07-02-2021, 05:04 PM | #1 |
Rep 632
Drives: 2011 E90 M3, 2018 F87 M2
I had another thread that was a long slow burn of track mods, but I'm resetting that as I feel like in the next few months it's going to fundamentally change from a casual slow burn to something totally different.
I'm intending to build a reliable NASA E0 endurance car, but also TT3/ST3 & BMWCCA B Mod I started tracking the car the same year I bought it in 2010, and some years I've been able to get out on track one weekend, and other years 10-12 times. My career in the Navy is changing and I won't be doing overseas deployments anymore so it seems like it's time to get more serious and more poor. The car just came back from fabrication at Neth Raceworks in Julian, CA. Pretty impressed with the fab design and the welding is a little out of this world. Bob Neth has a background in Baja desert trucks and does road cars too. Bimmerspeed in San Diego is doing the rest of the work. Here is the list of everything that is done or will be over the summer here in SoCal: MCS 2 way remote w/ 700/900 Springs Ground control camber plates Alcon CR6420 and CAR 4949 w/ PFC 13 Custom brake cooling backing plates Turner solid rear subframe bushings and Delrin diff bushings SPL arms in the rear Strom front uprights Remus Race Mid Pipe BW race exhaust BW front and rear aero 18x10.5 BW TA-16 Core4 hubs w/ 14mm press in studs AC delete w/ 2008MY power steering pump Epic DME tuning Motec PDM30 Motec C1212 dash Custom wiring harness Diffsonline 4.10 3 clutch diff do88 oil cooler CSF radiator SPAL fan Racetech 4199 Seat + Schroth 6 point KMP steering wheel Hard motorsports sedan rear door windows BW carbon sunroof insert BW carbon headlight inserts Coolshirt system Voltphreaks Li-Ion battery Macrolon front and rear windshield Lifeline 360 Novec fire sys CAE race shifter Custom 27 gallon fuel cell Bosch motorsport fuel pumps Here is the cage. Going off to paint the entire interior light gray next week: [IMG]"]https://lh3.googleusercontent.com/YtnrFGmCvuEeBB-47UuqKlPpeVAhkckfs1iaErPgD3N5SYI8yHGB2IoMqv1EHaJlr tM06K1dg9NAB1lXAhkUu06K-E7EFHc5CWxJiJ6LfcyXkF-5tHI6djvQ6SbvWwINO1JxIrKFdYk=w2400[/IMG] [IMG]"]https://lh3.googleusercontent.com/O-M-vek3mAJi6a_c0XaG9M02s-pwtXSAJfs_dIBOuozcGBz-ic2z1TXrE4t_AJHI89mHtsnFWJwStry4J0vbRrhTv1x7tsQvt0 A1XdJ8FypZ_IHd3cebaGWwMzsOQv6Mr0-DxdgyL-c=w2400[/IMG] [IMG]"]https://lh3.googleusercontent.com/iTiEUYzWPjwVR7cpWvPgVqUeS8jiTmPwVzJax13_Hk5Nlt9zyY mnDoP7wkHfWms7qAYecslMvil9nYAM3wQyLR5z_LtjJGnvNcKy 59I1s8wSaVApEzidy4zoozvZp-coxioznAvPnaQ=w2400[/IMG] [IMG]"]https://lh3.googleusercontent.com/TjR5tkwWPp2q88jlpGRVjxGabMUrUJ-pk4sL_GHawcrl6xHw1Crt1nAnJWtRaBllQVyb5IOmMq5dgJd7k RXnfIYZijkrEBTQra-GTPVykm_xVaczcvhcNJAGRsGjfPZ9N8O3cnjuHGQ=w2400[/IMG] [IMG]"]https://lh3.googleusercontent.com/nRbalfvLWKMWAz7Tf_UIKh31ggbPcuLStpTSTxht6aia_RlyA9 9IW5yJRRajPN0AgXeIgBs3CAtwWvV702ybWIWMcnQI8ddhBW4o NNFdoxhpT0zOC9VxmmprqXKpky728Vsu_7w9NaE=w2400[/IMG] [IMG]"]https://lh3.googleusercontent.com/M6bO8fyyIbSeZ00dh5xpW88VJruFg5lLAIcqm3u3zhY2EHax3Z