F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Brakes buying decision helper: "Factory", "M Sport Brakes", "M Performance Brakes"
GetBMWParts
      02-20-2016, 03:51 PM   #89
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
Originally Posted by kemiksiz View Post
Hi Ocean,
One more question please,
I'll change the front M sport rotors & calipers instead of basic setup o Monday So since its only the fronts, should I code them ?
OR I'll be fine untill I upgrade the rears?
Thnks a lot'!
Sorry can't tell you what the BMW recommendation would be for that setup (if there would be one, which I assume that there is no recommendation)
If you put the 370 rotors in front, I assume coding would be indicated, even if the rear brakes stay OEM. But again, just my guess.
Just test drive after proper brake bleeding and see if the brake balance is good. If you have easy access to coding, you could try one and other setting and see what works better.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
      02-21-2016, 09:32 AM   #90
kemiksiz
kemiksiz's Avatar
Turkey
380
Thnks a lot, so the worst scenario will be a mushy brake pedal?
Any chance not to brake and hit ?
      02-21-2016, 04:43 PM   #91
oceanview
oceanview's Avatar
Switzerland
207
I belive, that coding the M Sport Brakes will reduce the brake power.
So pushing the pedal down with the same pressure, will make less pressure arriving at the brakes than with smaller sized brakes. (At least that's what I read somewhere in here)
The logic behind that is, that otherwise the big rotor brakes would constantly be "over reacting" when slightly pushing the brake pedal.
      02-22-2016, 06:27 AM   #92
kemiksiz
kemiksiz's Avatar
Turkey
380
Thnks a lot
I have done it, without coding, today. The pedal is very slightly softer than before and I really can not feel the BRAKE UPGRADE here for sure I did not tryi it on high speeds yet as full braking. I'll pst when I ddid it.
But I'll remain uncoded right now untill I have the rear m sport 2 pots.
G20 to G80 M3 Conversion
Instagram: @sertackemiksiz (95K)
Youtube: Sertac Kemiksiz (126K)
      02-22-2016, 12:39 PM   #93
oceanview
oceanview's Avatar
Switzerland
207
Well it has often been discussed, that some of the users think the brake pedal is to soft even with the new M Performance Brakes. This is caused by the brake pads. I read, that some users changed from the M Performance Brake pads to the regular one.
This Pad
http://www.realoem.com/bmw/enUS/part...&q=34116859066
is said to have a soft initial bite
http://www.realoem.com/bmw/enUS/part...&q=34116865460
is said to have a stronger initial bite
      02-22-2016, 06:12 PM   #94
yoandry
yoandry's Avatar
693
Drives: G80 M3CX & X5 M50i
I installed the M Performance one today and yes, it is kind off soft than my silver M Sport. So you are saying that is the pad type? Can my old pads fit the front one? I had one piston crapy caliper in the rear before, don't think the pads will fit the 2 piston m performance one.
      02-23-2016, 01:24 PM   #95
oceanview
oceanview's Avatar
Switzerland
207
Looks nice
The front brake pad of the 4 caliper brake with 340mm rotor (OEM on 335i or S2NHA Option with 340mm rotor) will also fit into the 4 caliper M Performance brake with 370mm rotor.
Brake pad for rear brakes are different.
EDWYER1674.00
      02-23-2016, 02:33 PM   #96
yoandry
yoandry's Avatar
693
Looks nice
Seems like the soft pedal in the MPBBk also can be address with coding
      02-23-2016, 03:50 PM   #97
ShawnOST
ShawnOST's Avatar
Drives: 2017 M3 Competition
I am looking to make the same upgrade on my "new to me" 2013 328i Sport Line. Love the silver and yellow caliper.
      03-10-2016, 10:06 AM   #98
ShawnOST
ShawnOST's Avatar
Just purchased yellow BBK and 403M wheels from Steelerfan. BBK being installed today. Can't wait...
      03-15-2016, 01:29 PM   #99
ShawnOST
ShawnOST's Avatar
Thumbs up
A couple of quick pictures after the install. Now just have to get the new wheels on this coming weekend. After reading up on the experiences of a few others, I may need to go back to the dealership and ask them to code the brakes, they're feeling a bit too mushy...
      03-16-2016, 11:53 AM   #100
Tsilly
Tsilly's Avatar
Drives: F30 328i Jet Black
Looks Good!! Wheels will make it look even better
      03-19-2016, 05:28 PM   #101
oceanview
oceanview's Avatar
Switzerland
207
indeed! Wheels can make the difference :-)
      03-24-2016, 02:50 AM   #102
boosted43
boosted43's Avatar
Drives: 2017 C43 AMG
2015 BMW 335i  [0.00]
Just so I understand clearly, the only difference between the 335i M-Sport Brakes and the M-performance Brakes are the rotors? The M-Performance Brakes have Dimpled and Slotted Rotors and the M-Sport Variant does not? The calipers and pistons are the same (aside from the colors)?
      03-24-2016, 04:04 AM   #103
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Correct
      03-31-2016, 01:31 PM   #104
Versipellis
Drives: '17 F36 440i xDrive M-Sport
Wasn't the supposed "Advantages" of slotted and drilled rotors debunked as a myth in anything that isn't a proper track car?
2017 440i Gran Coupe xDrive MPPSK M-Sport Estoril Blue II w/ Individual Golden Brown Full Merino & Fineline Anthracite Wood
Track Handling + Premium + Cold Weather + Technology + Driver Assistance Packages
      04-01-2016, 06:15 AM   #105
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
No the mp rotors are much lighter for a start
      04-01-2016, 09:05 AM   #106
yoandry
yoandry's Avatar
693
They look good, help with the heat/performance under different weather conditions and comes with the kit at least the fronts. BUT they also make noise as they are dippled/slotted when air is passing through. It is just notice driving with the windows down and close to walls or medians.
      04-01-2016, 09:55 AM   #107
rwalker
Drives: the wheels off
did you weigh yours?
my brand new 370x30mm rotors weigh 26.4lbs (12kg)
      04-01-2016, 01:19 PM   #108
Versipellis
I'm not talking about the MPerf rotors - I'm referring to dimpled and slotted rotors in general.
Is there evidence for this for normal street driving (aka outside of track use)?
      04-01-2016, 05:30 PM   #109
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
No but holding plain 340mm rotors in one hand and the MP 370mm rotor in the other, they "felt" same/ similar in weight.
      04-01-2016, 05:32 PM   #110
rwalker
bah! banned until you weigh one
f30post
