      04-26-2013, 07:15 AM   #67
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Originally Posted by Guam135i View Post
I tried to replace my plugs since my car has 62K miles. I bought a thin wall socket an a torque wrench to do it. However when I was removing one plug it felt like it was cross threaded coming out. finally got the plug out and threads looked okay. I tried to install the new plug and I could not get it started by hand the side of the socket was rubbing against the side of the hole. I used a ratchet to get it going but I had to stop because it felt it might cross thread and it's aluminum is this normal?
I need help
^^That doesn't sound good. I hope you have not started the engine. You might want to have a shop(dealer or indi) check that plug.
Q's.... Where did you buy your spark plug socket>? It should be a 14mm 12point - with very thin wall, design. This is why I always buy high quality tools. Even BMW dealers sell the special spark plug tool.
Where did you buy your plugs? Maybe it is what is defective. Either way... its not a good feeling when you strip the spark plug threads. Hoping for the best for you.
Dack
      04-26-2013, 11:43 AM   #68
New21er
Drives: 2011 135i
I put a little anti-seize on my new plug threads.
      04-26-2013, 02:07 PM   #69
neglectedX5
neglectedX5's Avatar
Drives: 08 135i/90 325i/02 M5/12 X5
I need help
When i changed mine they were tight until i reached the very last few threads. I put a very small drop of anti seize to help with the install and a small bit of die electric grease on the plug to prevent this...
Coil was "frozen onto the plug"
      04-26-2013, 04:11 PM   #70
GuamX1
GuamX1's Avatar
Guam
28
Drives: 08 BMW 135i, 08 128 Cab
Thanks for the responses, the socket does not go center into the hole right? I bought the socket with the plugs. Looking thru the hole thread seems okay it is just that the socket rubs at the side of the hole (towards the exhaust).
Anybody that has changed the plugs does it fell like this, does the socket go right in the center and not rub against the sides of the hole. To start it can you turn it with your hand?
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000
2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive
      04-26-2013, 04:18 PM   #71
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
My Hazet spark plug socket went right down the "hole" and did not rub.
I just measured the OD(outer diamter) of the tool/socket it is 18mm's. Use a open ended wrench to check your socket IF you do not have any calipers in mm's.
      04-26-2013, 04:50 PM   #72
GuamX1
GuamX1's Avatar
Guam
28
BMW Spark Plug Socket Thin Wall (3/8" Drive, 12 Points, 14mm)
By KOMMEN TOOLS
This is the socket I got I will go and measure the one I have
Guess what my 18 mm wrench would not fit around the socket.
      05-01-2013, 06:29 PM   #73
GuamX1
GuamX1's Avatar
Guam
28
Does that picture make sense?
      05-01-2013, 11:04 PM   #74
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
By KOMMEN TOOLS
Now you know why it was binding up down in the plug holes.
You can turn your socket down by using a grinding wheel/stone.
Name:  grinding Rotating_grinder.gif
Just put the socket on the end of an extension and keep grinding the socket until your 18mm wrench fits over it.
Or... go buy a new spark plug tool/socket from your local BMW dealer. I bet even SEARS sells the proper socket
      05-02-2013, 08:53 AM   #75
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Here are some pics of my Hazet spark plug socket 14mm 12 point 3/8th's drive, with my Hazet 18mm open ended wrench to measure the socket's O.D. ...
      05-02-2013, 07:13 PM   #76
GuamX1
GuamX1's Avatar
Guam
28
thank you very much I ordered one already from BMS. I went to the indie BMW shop and they did not even have the socket for it. I used a rubber hose attached it to the end of the spark plug and used that to guide it and start the threading it into the head a good way to avoid any cross threading
      05-09-2013, 01:14 PM   #77
ccswift
Drives: Grey 08 135i e82
Thank you! fixed my jb4 problems!
Chris
      05-13-2013, 10:54 AM   #78
MIAblu1
Drives: 08 Monaco Blue 135i
Changed my spark plugs yesterday and let me say it was by far the biggest PITA. Changing my rotors and pads were simpler. Aside from having to take apart the cabin filter and what not to make room, the actual spark plug socket was a mission to find locally. Went to 4 different auto parts stores until I finally found it at Sears and even still it was too thick which I couldn't figure out why I had the exact sized socket but still the plugs weren't coming out. It was only until I read through this thread that I learned the socket thickness is ALSO of factor. Long story short, thanks for the info guys and I'm sharing my experience simply to stress to those who want to do the work themselves, GET THE RIGHT SOCKET.