MmeR3Wo6i6xRNZ67dZJme6936-Ajj55cgcoF75GsWLVidxVfq6BWPSjVtH6NY76FTuAQrwNoPSyh f6ENTGyUle7Ms=w2400[/IMG] [IMG]"]https://lh3.googleusercontent.com/9LCjD5tCCHVLMVMUuFJqni2uPJ6Ez45pRgOFHIPwbsZhV-vIy1CjDUx2EJZImOPMONJCVjVP3O6ZzT6Cre0xuPt2_jVXbxMH 80J2JqLNR8R4JuBE3yHPtpLv3Y5xC_TuqLhIhIOOL3Q=w2400[/IMG] [IMG]"]https://lh3.googleusercontent.com/-mMFEcf1RfABvJRzBRBoy53K3jXqu1wD6otBMf-vlaJKfv90dpSv8KdIKjgt-6M0-9tZ6fa9fMzWx94XycGL0mqxMJ97Le6WAv5guFF2I1nqLTIK0Yx TF2nhThguoiJirGSeWjWqWck=w2400[/IMG] [IMG]"]https://lh3.googleusercontent.com/r9MmU9SFSmoLhA4m58TLLu0nGRAcEWqFihxtbYrAVBeCfxxVJp HNY_4sn-zaHBp0xZAiArTO1DxDx35RnuNIMClO_iQ5FoDahDyc2Ty4nPjV GdWSMIPMmQUD8-NhmyQ_wakz9d3IkCs=w2400[/IMG] [IMG]"]https://lh3.googleusercontent.com/mvwuJCQX1Z1GQPGTDMv1t4ivf9rqSGV4LX7spj1jFetMi4xJHb R1J8gGYkpyXo4TrNhaXqPBdWtXv_sl4NJRxh9jZHKSgK-LeQUzF_hoFiXpHHcg5YTyqY5xk4AkVCT_rWFLjSY4plk=w2400[/IMG]
9
07-02-2021, 07:00 PM | #2 |
Rep 12,736
Awesome build dude.
Instagram; @roastbeefmike
evilspiritM3409.00 |
07-02-2021, 08:44 PM | #4 |
Rep 632
Haven't taken video in a long while. But will start once we shake the car out at Buttonwillow. Hopefully in October.
07-03-2021, 04:23 PM | #5 |
Rep 12,736
I'm hoping to get some good seat time in the fall. I'll see you out there. I can barely crack a 1:59 with my junk.
07-03-2021, 04:26 PM | #6 | |
Rep 632
Interested to see the new track layout at buttonwillow then too!
roastbeef11591.50 |
07-03-2021, 04:35 PM | #7 |
Rep 12,736
That new course is going to be a ton of fun. There are vids on YouTube of a dude driving the dirt course in a truck.
I can picture a weekend at buttonwillow like this- run cw13 one day then bbq and beers at night then running the new course the next day.
07-04-2021, 01:10 AM | #8 |
Derbo Tuning
3613
Rep 3,030
That sounds like a thunderhill East West party
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
roastbeef11591.50 |
07-13-2021, 06:15 AM | #9 |
Rep 38
Looks like a great build so far! Some great parts choices there.
Although I'll never know how you boys in the US cope with AC delete. Even here in the UK where it is pretty much always cold, I cannot bear to be without it on a trackday! |
07-20-2021, 02:14 PM | #10 |
Rep 632
Getting the car back from paint tomorrow to start assembly. Next big step is blueprinting out the wiring diagram and getting the harness made to play with the Motec PDM & dash and the factory DME that Epic Motorsport is tuning/tweaking.
Paint is a urethane coating from Sherwin Williams called "Genesis". Color is something close to matching Porsche's Chalk and sprayed in a satin finish. [IMG]https://lh3.googleusercontent.com/vc...VVih4wdc=w2400[/IMG] [IMG]https://lh3.googleusercontent.com/ab...nHpOsBMQ=w2400[/IMG] [IMG]https://lh3.googleusercontent.com/Uc...BQkzfLDg=w2400[/IMG] [IMG]https://lh3.googleusercontent.com/Mo...mvWJ631c=w2400[/IMG]
07-20-2021, 03:41 PM | #11 | |
Rep 126
07-20-2021, 05:10 PM | #12 |
Rep 12,736
I love it. The dash tie-in looks great.
