BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
European Auto Source (EAS)
      02-12-2024, 11:13 AM   #1
FrznM3
Drives: E92 M3
Good morning, I have a 2013 E92 Comp M3. About 2 years ago I swapped my stock wheels out with Apex Arc8s. The tire/rim combo was slightly smaller than the stock comps and threw my speedometer off. I messed with my coding values to get it accurate and forgot about it until today when I put the car back to stock. I don’t have the old android phone with the backup (does bimmercode save backups to the cloud?).
Could anyone provide a stock file for me? And how would I go about flashing a stock file to the car? I’ve only ever messed around with bimmercode.
      02-12-2024, 04:22 PM   #2
tdott
Drives: M3
Look up how to factory code the module.
Standard procedure when making VO changes. You don't need a "Factory coding" file.
DrFerry6731.50
      02-12-2024, 07:47 PM   #3
FrznM3
Drives: E92 M3
So when bimmercode asks to make a backup before flashing that’s just their extra precaution? Any more not matter how coded can be restored back to factory without a backed up file?
      02-12-2024, 07:57 PM   #4
tdott
Drives: M3
Sorry missed the Bimmercode part. You'll need NCS expert on a computer.
DrFerry6731.50
      02-13-2024, 12:13 PM   #5
omgzirra_exe
omgzirra_exe's Avatar
Drives: 4.4L M3, IS300
pro-tools can read the VO and default the cars coding as well.
Build: ZillaSpec M3 N1 Build
M3Post Track General Discussion: Discord
#fakeGTS
tdott3956.00
DrFerry6731.50
      02-17-2024, 02:58 PM   #6
yardbro
yardbro's Avatar
Drives: E92 M3, E39 528i
2008 BMW M3 E92  [5.00]
You'll need to know which module(s) bimmercode made these changes to. I have never used this app before so i'm not sure if it specifically states which module you are currently editing.
If you use NCSExpert on your computer you will be able to restore factory coding values for a specific module based on your VO by having a blank MAN file. Depending on your NCS installation you can also just use the "Factory Coding" profile if you have it, but i'm pretty sure that even in "Expert Mode" the blank MAN file will force it to write default values as well.
DrFerry6731.50
m3post
