02-01-2023, 10:13 PM | #45 |
Rep 8,077
Drives: 11 E90 M3 Individual
I think this is V4…it has a 4mm thick core and extra reinforcement between the bolt holes. Weighs 4.6lbs and is about the same stiffness at V2 and V3.
So I’m happy with the results. So the V4 plate is for sale. $780 shipped within the US. Next up, carbon engine screening panel - those stupid felt panels that always get torn up. This will be a challenge!
2018 F30 320iX Melbourne Red
02-01-2023, 10:19 PM | #46 | |
Rep 8,077
If you’re wondering, most “carbon fiber” parts are not carbon fiber. Seibon and VRS make parts using fiberglass chop mat and polyester resin and then put one thin layer of carbon fiber on top. Long story, got this VRS hood for my E46 M3 cheap but it was much heavier than the OE part. Still weighs 24lbs all cut up like it is. As you can see it is clearly super cheap fiberglass chop mat. The giveaway is the black gel coat on the side lip. An E46 hood needs a 52” wide cloth. Most carbon fiber cloth comes in 50” wide roll. 60” wide rolls are expensive and hard to find.
02-01-2023, 10:21 PM | #47 |
Rep 8,077
I have one available. $780 shipped.
DrFerry6731.50 |
02-02-2023, 06:45 PM | #48 |
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
What's the weight on the stock plate?
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
02-02-2023, 06:55 PM | #49 |
Rep 8,077
02-02-2023, 07:03 PM | #50 |
Rep 2,527
I want to see if this will work with my car and if it does (given my flatbottom attempts) I'm in. A pound's a pound and I would like to subscribe to your newsletter.
02-02-2023, 09:28 PM | #51 |
Boost
1355
Rep 3,695
Drives: 135i M-Sport
You would make a killing selling a slightly more aggressive "GT4+ sized" splitter that extends back to these OEM subframe pickup points with integrated diffusers haha or maybe that's just what I want... incredible work, I really want to get into vacuum curing CF stuff. Any vendors you suggest?
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
02-02-2023, 09:35 PM | #52 |
Rep 3,996
A cf skid plate shaped a bit like the mtl one would be pretty awesome.
If shaped like OEM felt ones they would just get torn up the same. |
bigjae19761580.00 DrFerry6731.50 |
02-02-2023, 09:47 PM | #53 | |
Rep 8,077
You mean a GT4 lip that bolts into the front subframe? That should not be too difficult to make. You’d probably want to separate the lip from the splitter in case you damage or lose the splitter…then you don’t lose the entire assembly. I have been brainstorming the idea of integrating mounting points for a splitter into the reinforcement plate and a easy to remove front bumper mounting. I should have my E92 M3 with a blown motor at my house in Mar/Apr so I can start playing with it.
02-02-2023, 09:54 PM | #54 | |
Rep 8,077
I have a plan 😉 I’m not going to pull a mold from the OE part. The felt makes it a challenge since I’d have to ruin the part. I will hopefully have something made by mid March.
02-03-2023, 08:10 AM | #55 | |
Rep 3,996
DrFerry6731.50 bigjae19761580.00 |
09-23-2023, 10:02 AM | #57 |
Rep 8,077
A new job slowed things down and this TX heat has put a stop to things. Hopefully I can get fired back up soon. Hard to work when resin and epoxy start to gel up after 10 minutes.
roastbeef11591.50 |
10-09-2023, 08:45 PM | #58 |
Rep 82
I'm in.
CF Front lip//Cyba Scoops//K&N filter//Charcoal delete//UPSolute tune//Full LED swap//CF roof spoiler//Monaco blue boot lid//muffler delete//Blacklines//15% tint//Rear fogs// |
11-16-2023, 08:19 PM | #60 |
Rep 8,077
Working on my carbon E46 hood. The engine covers is next up.
DrFerry6731.50 |
12-02-2023, 10:37 AM | #61 |
Rep 8,077
At this point, if anyone wants a CF plate just PM me. It’s $780 shipped.
In case anyone cares…Working on the felt cover replacement. So I’m changing direction on this. I had a Turner front plate that I could pull a mold from. I’m thinking it would be a dick move to pull an exact copy of it. I’d be more OK if could make substantial changes but I don’t really see any way I can do something tk make it better. I think the OE part would have better air extraction out of the slot for the oil cooler exit. I’m confident I can make the end parts studier so they last longer. Also I should be able to keep the cost relatively low. I think I can make a carbon part that costs about the same or a little less than an OE replacement . I’m working through the hurdle of making the mold.
12-02-2023, 01:26 PM | #62 |
Rep 2,871
I am interested in your complete solution for both. I have the Zeb splitter on the front and wouldn’t mind those two parts that were designed with the splitter in mind.
12-10-2023, 10:55 AM | #63 | |
Rep 2,072
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
12-10-2023, 04:25 PM | #64 | |
Rep 8,077
Cooling is less about core size and more about the air pressure differential front and back. I’m pretty sure BMW optimized the low pressure area behind the cooler which would significantly improve cooling.
01-30-2024, 03:26 PM | #66 |
Rep 8,077
Another one done
Working on the stupid felt covers that go in front of the plate. These end parts are going on my car. I have a test dummy lined up for the first part that’s not made of random scraps of carbon. I’m still trying to figure out the gurney flap on the vent, that’s been the painful part in all of this. Thought I could make the vent separately. I might just make a flat piece and bond it on. This should be way more durable than the OE part - which is flocked cardboard - and I might be able to price them cheaper than the OE part.
DrFerry6731.50 CamasM3e933222.50 |
