BMW M3 Forum (E90 E92)
EXXEL Distributions
      01-21-2024, 11:44 AM   #23
M3SQRD
M3SQRD's Avatar
2161
Drives: E92 M3,G20 330ix,F22 240iX,F82
Originally Posted by bigjae1976 View Post
Something I found is that the material can make a big difference. I went from a plywood to a carbon splitter, both were the exact same size with the same mounting. The carbon splitter changed the balance from understeer to oversteer.
This suggests the increase in aero efficiency of the front CF splitter moved the COP forward of the COG. Does the CF version have a better leading edge radius than the plywood version?
      01-21-2024, 12:39 PM   #24
bigjae1976
bigjae1976's Avatar
1571
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Similar. Easier on the plywood with a router vs trying to chamfer foam.
It had to do with the stiffness. The plywood would cause the front of the car to porpoise at 140mph (quite scary) because the plywood would flutter.
I’m sure the front of the plywood splitter would be pushed down at speed instead of the front end.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      01-21-2024, 01:06 PM   #25
M3SQRD
M3SQRD's Avatar
2161
WOW! That does sound scary! How did you determine it was the plywood vibrating at 140 mph and causing the porpoising? Could you hear it?
      01-21-2024, 01:08 PM   #26
bigjae1976
bigjae1976's Avatar
1571
2004 BMW M3  [4.50]
It was insane. The bouncing was so bad that the splitter was really the only plausible thing it could be.
      01-21-2024, 01:18 PM   #27
M3SQRD
M3SQRD's Avatar
2161
That would have resulted in a major shunt if that thing had failed mid-corner!
      01-26-2024, 07:44 PM   #28
nickauger
Drives: m3 e90
Just My 2cent but i ve run an e90 without aero and was getting 220kmh in the stretch, after gt4 lip and apr gt250 61" i'm now getting between 210 and 212 on same stretch but feeling more confident in high speed curve get me better lap time.
m3post
