GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      10-27-2017, 05:41 AM   #23
elmerzasty
elmerzasty's Avatar
Poland
69
Drives: F80
Ar they indeed painted? Maybe the finish is anodized and hence no paint color?
      10-27-2017, 03:18 PM   #24
Mike991M4
Drives: 2017 M4
yeah, I'm pretty sure they are anodized. Thats why people have had them discolor when using harsh wheel/brake cleaning chemicals.
1986 300ZX
2009 370Z Racecar
2013 991 C2S
2015 Cayenne Diesel
2017 M4 Competition
      10-28-2017, 08:01 PM   #25
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
The calipers are painted.
      11-02-2017, 11:01 PM   #26
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Originally Posted by BishUK View Post
Originally Posted by Encanto View Post
http://f80.bimmerpost.com/forums/sho...2&postcount=19
Going to try and liven this thread back up.
Did anyone ever get to the bottom of this paint code?
It seems BMW is keeping their code top secret.
Thanks, I saw that previously but nobody seems to know the paint code - or has ever heard of Meridian Gold.
The hunt continues...
It's a proprietary Brembo for M GmbH extremely high temperature paint. Outside of the MCCB calipers, and safety cars, Meridian Gold has been used precisely once.
BishUK440.00
Colinv64053.50
      11-04-2017, 07:32 PM   #27
Mike991M4
Drives: 2017 M4
I've never seen paint do this, but anodizing does if hit with chemicals
http://f80.bimmerpost.com/forums/sho...color+detailer
1986 300ZX
2009 370Z Racecar
2013 991 C2S
2015 Cayenne Diesel
2017 M4 Competition
      12-13-2018, 11:52 PM   #28
domino_z
Drives: F-Pace SVR
bump
anyone found a similar paint code
want to do my chargepipes to match ccb
      02-22-2019, 05:47 AM   #29
G4BR13L
G4BR13L's Avatar
Belgium
524
Drives: BMW M4
Originally Posted by Technic View Post
I do have those CCB calipers right now being refinished and the paint to be used is definitely not Phoenix Yellow. Look at your photo and look at this:
One is yellow and the other is really gold... there is nothing in between.
Wow this looks amazing! Did you get it refinished through the BMW dealer? Care to share the expected cost? I have some decolorization on mine.
      03-03-2019, 12:10 PM   #30
ronnie001
New to BMW world
Drives: 2015 M5 Competition
Can you tell me where you had your CCB refinished?
I know this was a post awhile ago. Where did you get your calipers refinished?
Mine are in need.
      03-03-2019, 01:24 PM   #31
G4BR13L
G4BR13L's Avatar
Belgium
524
Drives: BMW M4
I have the same question but Technic disappeared.
      03-13-2019, 06:12 AM   #32
G4BR13L
G4BR13L's Avatar
Belgium
524
Drives: BMW M4
I contacted Brembo a while ago and this was their response:
The coating used at the BMW M caliper has an oxidation as a base layer and on top a liquid paint. This paint can change its color if it is being confronted with higher temperatures. The paint code is GOLD 1PR (no correspondence to Pantone references etc..).
Unfortunately the paint code GOLD 1PR does not provide us more information if it only used internally by Brembo.
On their website are also 5 reason why not the use repainted calipers:
https://www.brembo.com/en/company/ne...alipers-brembo
      03-13-2019, 02:25 PM   #33
Encanto
Encanto's Avatar
He, he, he... “banano” calipers!!
      03-15-2019, 12:27 PM   #34
coldfish
Drives: Alpine White 2018 M3 F80
Originally Posted by BhamDavid View Post
Trust me, been there trying to match caliper paint. It's definitely Phoenix Yellow.
See Phoenix Yellow M3 below to refresh your memory what this color looks like.
[IMG]http://i180.photobucket.com/albums/x...742C0E39EF.jpg[/IMG]
Can you post the paint code ?
      03-16-2019, 10:50 AM   #35
MasterP
Drives: All the M's
None of those reasons are sound reasons to avoid repainted calipers - particularly if you know the caliper's origins. It's very likely just marketing from Brembo to buy new vs refinishing.
When you rebuild a caliper to replace boots and seals you almost disassemble it down to a bare caliper anyway so scuffing the caliper and applying fresh paint isn't much more work. So long as the piston buckets and bleeder/crossover ports are covered/plugged its fine.
I can't speak for brembo but ST anodizes their calipers and then applies their painted finish above that.
If you get any brake caliper remotely hot they will discolor unless that color is black.
      10-12-2020, 08:40 AM   #36
andrej--h
Switzerland
11
Drives: F83 & F01 & E46 M3 & Z3 QP
Hi folks you can use : RAL 1002 with "seidenmatt" effect guess its "semi-gloss" in english.
irunalot1518.00
      10-29-2020, 03:35 PM   #37
MineralWhiteF80
Dont listen to me
Drives: F82, E92 M3, G30 M550i, E46
just came across something that made me think of this thread- It appears people are also Cerakoting their calipers. Cerakote is known a lot in the gun world for high-heat, durable coatings. If you click this link, some of the gold cerakote options look pretty dang good, albeit not exactly the same. Just another option for people...
https://www.cerakote.com/project-gal...-140-and-h-167
      06-27-2021, 04:16 AM   #38
acob-84
Drives: BMW E46 M50 turbo BMW E60 545i
Paint code and method
Hi Technic
I know its been some time since this thread was started, but could you inform us on the paint and method for refurbishing the ccb calipers, as i would like to fix mine as close to oem again as possible.
Kind regards from Denmark.
      06-27-2021, 06:03 AM   #39
swagon
swagon's Avatar
Drives: F80 6MT
Originally Posted by acob-84 View Post
Hi Technic
Post 26 on this page? Anyone ever tried it out?
Could try finding someone at Brembo OEM to answer the question since they're the supplier.
      06-28-2021, 10:18 AM   #40
M 4 FUN
Drives: 320 Si, M4 comp. M3 E46
We mixed the colour after scanning it. We used two Mini colours, which is BMW nowadays. They are as follows:
Solid Sienna gold effect
B748297.
And the other.
A782560.
swagon13572.00
      06-28-2021, 12:09 PM   #41
TrevorM3
Drives: 6.3 AMG
there is no code the calipers. Whoever is painting them or powdercoating them needs to just tint it accordingly. The calipers dont even have a shiny clear on it either. More of a flat finish, which needs to be considered as well
      09-07-2021, 07:41 PM   #42
FrankMstein
FrankMstein's Avatar
Drives: F80 M3, R56 Camden, G37x
How about WC1P Galvanic Gold Metallic? Anyone have this on an X2 or an i3 and can shoot a pic next to a CCB?
f80post
