06-01-2009, 11:42 AM | #1 | |
Rep 4,647
air france airbus vanishes over the atlantic
06-01-2009, 12:35 PM | #5 |
Rep 335
awful, i cant see any chance that the are ok after the numerous articles i have read from online newspapers across the world (although most talk about the same thing)
06-01-2009, 01:18 PM | #7 |
Rep 5,970
Cost cutting. The airlines are all trying to save a buck, and I just don't have a lot of faith in what they're doing. I fly a LOT of regional trips, and I seriously question the skill of the pilots sometimes, as well as the maintanence. For example, I was on a flight a few months ago, and the guy dropped the landing gear nearly 20 minutes before we hit the ground. We weren't even close to being on approach when he did it. |
06-01-2009, 01:19 PM | #8 |
Rep 4,647
most commercial planes have onboard weather radar, and they do know the storm is there. in the end, it's up to the pilot-in-command to make the call to continue or not. he has to make the decision based on several factors including fuel, how severe the situation is based on information he's got, airline policies, and the safety of all onboard. he obviously didn't think anything was too bad so he continued. whatever happened up there happened quickly and it's doubtful that there could have been anything done to save the plane.
06-01-2009, 01:24 PM | #9 | ||
Rep 982
06-01-2009, 01:25 PM | #10 | |
Rep 4,647
06-01-2009, 01:32 PM | #11 |
Rep 4,647
that particular accident you're talking about was an aeroperu 757 that was being washed and waxed by ground crews and the static ports were taped over. the static ports are critical for accurate readings for airspeed, altitude, vertical speed indications. once the static port is blocked, you won't necessarily get false readings right away, but eventually you will.
06-01-2009, 01:32 PM | #12 | |
Supreme Allied Commander
2002
Rep 61,781
Posts Drives: A BBS WHORE Join Date: Jul 2007
he dropped it 20 somewhat minutes before touch down might be required to reduce speed further requsted by ATC....spoilers can do the trick too...but it will increast its race of descent....
06-01-2009, 01:36 PM | #13 |
2002
Rep 61,781
Map from BBC...
06-01-2009, 01:46 PM | #14 |
Rep 4,647
06-01-2009, 01:48 PM | #15 | |
Rep 5,970
Or more likely the guy just screwed up. It was coming into Evansville, so it's not like there's a lot of traffic to deal with that would require him to get in line. They have like four flights an hour or something. Besides, it was just an example. The fact that they're cutting corners is very well known, and there's been a lot of talk latley about the experience level of regional pilots. |
06-01-2009, 01:50 PM | #16 | |
2002
Rep 61,781
it'll be even harder to search for the CVR and FDR, given them has only 30 days to send beacon signal for SAR teams...
06-01-2009, 01:52 PM | #17 | |
Rep 5,970
I would almost rather see it turn out to be mechanical failure, rather than just a feak accident caused by the weather. The mechanical failure can be fixed, the other can't. Same goes for pilot training. I'm hoping we see some tightening of the standards for commercial Pilots because of the recent accidents. |
06-01-2009, 01:53 PM | #18 | |
2002
Rep 61,781
but AFAIK, mainline pilots and regional pilots receives the same training then off to type specific...which one scares you more? a regional pilot with 20+ years experience, or mainline cadets (which most asian and middle-east airlines do) with only 2-5 years experience flying a 747?
06-01-2009, 01:58 PM | #19 | |
Rep 5,970
I see VERY few regional pilots that are old enough to have 20 years experience driving, let alone flying. Honestly, they all scare me these days. I don't do a lot of internation travel right now, and I'm glad. I used to go to UAE twice a month sometimes, and I don't miss those trips at all. |
06-01-2009, 02:03 PM | #20 | |
2002
Rep 61,781
it sucks that you kind of have the feeling that most accidents are preventable....the chain of mistakes just happens to lined up....one single person caught the error and everything would be ok....or prevent the scenerio to get wrose... there's so much "whys?" need to be find out...
06-01-2009, 02:03 PM | #21 |
aka 1013MM
1310
Rep 9,545
episode 1 season 1 of LOST
06-01-2009, 02:03 PM | #22 | |
Rep 4,647
