10-23-2023, 05:29 AM | #1 |
Rep 161
Posts Drives: BMW 2023 M340i Join Date: Oct 2023
Ppf xpel vs suntek
Hi everyone,
I’m considering going PPF on by G80 arriving this week. I’m stock on the typical is it worth it? Obviously cost is large I’ve gotten quotes from 6500-7800. SunTek is 6500 whereas Xpel is 7800. Both films have the ceramic built in. Does anyone have experience? I know the investment is a losing argument and will never recoup the money. When I stated considering partial and all high impact areas, it’s near 4500-5000. Anyone in upstate NY have options? Dutchess/Putnam. Thanks for the help! |
10-23-2023, 06:55 AM | #2 |
Rep 1,916
At those prices, definitely not worth it. Even if you plan to keep the car "forever" that's still a stretch. A part of what's killing the value proposition is your location and the type of car. Not sure you can do much about either of those.
FYI - I'm not anti-ppf either. I've had at least 6 cars ppf'd. The prices in my area make it more palatable, and candidly, it's a no brainer if you care about the exterior appearance of your car. |
10-23-2023, 07:21 AM | #3 |
Rep 1,160
Pricing is what the market will support.....hence location....
Suntek and Xpel should price out the same but it depends on the -installer- and their rate. However, when doing PPF. while you are paying for the film (material ain't chea), it's also about the installer.....so YMMV. Xpel is a bit thicker so takes abuse a smidge better. Stek IMO looks better, it is a smidge thinner, so less Orange Peel that comes with it. Both great films. I'd find a installer you prefer then let the film be the second deciding factor |
snyder268188.50 |
10-23-2023, 07:30 AM | #4 |
Rep 5,112
Posts Drives: 2022 Z4 M40i, 2021 228i GC Join Date: Sep 2021
Xpel's Ultimate Fusion PPF which has a hydrophobic top coat (like ceramic coating) will be more expensive than their Ultimate Plus PPF which lacks this feature. Sun Tek's is also a well known brand and their Reaction PPF also has this hydrophobic top coat.
IMHO, this is more of a case of finding a shop that has excellent reviews and doesn't use precut pieces. That factored along with the cost should determine snyder268's decision. I personally would pay a little more if I knew my shop does top quality work. By the way, I don't recall picking up rock chips from street driving when I used to live in NYC. However this definitely happened while driving on the roads in upstate NY and many rock chips appeared on the front of my old CLK500 when I was upstate and they drove me crazy so I can understand why snyder268 wants to protect his G80. PS, just because a shops quotes you a price doesn't mean that you can negotiate and lower it. Nobody likes to lose business. Last edited by Westside Guy; 10-23-2023 at 12:10 PM.. Reason: corrected a typo |
snyder268188.50 |
10-23-2023, 08:03 AM | #5 |
Rep 31
I would definitely shop around for pricing.
To put it in perspective I'm getting XPEL installed on my Huracan STO for $6500. On the scale of difficulty, install on the STO is probably 8 or 9, install takes 5 days. I can't imagine PPF pricing to be that different in NY vs Miami or LA. |
snyder268188.50 |
10-23-2023, 08:30 AM | #6 | |
Rep 161
10-23-2023, 08:33 AM | #7 | |
Rep 161
Westside Guy6995.50 |
10-23-2023, 08:35 AM | #8 | |
Rep 5,112
Can’t you find a shop that doesn’t use pre-cut panels? |
10-23-2023, 08:42 AM | #9 |
Rep 161
I’ll do some more research locally and see if there are so other shops with good reviews that do more custom wraps. The other shop I know I’ll have to reach out and get a quote on the Xpel full wrap cost. I know they do quite a few ppf jobs and I’ve known the owner for awhile. When I mentioned I had a g80 on order and was considering ppf he said they would do the precut as well. I guess saving them a ton of time in labor. I definitely want something to last. I think definitely going somewhere with a warranty is worth it, if I’m debating spending that much money I might as well have it covered.
