HPDE Track Setup Thread
07-06-2012, 09:46 PM | #46 |
2006 330i, TSM, Black, manual, sport
878
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
I run front and rear spacers on my track setup.
My wheels are Enkei RPF1 18x8.5 et40 and I run a 5mm spacer front and rear. BFGoodrich R1 in 245/40-18.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
07-06-2012, 10:48 PM | #47 |
Rep 1,324
Drives: 335i Coupe, 6 Speed
07-10-2012, 12:27 PM | #50 |
Rep 595
Are you running 275 on 9.5" wheels in the fronts? What offset, and what camber setting?
07-10-2012, 12:30 PM | #51 |
Rep 1,324
02-23-2013, 02:40 PM | #55 |
Rep 4,121
335d
Considering following upgrades (tracked once, planning on 1-3x/year): 1) BMW performance suspension (from stock/non-zsp) 2) Upgraded Wagner FMIC (1-2% hp boost, 23 degrees cooler, less heat soak 3) LSD (Quaife or maybe Wavetrak). Thoughts? |
02-25-2013, 10:43 PM | #56 |
Rep 2,678
1 and 3 are nice upgrades but ... you will open up a can of warms lol. Once I upgraded suspension I had to replace subframe bushings and it goes on ...
02-25-2013, 11:17 PM | #57 |
Wannabe Track Rat
70
Rep 930
So an update to my setup-
AST 4100- run usually 6/10F 8/10R, but a work in progress Vorshlag Plates, -2.0 Front -1.75 Rear APEX ARC-8 17x9 Square Nitto NT-01 255/40/17 StopTech Powerslot rotors w/ PFC-08 (love these pads!!) I really like the alignment settings, getting even wear on tires. Still tweaking rebound settings.
2017 OG M2
02-26-2013, 08:13 AM | #58 |
Rep 864
Drives: '08 E92 335i
Ground Control coilovers 525f/650r spring rates, dampers adjustments in the middle of the range f/r
Ground control camber plates, -3.3 degrees front -2.4 degrees rear, 1/8" total toe out in the front, 1/8" total toe in in the rear UUC 27mm front 19mm rear swaybars, both on the softer of the two adjustment holes Nitto NT01 255/40-17 front 275/40-17 rear tires on 17x9.5 et35 Arc-8's Stoptech 355mm BBK front axle, PFC06 pads, stock rotors/pads/calipers rear OS Giken Superlock LSD Powerflex subframe/diff bushings Stett Stage 2 oil cooler downpipes/cat back exhaust/FMIC, Cobb stage 2+ FMIC tune Running great so far, working on tightening the nut behind the wheel. |
02-26-2013, 01:02 PM | #59 | |
Rep 638
02-26-2013, 09:17 PM | #60 | |
Rep 8,745
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
02-26-2013, 09:43 PM | #61 |
Rep 1,510
02-26-2013, 09:49 PM | #62 | |
Rep 8,745
My PFC 08 my mechanic had to fabricate a wedge to minimize the back and forth play, otherwise it sounded as someone hammering away repetitively at a piece of metal.
02-26-2013, 09:50 PM | #63 |
Rep 4,109
Drives: BMW M3
I bought the PFC 08 when they were released, front and rear. It's good to hear the new ones are coming with clips on the front. Mine rattled like hell for a few months, then after a few track days and street driving, no rattling ...hmm.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
02-26-2013, 09:58 PM | #64 | |
Rep 1,510
I bought mine from Harold (hpashop) about a month ago. |
02-26-2013, 10:09 PM | #65 |
Rep 8,745
ha ha yes, and I drove in bumper to bumper traffic on the highway and tried not to make eye contact with drivers in the cars around me, lol! I even saw some nodding their heads in disbelief....
02-26-2013, 10:12 PM | #66 |
Rep 8,745
I guess the track days must have evened the rotor surface flat and hence no more grabbing of the pad by the rotor.
