Go Back   BMW E39 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs)
      09-26-2021, 09:33 PM   #1
fxcw85
Drives: 2022 BMW M440xi
Pressure washer
I took delivery of my M440i this week and am driving it back from PCD.
I used to take my previous car through the car wash but want to wash this car at home.
I was wondering if anyone had recommendations when it comes to pressure washers.
Any other tips for at home washing are welcome.
      09-29-2021, 03:35 AM   #2
NorCalAthlete
NorCalAthlete's Avatar
3292
Drives: '23 M4CX - Tanzanite / Tartufo
SunJoe SPX3000 seems to be the most common "bang for buck" for home washing.
I'm ordering one of those and then a TriNova foam cannon ($35 on Amazon). I have Microfiber Madness mitts and drying towels, still shopping for bucket + grit guard.
I plan on probably one good wash per month / quarter and foam spray on / spray off / dry quick wash about every other week / once a month.
Depends on how I feel in between. Might be excessive. But I've put 8k miles on it since April, so....
Ego is the anesthesia that deadens the pain of stupidity.
The single biggest problem in communication is the illusion that it has taken place.
Wheel horsepower is just crank horsepower after taxes.
IG: EmFore_650
fxcw8544.00
      09-30-2021, 12:28 AM   #3
VICG20M
VICG20M's Avatar
60
Drives: 330i M Sport
Check out detailing.com I get all my cleaning supplies from there.
fxcw8544.00
      09-30-2021, 11:12 AM   #4
R12ax7
R12ax7's Avatar
123
Drives: 2021 340xi
2011 328i  [0.00]
This is probably a stupid question....but do you use the pressure washer on the car? I just assumed even the lowest setting would ruin car paint.
Current: 2024 i4 M50
Retired:
2021 340xi |2018 330xi | 2016 340i 6MT | 2013 335i 6MT | 2011 328i 6MT (N52) | 2008 335xi (N54)
      09-30-2021, 02:14 PM   #5
NorCalAthlete
3292
That's partially why the SunJoe is so popular I think. It's on the lower end of medium power for pressure, quiet, with multiple tips to get the right spray. As long as you keep the tip at least 18" from the paint you should be fine from what I'm told. I have PPF + ceramic coating on mine and that's what my detailer said - 18-24" away from the paint and you're still fine, 12" is probably still ok but getting risky, anything closer and you may start peeling the PPF.
IG: EmFore_650
sfgator42.00
      10-01-2021, 08:19 AM   #6
ultrared93
Drives: '21 M340ix '93 300zxTT QX30
You might want to check out Obsessed Garage. Matt has tested dozens of different power washers (data available in a spreadsheet) from low end to commercial grade. About 1000 psi is a good target for washing a car. Matt drives BMWs and Porsches and his wash technique has been proven over many years on both coated and ppf cars.
fxcw8544.00
sfgator42.00
      10-01-2021, 11:09 PM   #7
fxcw85
Thank you for the replies and the resources, this is all great info.
      10-02-2021, 12:15 AM   #8
themnmd
themnmd's Avatar
Drives: 23 X5MC
I bought a Kranzel 1122 pressure washer from Matt at O.G. I love it, it is pricey though.
      10-26-2021, 05:28 PM   #9
justbananas
Drives: none
I saw a guy on YouTube take his car to a carwash, only to use their wand. He had his own buckets and wash mitts in the trunk.. Pretty smart if you ask me and I don't know why I never thought of it.
      10-27-2021, 12:13 AM   #10
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
I do that too. I only use the pressure washer at the coin wash since I haven't bought one yet. Only issue is the recycled water can cause water spots if you don't dry the car fast enough. I usually wash my cars at home and take it to a coin wash if it is really dirty or after heavy rains.
PS - You can't do that at crowded coin washes. Most won't let you use your own bucket and soap either. I'm lucky to live in a small town with many coin washes that have hardly any patrons visiting. Even then, I usually go late in the evening or early morning when it's abandoned.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      10-27-2021, 09:17 AM   #11
justbananas
Drives: none
I also own a Sun Joe washer from Home Depot... it's "okay". I further own a gas powered unit which is much heavier duty, but likely too much for my car. But frankly, I like the idea of the car wash because I can leave all the mess behind. Totally right if it's crowded.
VipinLJ1962.00
      10-29-2021, 11:30 AM   #12
Bc2005
Drives: 2021 M340i
I find it interesting that there are places with coin-operated self-washes that actually monitor your use of a bucket and soap. Every one I’ve been to was completely unmonitored, and you were lucky if they even had a working change machine or credit card swipe.
      10-30-2021, 09:06 PM   #13
TTG
TTG's Avatar
Drives: M340
This!
There really is nothing better than Kranzle out there but then OP sounds like a newbie and this might be a little too much for what he is looking for.
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
themnmd1708.50
      11-22-2021, 04:28 PM   #14
SummerallGuard04
SummerallGuard04's Avatar
89
Drives: 2016 BMW 550i M Sport
Electric and gas pressure washers are fine--honestly anything over 2000 PSI. My only advice is to steer clear around headlights and tailights and really anywhere there is exterior lighting as you don't want to break seals with pressure. The real fun is the foam cannon.
      12-11-2021, 03:14 PM   #15
siegester
siegester's Avatar
379
Drives: '20 M340i
2020 BMW M340i  [0.00]
I love my Sun joe SPX3001 and cheap foam cannon (both from Amazon on sale a while back). I stick to Megiuars mid level products for wash, correction, and protection. I'm not a crazy OCD detailer like you see online, but these products work great for me.
I also picked up a Griot's DA polisher and some lake country foam pads. All have been great for a novice like me and have had great results.
      12-11-2021, 07:52 PM   #16
CCM11285
CCM11285's Avatar
Drives: '24 G82
Sunjoe sxp3000, use the 40degree tip. You can spray as close as 12" away from the surface without harming anything. You'll want to look into getting a short gun for it and replacing the hose plus adding QDs. The standard hose and gun just suck to use for washing. Get a decent quality foam cannon (30-40$), find a quality soap, and use microfiber mitts and pads. Incredipads from Microfiber Madness are good but a little pricey. The Rag Company has their cyclone mitts and pads that are really good also and a bit more affordable. I use the multi pad method instead of messing with grit guards. You would have a mixture of 5 pads, and mitts. Once you've washed a panel or two then throw it in a separate bucket and grab another.
Alternatively, Obsessed Garage has curated packages available.
sfgator42.00
