BMW M3 Forum (E90 E92)
BPM
      05-01-2011, 08:23 PM   #23
ttt
Drives: n/a
Originally Posted by xchosun1x View Post
Cut a shop towel to cover enough of the filler cap. Over the towel on top of the cap and zip tie the towel around the base of the cap. The towel will absorb the overflowing fluids
Do you keep a towel there all the time? Or do you remove it right after a track day? Is there any potential harm if the towel is left there?
      05-01-2011, 08:25 PM   #24
xchosun1x
Track Duty
xchosun1x's Avatar
Drives: Track build 08 E92 M3 DCT
keep it there =)
      05-01-2011, 08:38 PM   #25
leo95se
Drives: '09 e92 M3, '15 F15 X5d
~15 track days in; zero issues. (10k miles on the car)
      05-01-2011, 09:16 PM   #26
I M STIG
RawAutos.com
I M STIG's Avatar
Drives: 2009 E90 M3
I'm so glad someone started this thread. I've been looking at doing a track day come summer time with my car, but wasn't sure of any issues to look out for. My car has 35,xxx miles on it and hasn't been tracked, as far as I know.
2009 E90 M3| Jerez Black | Extended Silver Novillo with Brushed Aluminum | 6MT | EDC | Premium Package II | Convenience Package | Enhanced Premium Sound | HD Radio | Heated front seats | Fold down rear seats | Moonroof | 19" wheels |
RawAutos.com
      05-02-2011, 09:22 AM   #27
saildoc
saildoc's Avatar
41
Drives: 2012 Porsche Cayman R
No issues but getting a track only car now...
I have four track sessions under my belt. I bought carbotech pads which held up beautifully in the very track temps and never had to slow down for fade, they are really noisey on the street. My Yoko Neova AD08's put the power down and held up great. No mechanical issues and I want to keep it that way thus I am getting spec Boxster for track fun. I will feel way better with a 6 point harness and a full cage to keep me intact if something bad happens.
      05-02-2011, 05:10 PM   #28
persian54
persian54's Avatar
Drives: M760/G83M4
Show me at Streets.
I didn't notice a leak in mine
      05-02-2011, 08:52 PM   #29
dawgdog
Drives: 2015 M3, 2016 GT3
I have about 25 track days and 30,000 miles and other than the power steering fluid overflow issue everything is fine. I have been happy with the AP brakes other than going through pads fast - I'm still using the Mintex Extreme pads.
2015 f80 M3, 2016 GT3
      05-09-2011, 01:29 PM   #30
mdosu
Drives: Double Vanos'd Civic-M3
why does the power steering fluid leak? Where is it leaking from? It appears it's a "spill" rather than a "leak" (i know semantics) Is this a big deal or not?
Can someone take a pic of the zip tie/ shop towel fix?
thanks, looking to track it for the first time this summer, I want to make sure I'm monitoring all potential wear items properly.
      05-31-2011, 04:44 PM   #31
mpm3
mpm3's Avatar
Drives: 2007 M coupe
2007 BMW M coupe  [10.00]
2011 BMW M3  [0.00]
yes someone plz take a pic i have a track dday coming up wanna be prep
      06-01-2011, 06:49 PM   #32
OC3
Havin' a blast!
OC3's Avatar
Drives: 2013 M3 E92 Jerez Blk DCT ZCP
http://www.m3post.com/forums/showthread.php?t=278495
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
      06-29-2011, 10:53 AM   #33
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
Part number 1 in this diagram is the power steering fluid reservoir. It can be found in the engine bay on the passenger side, just in front of the coolant expansion tank. When the power steering fluid gets hot, it can seep out of the reservoir cap.
What xchosun1x is suggesting is that if you tie a shop towel around the filler cap area, it can absorb seeping fluid and keep the bay a bit cleaner.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      08-15-2011, 07:52 PM   #34
M3 Montreal
Drives: 2012 M3 SG ,DCT & 2011 S4
Originally Posted by Martin_D View Post
It is the brake boost assist. This happens to fast drivers in the E9X M3. The system pulls vacuum from anywhere it can and you get an inconsistent pedal.
AE performance is working on a fix for this. It happened plenty of times in my car, happens with their car as well. Anyone driving fast knows about this.
So whatès the fix for this...