I've been flip flopping on doing a cage or not. One thing I'm curios about is how much it helps with the rigidity of the car. Curious to hear impressions on that. I'm also looking forward to your wiring project!
07-20-2021, 05:36 PM | #13 | |
Rep 632
The front tie in I have is ok, and removable. Not as good as some of the work I've seen on E36-46. Who knows though. Not like I'll do any testing. But we have all that stuff behind the strut towers on the E90/2 it's hard to do a lot more without relocating all that stuff (brake booster, DME, etc). If you zoom in on where the bars tie in to the trunk floor there is some metal work beneath the plates that tie into the sub frame mounting. So I expect that is pretty robust.
roastbeef11591.50 |
07-21-2021, 05:26 AM | #14 |
Rep 12,736
can we talk about the motec power distribution module? what does it actually replace? are you relocating the DME at all?
i've read a few descriptions, and it seems like you connect it to the DME and just wire power to what you want to be functional? i'd really like to get rid of some of the wires in this car.
07-21-2021, 06:44 AM | #15 |
Rep 632
It's the Motec PDM30.
https://www.motec.com.au/pdm30/pdm30overview/ It does the work that the fuse box did. So all that stuff won't be going back in the car. Things will be relatively simple. I am re using the factory DME and I won't be using a Motec ECU. That's another level of complexity and money (and functionality- like real Motorsport traction control). I'll post a bunch more once I meet with the Motec guy and go through all the detail. I'll lose the wiring on the left and be keeping most of the wiring on the right: [IMG]https://lh3.googleusercontent.com/3D...9ojZ8-vs=w2400[/IMG] I'll end up with a simplified custom harness that is made to work with the Motec setup and the factory engine harness. So most everything you would have in the cabin of the car (wiring, fuse box, other random modules) is gone. This video sort of maps out what I am doing. Except he is using a Motec ECU and I won't be:
07-21-2021, 07:11 AM | #16 |
Rep 12,736
nice. i watched the video of the guy with the drag gtr. see if they'll give us a discount if i buy one and have them do the same wiring. lol
i have a basic grasp of the concept, but i'm kinda curious about the programming thing like lights through the brake pedals and such.
DRLane3996.00 |
07-21-2021, 09:34 AM | #17 | |
Rep 3,413
Really appreciate what you're working on here evilspiritM3 Congrats on the build and the thorough and thoughtful approach. I think this will pay dividends long into the future.
Not a Doctor, those are just my initials.
08-30-2021, 03:16 AM | #18 |
Rep 12,736
any updates?
i also wanted to ask you if you are solid on the SPL arms and the strom uprights. i was considering both, but was told using both would be redundant and not yield any benefit.
08-30-2021, 06:36 AM | #19 | |
Rep 632
Strom uprights aren't on yet . . . Getting the electronics set up first.
11-19-2021, 08:10 PM | #20 |
Rep 632
Random update:
Alcon kit is on Strom uprights are on Do88 Oil Cooler and CSF radiator are on Strom uprights don't play well with the full SPL setup. So back to stock steering arms and clearance between arms is good and the nut on the end of the arm doesn't come close to the wheel barrel. It'll get busy after we get back from the 25hr at Thunderhill. Next is wiring and Motec. Front and rear poly windshields are here. They turned out great - from racingshields.com. [IMG]https://lh3.googleusercontent.com/iO...Yy79dvYY=w2400[/IMG] [IMG]https://lh3.googleusercontent.com/DZ...XWQzx39M=w2400[/IMG] [IMG]https://lh3.googleusercontent.com/VU...1wkOmlSM=w2400[/IMG] [IMG]https://lh3.googleusercontent.com/rA...ISIMmlck=w2400[/IMG]
11-24-2021, 08:50 AM | #21 |
Alex - IG @screamer
632
Rep 480
Are you going to try and rework the Strom Uprights to make everything compatible?
Sucks because I have them (not installed yet), and have heard they work wonders! Subscribed to this epic build!
Instagram: @screamer
- 2013 Subaru STi Hatch - White - Racecar - 2011 BMW E92 M3 - Moonstone - Collector Car - 2008 BMW E90 M3 - Silverstone - Racecar |
11-24-2021, 01:57 PM | #22 |
Rep 632
Probably just going to go back to all stock arms on the front.
