BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
      02-15-2011, 04:58 PM   #1
jeff@autocouture
BimmerPost Supporting Vendor
jeff@autocouture's Avatar
975
Drives: 2002 E53 X5 4.6is
Recaro pp vs recaro sportster cs
Does anyone have know the weight of the pole positions and the sportster cs seats with all proper mounting hardware, I want to see what the difference in weight is with all hardware and seats ready to be mounted
Thanks for any help
      02-15-2011, 07:07 PM   #2
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Thanks for any help
Not much, you're looking at approx ~8lb difference.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      02-15-2011, 07:12 PM   #3
jeff@autocouture
975
That's it? Because I know the seats alone-
Rpp are about 18 and the sportsters are 33, I know the sportsters don't use the side mount but I didNt realize it was only 8lbs, not bad
Sportster make more sense then
      02-15-2011, 07:23 PM   #4
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
I ran the PPs at first, then switched to the Sportster CS seats on my e92 M3.
The Sportsters do not require a side mount as these are already built into the seat (steel mounts are heavy), which accounts for most of the difference.
We are an authorized Recaro retailer, let me know if you have any questions.
      02-16-2011, 05:47 AM   #5
ee8
Portugal
Drives: E92 M3
2008 BMW M3  [6.40]
you don´t have to use steel side mounts... you can use aluminium thus maximising wheight gains with the PP... however if you need the backseats the CS is obviously the way to go...
By the way Tom... is it possible to get a CS seat covered in the oem Bamboo Beige leather?
      02-16-2011, 10:17 AM   #6
jeff@autocouture
975
which did you find more comfortable, which held you in better, i used to dd with rpp in my e46 and loved them but figured if there isnt much of a weight difference then why not get sportsters
      02-16-2011, 10:57 AM   #7
rzm3
rzm3's Avatar
675
Drives: E92 M3
Other thing to keep in mind is that pp is fixed back and fia approved for racing.
      02-16-2011, 11:06 AM   #8
jeff@autocouture
975
The sportsters aren't? So does that mean I can't use the seats on the track? I don't track yet but plan on starting this year, any info is good
      02-16-2011, 11:39 AM   #9
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
As well as the side mounts, aluminum are not FIA cert - only steel versions from Recaro.
      02-16-2011, 11:49 AM   #10
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Yes, Recaro offers the S08 program (at additional cost) in which you can provide leather for them to cover. There is an approval process required.
The sportsters aren't? So does that mean I can't use the seats on the track? I don't track yet but plan on starting this year, any info is good[
Not competitively, this will depend on the rules set by that specific track/organization. Most Recaro fixed-back shells are FIA Cert.
Fixed back shells are best suited for track use. The Sporster CS seats are the same as the BMW performance seats (sans airbags), and better suited for everyday driving.
      02-16-2011, 05:14 PM   #11
montreal red
chris
montreal red's Avatar
Drives: White Boat
if you need back seats then go for the CS... with recaro PPs, the back seat will be almost impossible to get into.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      01-16-2013, 07:41 AM   #12
Superfly_M3
Drives: 2011 M3
Thread revive
what are the weight savings of Recaro CS vs OEM power seat in the M3 (E90).
Thanks.
      01-16-2013, 06:39 PM   #13
M3PO
M3PO's Avatar
84
Drives: '08 IB E92
Originally Posted by Superfly_M3 View Post
Thread revive
Thanks.
I don't have an exact answer but it has to be at least 20 lbs. Tom said the Sportster CS is 33 pounds with brackets and the OEM is probably 60+ lbs. The E46 seats were 65 lbs with power, heat, and memory.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R
dozaiya236.00
      01-17-2013, 12:31 PM   #14
mattgold
Drives: Vroom
Recaro CS with bases, sliders and seat belt receiver are 39lbs each. I just threw mine on the scale.
...and they just happen to be for sale here:
http://www.m3post.com/forums/showthread.php?t=780970
(shameless plug)
-M
      01-20-2013, 10:48 AM   #15
radiantm3
Apex Everything!
radiantm3's Avatar
Drives: 2007 Honda S2000, 2017 GT350
2011 E92 M3  [9.35]
2014 BMW i3  [10.00]
Do the sportster cs' provide more lateral support over OEM? I want lighter, more supportive seats for the track but I need to be able to add remove a child seat in the back when I'm not at the track. Any advice?
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com
      01-20-2013, 11:09 AM   #16
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
this sir is why they invented the e90 m3.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      01-20-2013, 11:33 AM   #17
jonasaurus
jonasaurus's Avatar
Drives: E90 M3 [Sold]
I found them to be a big improvement over the OEM seats, I'd probably attribute some of that to the Alcantara as well. Brief moments on the track of wanting more lateral support on very tight corners but otherwise no complaints.
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
      01-30-2013, 05:40 PM   #18
M3PO
M3PO's Avatar
84
Drives: '08 IB E92
Yes.
      04-17-2013, 11:24 AM   #19
nitroho
Drives: 2012 BMW M3 AW
Hi everyone , quick question for anyone who knows. Do you know where I can get the seat railings for the recaro sportster cs to fit in the e92 m3? I've had these seats for about 2 months now and can't seem to locate these dam items so I'm stuck with the seats still in the boxes and not where it should be, in my car.
2012 Bmw M3 Aw
2012 landrover Evoque
2012 Acura Tl
2010 Mazda 3
      04-17-2013, 11:33 AM   #20
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
We've got everything you need. In stock.
      08-27-2013, 07:59 PM   #21
AWM3ME2
Keep practicing your almost there....
AWM3ME2's Avatar
34
Drives: E92 M3
Do you have anything that can adjust the height? They seem to sit too low.
      03-12-2021, 08:42 PM   #22
cvstar9M3
cvstar9M3's Avatar
Drives: 2011 MR e90ZCP 6-MT
7+ years thread revival: is the Recaro PP way better in terms of lateral support than CS? I got an e90 that is mostly daily driven (more so 2nd car than daily) but some track days. I want to change my seats. I'm about 5'9 175-80 lbs tops and pretty fit. Which one would y'all recommend? I also want to retain may seat heating functionality. Should I look in other brands? Thank you
2011 MR e90ZCP, 6-mt
2011.75 e90 M3 ZCP, DCT, ZP2, ZCV, JB w/ 2Toned FoxRed/Black Interior - SOLD
m3post
