01-11-2014, 06:46 PM | #45 | |
Rep 1,364
01-11-2014, 06:59 PM | #47 | ||
Diamond Geezer
214
Rep 2,385
Drives: Jet Black 2007 328i Saloon
That said, very satisfied with the inserts. More rear stability and no NVH compromise for me. In fact, they've reduced a drivetrain NVH issue on my car. |
02-09-2014, 10:16 AM | #48 |
Rep 337
Has anyone noticed that the wiggle has come back when hitting larger bumps? I have noticed that the rear is not as planted as before. I checked the 16mm bolts again and they are all snug. This feels more like the way the car felt stock. Not as bad but not as good as when I first installed them.
02-20-2014, 04:41 AM | #49 |
Rep 52
I can't say I have noticed any loss in body control since installing the inserts a couple of months back, although your post has made me think I should re-check the subframe bolts for tightness.
Perhaps you need the M3 bushings if you feel the inserts are going, ahem, soft? |
02-24-2014, 06:34 AM | #50 |
Rep 615
Drives: BMW 120d e82 M Sportpaket
Any idea if the inserts increase the high of the rear suspension or subframe ?
Thanks in advance mates
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ... French community of 1 and 2 Series: One-Two-Bimmers |
02-24-2014, 05:19 PM | #51 |
Rep 1,051
I don't believe so. The upper mounts do not interfere with the vertical positioning of the subframe. The inner metal collar (where the bolt goes) of the stock bushings still makes direct contact with the body of the car. I didn't get a great shot of it, but it is apparent when you lower the subframe. There is a shiny spot on the body frame and inner bushing where you can see no dirt has been present. The upper inserts do not cover this area.
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
02-26-2014, 03:12 AM | #53 |
Rep 615
Thanks for the inputs guys So for those who want to mount some subframe inserts, they don't have to worry : they don't change the highness of the rear axle !
02-26-2014, 10:20 PM | #54 |
Rep 760
Drives: E82 135i & F80 M3
Yes, thank you everyone for your input and to the original poster of this thread.
I ordered a set, and they will arrive Friday. Talk about fast shipping! Very excited to install these over the weekend. |
03-09-2014, 10:14 AM | #55 |
Rep 1,051
I don't believe so. Judging by how light they are and appearance I think the bolts are aluminum or magnesium alloy, which I don't believe are suitable for torque-to-yield.
03-12-2014, 02:20 AM | #56 |
Rep 52
I wondered the same after installing Whiteline inserts a couple of months back. To reassure myself, I re-torqued the subframe bolts recently to 75Nm (the lower of two settings I came across). 3 of the 4 bolts were fine, but the 4th required a very slight nip - although it may not have been as tight as the others to start with.
04-18-2014, 06:58 PM | #57 |
Rep 216
I did this today. The inserts are now black. Took 2.5 hrs, incl a drive, re-jack, and re-torque. Would have been easier with a friend. These are not like solid M3 bushings, I'm sure, but at least I don't have to FULLY drop the subframe and mess with brake lines to press/pull the bushings in and out. Wheel hop is less, straight line acceleration is... straight now. Worth the effort. I'd imagine the feel is 75% of M3 bushings, with half of the effort and cost. To really complete the "m3 bushings" package you'd probably need to replace the carrier bushings and all of the other suspension bushings also, of which there are plenty and you may as well just purchase M3 arms.
It was difficult to get my driver (US) side front back in the correct place so the bolt wouldn't cross-thread. The 18mm hex bolts were not in the same places as evidenced by the road grime ghost. I'm sure I need a minor alignment. Ozimmer, it's 100nm, so 74 ft-lbs, not 75nm. Go re-torque your bolts. I'm not sure what the hex bolts are - they are for reinforcement only anyways. Good and tight will do for those. Of course, a solid M3 bushing is better than inserts. A solid urathane would be even more stiff, solid delrin would be even harder than that, and billet aluminum would be for hardcore racers who like to break things. |
04-23-2014, 10:01 AM | #58 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
FYI, I just found the Whiteline KDT918 inserts listed for sale a few bucks cheaper by a vendor called NeverEnoughAuto. They have it listed both on Amazon and eBay. The MSRP is same as other sites but shipping is cheaper by few bucks ($5 vs $9).
http://www.amazon.com/Whiteline-KDT9...A10KPP948X9D3L |
05-23-2014, 01:24 PM | #60 |
Turbo Power
51
Rep 364
Just ordered these, will be installing them in the coming week.
Long term owners, what are your impressions after having these inserts on your car for a while now?
BSM 135i - CDV Delete | Bilstein | Eibach | M3 FSB | Whiteline
05-25-2014, 10:00 AM | #61 |
Rep 929
Yesterday I installed a set of Whiteline subframe inserts (KDT918). Thanks to Freon and others who posted instructions, photos, and torque values… I found them to be very helpful. I am extremely pleased with the results. Only one test drive so far, but initial impressions are that the rear wheels now feel much more planted and secure.
I thought I’d pass along a couple comments on the installation process: As shown in the photo, I found that the bolts attaching the diagonal subframe brace to the chassis on my car are 16mm Torx bolts, not hex bolts as others have mentioned. Good thing I had a complete set of Torx sockets! The position of the subframe and load on the various hardware can be controlled by either lifting or lowering the rear differential with your floor jack. Unless you adjust the jack to either compress or relax the rear suspension for the specific task you are trying to accomplish, you’ll be working against yourself. Here are the steps I recommend:
Here are photos of the bushings before install, before and after photos of the front and rear bushings, and a photo of the 16mm Torx bolts securing the diagonal cross braces. In the last photo (without the inserts installed), you can imaging that with the front subframe bushing lower inserts installed, the diagonal cross brace is displaced by the thickness of the insert (approximately 3/8”). I’m sure that tightening the cross brace bolts results in a fair amount of stress on the cross brace. Ideally a spacer would be fabricated to take up some of this space and reduce the amount of compression/bending load on the brace. I left it as is and tightened the bolts.
F87 '16 M2 ... Mineral Grey, 6MT, Exec, MPE Gone: E82 '13 135is 475/586 ... Mineral Grey / Oyster, DCT, Premium, Tech, HK, Michelin PSS, BMW Performance Suspension |
06-11-2014, 02:08 PM | #64 |
1Addict
3239
Rep 7,906
Finally doing this Friday. Anyone find they needed more grease than the two little packets it comes with? If so what did you use.
06-13-2014, 06:55 PM | #66 | |
1Addict
3239
Rep 7,906
On another note, went to do the install this afternoon, chocked, jacked up, secured, loaded subframe, then checked my E18 socket. 1/2" drive and I forgot! all my extensions are 3/8". Had to run to the local tool shop and grab a 1/2" -> 3/8" female adapter. Not enough sunlight left so will be doing it in the morning. Bummer.
