01-23-2014, 02:06 PM | #23 | |||
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
Full Res http://farm6.staticflickr.com/5503/1...abdf00ca_o.jpg Full Res Full Res Full Res Full Res
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
01-23-2014, 03:45 PM | #26 |
11818
Rep 23,187
looks good with MR. just tell the mrs its a race car and thats how it supposed to sound.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
01-23-2014, 03:47 PM | #27 | |
Rep 4,002
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
01-23-2014, 04:08 PM | #28 | |
Rep 1,973
Thanks!
01-23-2014, 04:47 PM | #30 |
11818
Rep 23,187
no worries pretty soon she will just shake her head when a package arrives at the door and you say you needed it.
01-23-2014, 04:50 PM | #31 |
Rep 1,973
lol, thanks
ah, we're already there, she doesn't really bother to ask anymore.
01-23-2014, 05:15 PM | #32 |
11818
Rep 23,187
problem solved, mod away old sport.
01-23-2014, 05:27 PM | #33 | |||
Rep 1,519
Sight: bright Interlagos Blue Sound: squeal of Pagid pads; roar of full Dinan exhaust Feel: rumble/vibration from full Dinan exhaust Smell: nasty smell of catless setup Taste: nasty taste of exhaust fumes It was antisocial and fantastic!
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3 |
01-23-2014, 06:30 PM | #34 | |
Rep 1,973
01-23-2014, 07:41 PM | #35 |
Rep 8,077
Drives: 11 E90 M3 Individual
Nice!
Did you wash the rotors as directed? They look pretty silver. Probably not an issue now if you've driven it.
2018 F30 320iX Melbourne Red
01-23-2014, 07:48 PM | #36 |
Rep 1,973
washed and scrubbed with soap, hoping it was enough.
01-23-2014, 07:59 PM | #37 | |
Rep 8,077
Ok...I usually get runs of rust after washing. Doesn't take much.
I usually put a light coat of anti-seize on the bridge bolts. Lube the shaft so it slides in and out easier (that's what she said). Then lube the threads so you don't strip the timecerts. You can buy replacement timecerts and bolts. Just don't strip anything else on the caliper...then you're f'd. Enjoy! Quote:
Yeah, the Essex kit is better if for no other reason is the anti-knockback feature. Not sure about the consumables if replacement discs are $360ea. But the Essex kit is a little more...I'll just deal with the pad knockback. But these would definitely get a look if I had to buy a new BBK.
01-23-2014, 08:06 PM | #38 | ||
Rep 1,973
Thanks for the input, I'm itching for 2/1/2014 their first track day.
01-23-2014, 08:10 PM | #39 | ||
Rep 1,470
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
01-23-2014, 09:08 PM | #40 | |
Rep 1,973
The ST-40 was more my liking than the ST-60, but I'm sure there are benefits and drawbacks to both. I'm no expert, but likely I won't hit the limit of each any time soon... lol I'm just not that fast, but I like braking, and stopping power as well.
01-25-2014, 09:13 PM | #41 |
Rep 4,488
Nicely done OP! If you feel like experimenting with other pad compounds, PFCs are also popular on our cars. The 01 compound is the sprint version (hardest-core but fastest wearing and most rotor-hostile) and the 08 has nearly the same bite and somehow both the pads and rotors last longer with them -- and they cost about the same as 01s. All that sold me on 08s when I saw how much PFC pads cost in my ST-60 fitment: $480-550 just for the front!
I mention this mostly because I did a fair amount of research on pads myself before buying and I found that lots of people love the Pagids bit acknowledge that they're VERY picky about being bedded in properly, whereas the PFCs don.'to really care. I personally swap my PFCs in a week before I'll be at the track and drive gently during the week to scrape the street pad deposits off the rotors, then leave them in a week after the event to scrape their own deposits off before going back to street. Obviously race pads make far better scrapers than street pads. Out of curiosity though, what did you mean about the ST-40 making street/track pad swaps viable compared to the ST-60? Not that I disagree with your reasoning for going ST-40, but it seems equally easy on both choices. I went with the ST-60 myself because I figured a heavy car like ours needed all the fade resistance it could get (thanks to the 380mm rotors, primarily) and because the pads should last longer due to spreading the load over their larger surface. Good luck and enjoy your track event!!
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
01-25-2014, 10:08 PM | #43 |
Rep 5,483
Sweet. They look surprisingly big behind the 19's, I guess the calipers help. I also went with the st40 (trophy because I like the added lightness and the finish better) fronts for similar reasons, mostly because I don't want to compromise on running my 219M's. Sweet. V
01-26-2014, 12:11 AM | #44 |
Retired Curmudgeon
2985
Rep 4,050
Agreed!
Now I'm anxious to hear how they work at the track. If you can't find pagid street pads (I thought our stock pads were made by pagid, or are they juried), maybe you can switch to PFC next time if they make a z-rated and '08 pad in the ST40 size.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
