10-09-2023, 02:01 AM | #24 | |
Rep 2
Another screen upgrade complete
I have completed a screen upgrade on my 128Ti as above. I also had to set the resolution to 1920_960 first and then back to 1920_720. I didn't wait any time between reboots after programming, just the initial settings, reboot, res change, reboot, change res back and reboot. All working as it should. |
suchpro7.00 |
12-17-2023, 06:09 AM | #25 | |
Rep 20
To be honest in 85% of situations I don't notice the smaller screen. It's apparent only when there's a lot of sun and you see all the dead space. One thing that helps with the smaller screen is if you have CarPlay, it really fills out the screen, and even on the 8.8", it's more than enough. If I had iDrive 7 and 8.8" I would have upgraded, but for iDrive 6, it's good enough. |
12-29-2023, 11:13 PM | #27 | |
Rep 2
I found it easiest putting a cloth against the current display screen and use a trim removal tool against the cloth at the top right slowly working my way around the edges. There are a couple of long metal pins that need to come out fairly straight so work it slowly a bit at a time rather than bending too much. There is a cable connecting the ambient lighting at the left side but it can be left attached whilst you replace the screen. Once out the screws for the screen are visible and hopefully the screen cable is loose enough to pull the screen forward and disconnect . Be careful disconnecting the cable with a small screwdriver to release the locking clip. Fit the screen and slowly refit the trim. |
Thunnus6424.00 RaptorStrike61.50 |
12-30-2023, 03:13 PM | #28 |
Rep 59
Can you provide some details on how to do this? I'm trying to fix the resolution on AA on iDrive 8. Resolution looks low compared to CarPlay. Hardware and software is stock.
02-04-2024, 02:02 AM | #29 | |
Rep 208
Unfortunately this didn't work for me. I would like to make the upgrade in a G21 from 2020 with MGU Headunit with ID7. I have tried it several times, but more than the backlight never worked on the new display. Has someone suffered the same problem and perhaps have a solution for this? Last edited by tomsab0; 02-04-2024 at 02:46 AM.. |
02-29-2024, 11:33 PM | #30 |
Rep 29
Hi,
I have a 2022 g22 that came from factory with the touchscreen deleted. Can anyone tell me the part number needed to replace my non touch screen with a touchscreen? Thanks |
03-17-2024, 01:40 PM | #31 | |
Rep 419
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
03-29-2024, 01:06 PM | #32 | |
Rep 20
While on the G20 the ENTRYNAV2 (ID6) with 8.8" was the "basic" option and if you opted for a larger screen (Professional) you would also get an upgrade to the MGU (ID7) head unit with a 10.25" screen. So there was no NBTEvo with a larger screen ever available for the G20. Even the ID6 variant got replaced with ID7, 6 months after the model launch. Update: I reached out to BimmerTech and the answer was that they couldn't code the 10.25" display on ID6 because the ENTRYNAV2 HU in the G20 cannot output the needed resolution. |
03-29-2024, 01:26 PM | #33 | |
Rep 419
03-31-2024, 05:48 PM | #34 | |
Rep 20
For now, I've given up on this upgrade as either way you look at it's a big job. Hoping someone will come up with a modded screen -- though unlikely as only cars from late-2018 up to mid-2019 came with ID6. |
Tags |
10.25, 8.8, display, idrive, large screen |