      05-13-2013, 04:37 PM   #79
MIAblu1
UPDATE... having an issue
I changed the plugs yesterday and when i first cranked the motor it sounded like a V8 with cams... turned off the car and turned on again and it was humming normally except a bit louder than usual and it was kicking out smoke from the exhaust. Finally the motor calmed like always and seemed fine. Today i headed to work and all was fine until after work when i headed home and the power wasn't there and the car threw the message of "motor malfunction" and that it was running at reduced power. Went by an auto parts store to check for codes and nothing.... with car on and off. BMW wants $135 just to hook it up to diagnose with their system....
      05-14-2013, 07:08 AM   #80
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
You need a scanner that can detect BMW specific codes, not just general OBDII codes. Some of the codes are shaddow codes and can only be read by BMW or a very good scanner like the BT (Bav Tech) cable or those coding OBDII cables with downloaded sw from the web.
I would watch that COBB video again... you probably do not have one of the coil packs connectors seated correctly or one of the coils is broken(down in the plug hole). You should inspect the old coils very carefully for any arch tracing(carbon) on the rubber stem part.
ALSO... I hope you used BMW dealer bought plugs. Some people have reported issues like this(missfires and thrown codes) with the OEM Bosch spark plugs. ALWAYS use BMW BOSCH plugs. There is a difference. And not just in the price.
Sometimes a "cheap" tool can be quite expensive at the end of the day. I always try to buy quality over price.
      05-14-2013, 09:09 AM   #81
MIAblu1
I bought the exact Bosch replacement plugs, coil packs weren't changed though, I reused the ones I had and I looked inside each when I pulled them and they all looked fine with shinny tips, no blacking. I'm going to give the motor another look over today and back track. When driving normally the car is fine, no codes, but when I give it past 1/4 throttle there's no response, it just slooowly starts to pick up and then the malfunction message is thrown.
      05-14-2013, 12:44 PM   #82
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
So you bought your spark plugs from a BMW dealer? IF the answer is No, then go buy some and try them AND report back. There is a difference between BMW Bosch plugs and Bosch(aftermarket plugs).
It could still be your coils or fuel injectors as well. But spark plugs are the cheapest first "fix". And it has been known that aftermarket Bosch spark plugs DO not work as well as BMW ones.
Don't believe me... just go back a few pages in this thread and read this(post #44 and #45)...
http://www.1addicts.com/forums/showp...2&postcount=45
http://www.1addicts.com/forums/showp...2&postcount=44
Also... make sure ypur dealer gives you the correct spark plugs. There is a N54 and a N55 version:
N54...
12-12-0-037-244 ( 3 prong, not 4 ) in currently production
N55...
12-12-0-037-582 ( single prong )
http://www.1addicts.com/forums/showp...2&postcount=42
http://www.1addicts.com/forums/showp...2&postcount=43
Dack
      05-14-2013, 01:58 PM   #83
takrdown
Other car was a submarine
takrdown's Avatar
94
Drives: i4M50 (waiting), 2013 R56 JCW
I hate always being the example for spark plug problems
      05-14-2013, 02:09 PM   #84
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Your my Poster-boy!
      05-14-2013, 05:12 PM   #85
MIAblu1
Ok, so I removed all 6 plugs
Seems like cyl 1 & 2 fried the plugs for some reason
Plug 1:
Plug 2:
Plug 3-6 are fine:
Not sure what could've caused 1 & 2 to burn up that way in a matter of a day and why those only and not all of them if it's in fact due to a difference between these replacement Bosch plugs in comparison to BMW specific bought ones...
      05-15-2013, 09:27 AM   #86
takrdown
takrdown's Avatar
94
Originally Posted by Dackelone View Post
Your my Poster-boy!
It's only because my post and troubleshooting were so damn thorough
      05-15-2013, 11:40 AM   #87
MIAblu1
So after replacing the plugs on 1 & 2 the car is responding much better but still throwing the engine malfunction and not running to potential. Will be getting the car scanned and checked for the codes.
      05-15-2013, 02:49 PM   #88
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
PLEASE let us know(here) what your problem ends up being. We are all curious to the fix.
1addicts
