05-13-2023, 01:29 AM | #1 |
Rep 240
G20 M340I Brake Fluid
Hello, does anybody have links/recommendations for the brake fluid on a G20 M340I? Original part # or anything superior (Motul/Liquomoly/etc.) would be helpful! Thank you!
05-13-2023, 06:04 PM | #2 |
Rep 1,150
Drives: 2022 M340i Mineral Grey
For street/track, I’ve used Motul RBF660.
Present: 2022 M340i Mineral Grey
Past: 2019 330i, 2012 Evo X GSR |
05-15-2023, 03:13 AM | #3 |
Rep 240
05-15-2023, 08:07 AM | #4 | |
Rep 1,150
I don’t know how much fluid, sorry. Shop did my flush.
06-01-2023, 05:46 PM | #5 |
Rep 222
Drives: '20 M340iX
These cars are spec’d for “low viscosity” fluid. Supposed to be more ABS friendly and what-not. I’m sure there’s some truth to that but I don’t know if normal viscosity would create any problems in emergency situations. I’ve personally run Torque 700 in my car and it works just fine. But no true emergency situations have occurred yet so time will tell. Btw… I believe Pentosin makes the OE stuff. Just go to Rock Auto and put in your vehicle info and it’ll come up with what you need.
06-19-2023, 09:45 PM | #6 | |
Rep 240
06-19-2023, 11:50 PM | #7 | |
Rep 222
Drives: '20 M340iX
02-09-2024, 04:13 PM | #8 |
Rep 196
How much fluid do we use in the M340? I think it's around one liter, but I'm going to be moving to a more expensive fluid (Endless RF-650 most likely) and I don't want to buy an extra 500 ml (1.5L in total) and only use a bit of it when I do my flush. Sounds like based on the above, we use around 2.5 500 ml bottles, so I may be out of luck.
02-10-2024, 04:07 PM | #9 |
Rep 95
Drives: 2020 BMW m340i xDrive (Alpine)
Pentosin
I flushed mine a couple of weeks ago, and I used the Pentosin DOT 4 LV. I used 1L, but I was very close to running out. So I would recommend gettin more than 1L for a good solid flush, but you can make it work with 1L. Here is a link to the kit I bought from FCP Euro - highly recommend.