Im pretty sure I experienced this on hard braking last week and I was wondering if my brake fluid was not properly bled.
2012 E92-M3 Space Grey on Fox Red, DCT
2011 B8 S4 S-Tronic , Black on magma red
      08-28-2011, 12:20 AM   #35
wwjd15
Drives: 11 E92 M3 MR
Hmm, this happened to me again last weekend at Fontana. Anyone has solution for it?
      08-28-2011, 02:33 AM   #36
rzm3
rzm3's Avatar
673
Drives: E92 M3
      09-06-2011, 10:33 AM   #37
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
120 autocross laps and 22,000 miles, with stock brakes:
Power steering: No leak.
Brakes: No problems, but will go to a street/performance pad next season in hopes of gaining a little more initial bite.
Engine: No issues.
Bushings & Subframe: No issue. However, I'll be putting the 'vert rear sway bar on my coupe over the winter and I plan to replace bushings while the subframe is dropped.
I've autocrossed various cars for decades and never had a "failure" or problem related to AXing the cars, other than accelerated tire wear.
Dave
      09-06-2011, 10:50 AM   #38
Martin_D
Martin_D's Avatar
Drives: Ford Super Duty
contact casey at ae performance
when you are FAST in the M3 this happens all the time...
      09-06-2011, 11:53 AM   #39
montreal red
chris
montreal red's Avatar
Drives: White Boat
13 track days this year (3rd year of ownership). did a lot less track days in my first two years of ownership.
power steering fluid needs to be topped up from time to time. usually check this every 3 or 4 track days.
engine temps get a little warm on the track but never went into limp mode.
changed oem brakes to stoptech BBK this year. running stoptech's oem street performance pads and Ate Blue fluid. have no complaints with this set up so far... seems like the street performance pads are sufficient for my skills at this point in time.
i usually need to add 0.5 qrts of oil in between oil changes. nothing too serious.
getting another set of dedicated track rims next year, probably the ARC-8s
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      09-06-2011, 01:27 PM   #40
MaxL
Drives: E90 M3, Cayenne T, 991 GT3
Originally Posted by mastek View Post
Then I guess Im going slow -- cause Ive not had this issue -- but good to know that there IS an issue with the brake boost
I guess it is track-dependent - I had it on WGI, was exactly as others described, but never had it on Mosport, and I drive at Mosport much harder with more pad wear (home track). I thought I boiled fresh Castrol SRF at WGI, but brake flush shown no signs of anything wrong with the fluid - looked like new, no air.
So what's up with the fix?
On the topic - tracking the car from time to time over 2 seasons with absolutely no issues other than spilling over power steering fluid and the brake issue mentioned before (but that does not happen outside of the track). It's a very robust car!
      09-06-2011, 05:21 PM   #41
Martin_D
Martin_D's Avatar
You'd have to call Casey at AE Performance and ask him what they did for the race car. The brake boost assist system pulls vacuum when you exceed a certain level resulting in an inconsistent pedal. They were working on delete and do not know at this point if they finished with it.
At VIR it happened a lot, high speed 145+ ...
      09-09-2011, 12:11 PM   #42
Dodge2Dub
Drives: E90 M3; Ducati
Not a big deal. The system is designed to do this. If you look at your Power Steering cap, you will see a small pin size hole. The "leak" exits from the hole when the fluid overheats. Another quick fix that I've seen a couple of times is to put a sweat band around the cap (motorcycle brake reservoir style).
E90 M3: Some cool stuff...more to come
Ducati 1199 Panigale: Bucket full of mods
      09-09-2011, 12:15 PM   #43
Dodge2Dub
Originally Posted by RickyBobby View Post
Brakes: I've gotten them nice and toasty but they are still working for me with proper pads, ss lines and titanium backing plates.
Which Ti plates and pads are you using? Have you seen any trouble with the track pads causing undue wear on the OEM rotors?
At some point soon, I'm planning to upgrade to Motul 5.1 and Goodrich ss lines. I've also run Hawk HP+ pads in the past successfully, but still want to know what you guys suggest for the track (I assume that you use the stock pads for the street).
      09-13-2011, 11:55 PM   #44
rzm3
rzm3's Avatar
673
Drives: E92 M3
Had my right rear wheel bearing replaced a few weeks back as it was making a loud clicking noise.
m3post
