09-13-2023, 11:03 PM | #1 |
Rep 77
Ppf assessment - 4 months on
Bought my 2019 X5 beginning of May with 40k on the clock. Took it to a well-known detailing shop and had a single stage polish, ceramic wrap and PPF in all the usual areas. Vehicle already looked brand new before i got all that work done, it looked even better after. However, 4 months on the PPF is peeling around some of the edges. I've done only local driving in the city and a couple of small < 200km trips to the countryside and even then hardly had any bugs. Vehicle gets babied and washed once a week carefully. We're getting ready for the Canadian winter up here, I’m concerned this is going to get worse. The PPF is looking dirty where it's getting exposed underneath Before I go have a conversation, just wanted to get everyone’s opinion - this PPF shouldn't be doing this after 4 months - right? LOL
*Apologies if the images aren't crystal clear
2011 335 xDrive - retired
2019 X5 xDrive40i MSport |
09-14-2023, 07:01 AM | #4 | |
Rep 5,112
Posts Drives: 2022 Z4 M40i, 2021 228i GC Join Date: Sep 2021
After 4 months this definitely should not be happening, take your car back to the shop and insist that they correct the issue! |
09-14-2023, 07:06 AM | #5 |
Rep 5,112
The length of the warranty depends on the brand of PPF installed and whether you have purchased it from an authorized shop. Both Xpel and Stek give you 10 years, Ceramic Pro is 12 years and others can vary.
bvrider1359.00 |
09-14-2023, 10:20 AM | #6 |
Rep 77
Thanks for the feedback. I've dealt with this shop before and never had any bad experiences and the ceramic coating looks to be good.
Looks like they used this stuff: Premium Shield Elite Nextgen Paint Protection Film https://premiumshield.com/ Convo this morning: Shop: That'll just need trimming, that's very typical and why I mention coming back for trims in a month or so. It's just more visible because it's white Me: How do you mean trimming. Not trying to be difficult, I don't really know much about putting new PPF on a car, but it looks to be worse than just needing a trim. My concern is all the crud from the winter is going to make this worse. Shop: I trim off a small amount up to where the film is holding. White will always accumulate dirt and stuff on the edges but trimming that extended edge makes it much less
09-14-2023, 12:35 PM | #7 |
Rep 77
Apparently Premium Shield Elite is lifetime
09-14-2023, 12:58 PM | #8 | |
AZhusky
132
Rep 111
Trimming to me seems like just a "bad fix" option as now you're going to have even less coverage/protection for the paint and what's to say it doesn't keep peeling up? |
09-14-2023, 02:16 PM | #9 |
Rep 1,011
Posts Drives: 2007 Z4 M Coupe 2012 e93 M3 Join Date: Sep 2008
Man, those are terrible and sorry you have to deal with it.
Trimming is normal when doing PPF but the edges should not lifted and had all kind of crabs built up. Have both of my M3 and a DD done with partial PPF and never have issues with the edges. Most likely they have a defective material or the PPF is so bad and the Adhesive never "cured". Definitely push for a re-do but not sure if I would want the same Film (let alone the same installer). |
Westside Guy6995.50 P111716.50 |
09-14-2023, 02:40 PM | #10 |
Rep 7,503
Yeah this is a shit install or adhesive.
09-14-2023, 05:50 PM | #11 |
F15 daddymobile
2434
Rep 3,580
looks like they coulda used more tack solution on the edges. heat also helps to let the slip solution dry out. this is common but not entirely a normal thing. a good install doesn't have this issue
09-14-2023, 06:22 PM | #12 | |
Rep 5,112
You should ask them if this will reappear on the edges every time they trim the PPF and at what point will they simply replace the PPF. |
09-14-2023, 08:29 PM | #13 |
Rep 4,548
That's a terrible PPF job. Not even close to any edges at all. Brutal. Hopefully you didn't pay much.
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
09-14-2023, 08:37 PM | #14 |
Rep 760
when you guys say warranty, does it refer to the time the PPF can be installed on the car without affecting the original paint? or warranty of any defect workmanship or peeling, etc that they will replace it if within the warranty period?
09-14-2023, 08:45 PM | #15 |
Rep 806
peeling, lifting of edges, defects in the material itself.
09-14-2023, 10:32 PM | #16 |
Rep 760
09-17-2023, 11:03 AM | #17 | |
F15 daddymobile
2434
Rep 3,580
however, ppf will never ruin your paint when removed properly. sure it will be harder to remove and become brittle as it ages but it should not damage your paint in any phase of its life
Westside Guy6995.50 |
09-17-2023, 11:27 AM | #18 | |
Rep 5,112
09-17-2023, 12:30 PM | #19 |
Rep 11,181
That is a horrendous looking and very amateurish PPF install. What on earth did they do in that second picture? Looks like a kindergartener did this during this lunch break.
I'd ask for those areas to be 100% redone. Completely unacceptable. |
09-17-2023, 08:35 PM | #21 |
Rep 57
Posts Drives: '23 840i, '24 X6 40i, '19 X7 Join Date: Jan 2022
That is definitely an unacceptable instal, even if they used pre cut PPF. Plus, in some of the pictures it seems to be discolored, like it is turning amber already....
Stuabroad21.50 |
09-18-2023, 07:04 AM | #22 |
Rep 5,112