10-23-2023, 08:47 AM | #10 | |
Rep 5,112
snyder268188.50 |
10-23-2023, 09:14 AM | #11 | |
Rep 1,160
Don't hold me to this but at least in my area, if one is a Xpel Dealer.....they don't offer anything other than Xpel. It has to do with their dealer agreement, etc. This rule may not be the same in your region.... Both the Xpel and Stek shop I know do high quality work but it's not like the Stek shop can offer Xpel film...Hence, which is probably why he is stating he can offer you Stek, with no warranty....he is not an authorized Stek shop. When it comes to warranty - it's only as good as if:what is covered... Hopefully you would not need to take up on it, but the cost of PPF is high as there is the -built in cost- of either needing to redo the panel while they are doing the install and or they may need to redo the panel whether it be 3 months from install or 3 years from it.. YMMV but going to my 1st reply, installer is key....not the film, Last edited by chefwong; 10-23-2023 at 09:55 AM.. |
snyder268188.50 |
10-23-2023, 09:37 AM | #13 | |
Rep 161
10-23-2023, 09:42 AM | #14 |
Rep 1,011
Posts Drives: 2007 Z4 M Coupe 2012 e93 M3 Join Date: Sep 2008
I have Xpel Ultimate on the M3 and Suntek Ultra in the DD.
I don't have experience with Ceramic Infused PPF but would recommend Suntek over Xpel. Do some researches on Xpel! They recently changed their warranty terms and a few of my friends stopped offer Xpel because of the changes. |
snyder268188.50 |
10-23-2023, 09:59 AM | #15 |
Rep 1,160
On the topic of custom vs precut, there is not right or wrong. In some instances, precut with some allowance for extra material to get close to the edge may be superior than a custom wrapped to the edge.
It depends how much stuff is removed in order to do a proper to the edge. If it's cut on an edge but not tucked behind the edge, sometimes u get lifting - as the film cures and it shifts over time. The film is thick - the tension on the film, movement, etc. Hence, don't drive 200 miles for a cheaper install price, unless you don't mind driving 200 miles + to the same shop for post install fixes. The film will need to be *tweaked and adjusted* as the film cures and shifts post it's initial install..Sometimes this may dictate a panel redo (rarely) but film does shift a bit as it cures. |
snyder268188.50 |
10-23-2023, 10:06 AM | #16 |
Rep 1,160
Snyder -
1st time getting PPF. I did say installer is key right ? They guys are using Surgical knives to score the film on the paint. The film is thick...... Sh### happens and PPF also covers up scored paint . Hence, installer is key. Visual good ppf install aside, you also want one that is not going to hack the ## out of you paint and you may never know until the day you remove it and paint is cut.. I suppose that is one advantage to pre cut. Some shops do full wraps. Some shops may do hybrid - custom cut and some areas with pre cut . The installer will somewhat dictate how to get the best results .... if he has the skill for custom + pre cut with *tweaking* on the plotter |
snyder268188.50 |
10-23-2023, 10:17 AM | #17 | |
Rep 161
10-23-2023, 10:30 AM | #18 |
Rep 1,160
That's more a budget question on front end or full wrap. Front end takes most of the brunt. But sometimes, when you're adding the rockers, B, C Pillars, you're down the rabbit hole of F'it, let's just full wrap it.
Forget what you see on instagram, yelp, google reviews, etc. While that is helpful, I'd say do an impromptu visit to the shop. You want to see real life cars in progress or know if customers who have had work them in real life experiences.. I know of one shop. Exotics galore....all favorable yelp reviews, google review - almost 4.5'5 Stars highly reviewed. The work is crap if not whatever the cars in the shop that it is subjected to. I was once there and saw them using a grinder doing some bodywork within almost the same space where PPF is in the adjacent room. However, next to this car, was 10 cars in the same work bay getting vinyl done, etc and if you don't know what happens with Hot Metal Sparks flying everywhere....I was in awe on the lack of -unawareness- of all those others cars and hot metal slag getting embedded into the adjacent cars finishes, with the owners not knowing what their vehicles were being subjected to. Alot of #### goes in the shop that one never sees or knows. Last edited by chefwong; 10-23-2023 at 12:23 PM.. |
snyder268188.50 |
10-23-2023, 12:19 PM | #19 |
Rep 5,112
Actually I would rather be in a city like NYC, Miami & LA because in a major market there are many more shops to select from. This allows people the ability to shop around for a better price. I drove a hard bargain with the shop I finally selected and started to walk out before they lowered their original quote because he didn't want to lose a potential sale.
10-23-2023, 12:28 PM | #20 | |
Rep 1,160
Of the handful or less PPF shops I would use, their pricing is -all the same-. Maybe $200-300$ difference between some, but for the most part, the same pricing across the board.... And some of these shops, like the *exotic gram* shop I mentioned who puts out crap work if not mis-treats cars left at the shop, his pricing is the same as a Top Level PPF installer/detailer who is in a different league in terms on quality of output if not attention to detail. |
10-23-2023, 12:53 PM | #22 | |
Rep 7,503
snyder268188.50 |
