Hello Colorado, Goodbye 2020
12-22-2020, 03:02 PM | #1 |
Major nutz
86
Rep 1,489
Drives: '09 n54 e92xi, 6mt, kw v3
Still have my '09 e92 that I bought new.
107,570 miles. Only drove it about 300 miles this year with Covid... Still pulls hard. In the 11 years since I bought it from (now gone) Murray Motors in Denver: Oil changes every 4k or so (sometimes more frequent) HPFP @5k - warranty Used Brembo BBK @ ~10k Numerous brake fluid flush/bleed/replacements New spark plugs every 10k or so 40k miles Battery replacement 02 sensors replacement 1 walnut blast @ ~ 42k (oil catch install at that time too --> really helps, checked @85k, need to check again) Between 50k and 60k miles Fuel Injectors VC (cracked) and gasket replaced Alternator replacement (twice, but because original replacement also went bad ) Oil filter housing gasket replacement (same time as alternator, 'cause the alternator is a PIA, and helps to remove oil filter housing) Trans & front/rear diff and TC fluid replacement (need to do again) Right front half-shaft (CV joint) replacement 80k miles Water Pump & thermostat replacement Car has been trouble free since the water pump. To do: Front hub replacement Possible left front half shaft replacement Diff & Transmission fluid replacement Possible walnut blast Still like this car and enjoy working on it, even though engine bay makes if feel like you are working on a 10# of s#!t in a 5# bag.
01-20-2021, 11:18 AM | #2 | |
Rep 1,578
