BMW M3 Forum (E90 E92)
EXXEL Distributions
      05-17-2020, 08:45 AM   #89
rhyary
rhyary's Avatar
Drives: 2013 M3
G-Sum comparison between 1:35.7 R7 and FFI500. The rears were not the same, but I think the main diff is the front.
      05-17-2020, 08:57 AM   #90
rhyary
rhyary's Avatar
Drives: 2013 M3
Adding steering angle to the Measures Graph shows the superiority of the R7.
You can see that the FFI500 (blue) takes more steering angle to generate less g-sum.
This is way playing with the throttle and steering angle helped rather that a smoother input on the R7:
      05-17-2020, 05:20 PM   #91
rhyary
rhyary's Avatar
Drives: 2013 M3
Wear was good.
but look at the inside of the FFI500
      05-17-2020, 06:40 PM   #92
tsk94
tsk94's Avatar
Drives: E92 M3, E82 128i, F82 M4, E36
Originally Posted by rhyary View Post
Wear was good.
I might have missed it, but what are your overall impressions and thoughts for the FFI500 for a budget track tire?
      05-17-2020, 07:08 PM   #93
rhyary
rhyary's Avatar
Drives: 2013 M3
Wear was good.
This is only for track, no idea for road/daily usage.
Cheap $215 for 275/30/19 on tire rack
Loud on the turn
Good wear (must be hard rubber)
Predictable. No issue about wondering what it is going to do
About 2 sec slower than MP4S, ADOR8, R888R
However, all tires mentioned here were in a different suspension setup.
Next trackday I will be on front MPScup2 265/35/19 and same setup. We will see the diff then between 180 track tire and general 340 performance tire.
tsk941522.00
      05-17-2020, 07:55 PM   #94
Grillpt
Drives: E92 M3
Was this the first time out on that suspension? U said all other tires were on a different setup..
I'd be seriously worried if i saw that kind of devastation to one of my tires. That's scary man! I wouldn't just brush that off.. Tires don't chunk on the sidewall from heat
      05-17-2020, 08:07 PM   #95
Grillpt
Drives: E92 M3
Looking at the pictures again, looks like the inside is cracked almost all the way around. I've never seen a tire destroy itself that way, but it's clear u overdrove the ish out of it
Honestly makes me angry as an instructor
      05-17-2020, 09:03 PM   #96
Bartledoo
Driver
Bartledoo's Avatar
2692
Drives: 2011 E90 M3 6MT
"Wear was good"?!!!!! Doesn't seem like it!
E90M 6MT Slicktop Single Humper in need of a diet
      05-17-2020, 09:12 PM   #97
rhyary
rhyary's Avatar
Drives: 2013 M3
i have documented this year changes already
      05-17-2020, 09:13 PM   #98
rhyary
rhyary's Avatar
Drives: 2013 M3
I like to get my money worth out of my tires
      05-17-2020, 09:17 PM   #99
rhyary
rhyary's Avatar
Drives: 2013 M3
Meaning I did not cord the outside.
I only saw the inside when I got home and took the wheels off.
This was a 2015 tire. perhaps it was too old
      05-18-2020, 10:27 AM   #100
Kelse92
Drives: Former e92 M3 Owner
Ohh yeah, that'll do it, old tire probably dry-rotted some. Plus, maybe a little rubbing going on with the spring perch?
Tread does look good though, I have heard they do get pretty decent wear. Bummer on the sidewalls
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads
      05-18-2020, 12:34 PM   #101
rhyary
rhyary's Avatar
Drives: 2013 M3
No rubbing.
Tires did its job. I got 1:40.x, 13x20min sessions at full speed, no traffic. and got home to enjoy another day.
Really can't ask for more.
There was no visible dry rot, but then again, look at the picture :-)
      05-19-2020, 04:57 AM   #102
WhiteM3EMC
WhiteM3EMC's Avatar
116
Drives: 2011 White M3 DCT
I ran 275 square FFI500 on my last car, and I was extremely happy with them. Very cheap, great wear, decent grip for the price point and wear. I'm on faster tires in the M3 now, but I thought the FFI500 was a great dual duty tire. Zero inner sidewall issues with mine, but they were newer.
      05-19-2020, 05:36 AM   #103
rhyary
rhyary's Avatar
Drives: 2013 M3
Good to know.
I have another set for the front and plan to run them later in the year
      05-19-2020, 07:36 AM   #104
WhiteM3EMC
WhiteM3EMC's Avatar
116
Good to know.
Of note, this was on a 4500lb Dodge Charger (yeah I know, I had to have a boating license to operate it on track)
With stock camber and that much weight, the lack of outer shoulder wear was fantastic. After one session, they would get nice and tacky and pick up dirt and pebbles in the paddock. Within 10 road miles they would smooth back over.
I would have zero hesitation of running them again for lapping if I wasn't trying to be competitive in TT at some point.
      05-19-2020, 07:50 AM   #105
rhyary
rhyary's Avatar
Drives: 2013 M3
Good to know.
You are making good point and I second your opinion. 1:40 at NYST is a respectable time for a 3400Lbs car. The hard rubber on the FFI500 wear out very well and I was able to finish two days which I was not able to do on many other tires.
So this is the point, if you are NOT trying to do your best time, these are good, inexpensive option.
The fact that you did not eat up the outside of your sidewall and were on a stock camber is related to traction. If the tire can't generate enough grip, it will slide before it goes over. It also related to your pace. a 275/30/19 MPS4S did great using -2.5 camber on 1:42-1:44 lap time. Wear was even and all looked honky dory. Totally different wear pattern on 1:38. The outside was destroyed. The MP4S has enough grip to role over on the side wall.
As a reference, my time in Hoosier R7 is 1:35.7 and that is yet another level of grip
      05-19-2020, 08:57 AM   #106
WhiteM3EMC
WhiteM3EMC's Avatar
116
Good point. With that much weight, the car certainly liked to understeer. I was running good pace in the car but at the point where you're dragging 4500lbs around a track, you can only go so fast. My first time at the same track in the M3 on NT01s (with PFC front BBK, so a bit of a skewed result) I was 3 seconds faster. Weekend got cut short by some mechanical problems so I didn't get a chance to see if I could push that to 5 seconds or so gap.
      05-21-2020, 07:00 AM   #107
rhyary
rhyary's Avatar
Drives: 2013 M3
Beatiful day at NYST today.
Here is the 1:31 Corvette. He is going for the Viper record of 1:28.
According to the driver this is no excuse Corvette. If he does not do 1:28, he says it is on him.
315 Hossies on the front. One can only dream...
      05-21-2020, 07:04 AM   #108
rhyary
rhyary's Avatar
Drives: 2013 M3
Beautiful GTR with R888R 285 front 315 rear
He says he is lucky to get one day on the fronts at NYST.
His best time is 1:37.
      05-21-2020, 07:21 AM   #109
rhyary
rhyary's Avatar
Drives: 2013 M3
We got GT2 RS, the new Corvette, R8, GT3, GT3 RS and bunch of exotics. This is going to be a fun day.
      05-21-2020, 07:49 AM   #110
WhiteM3EMC
WhiteM3EMC's Avatar
116
Thats a gorgeous lineup!
m3post
