07-15-2020, 08:11 AM | #23 | |
Rep 310
liner to access it. Last edited by Calamari; 07-16-2020 at 03:03 AM.. |
helmet91303.50 |
07-15-2020, 08:47 AM | #24 |
Rep 567
Drives: BMW G20 330i X-Drive M-Sport
Oh... I didn't make it that far. I found that diagram too, but it wasn't all that detailed. LOL
Thanks! |
07-18-2020, 01:46 PM | #25 |
Rep 15
I’ve bought the Match UP7BMW, but realized and confirmed by Audiotec Fischer I needed the UP7DSP including the 1.7 RAM harness.
I’m planning to built these into my car tomorrow. Curious how it Will perform. Now I need to figure out how to access the battery. |
07-19-2020, 12:05 AM | #26 |
Rep 222
Are you swapping the amp out?? Please take lots of photos and let us know how you go! Definitely keen on tunes, ASD and what speakers you're running
07-19-2020, 04:22 PM | #27 |
Rep 2,180
07-19-2020, 04:28 PM | #29 |
Rep 2,180
07-24-2020, 11:15 AM | #30 |
Rep 310
Hi,
I've looked under the boot liner to see what kind of audio system I have in my 07/2019 G20 with HiFi (mid-level) sound system. My car has iDrive 6 headunit. I do not have Navi-proffesional system that runs on iDrive 7. From what I saw, I have the classic analog amplifier architecture that is well known on all F-series cars but is also found on a lot of G30 cars. I'm posting pics with the details of the amplifier and connectors. Encanto Can you confirm that this is a standard analog HiFi amplifier and that I can replace this factory amp with Match UP7BMW amplifier with a plug-n-play harness. Amplifier - bottom side Amplifier - female connector Male connector (factory harness): |
07-24-2020, 12:50 PM | #31 | |
Rep 2,180
Your configuration does not show in the ETK for 7/19 - HiFi(676) OEM amp in a G20- and no RAM.
I would guess that your 676 will support an UP 7BMW directly, no need for RAM harness. Quote:
07-25-2020, 03:24 PM | #32 | |
Rep 15
Installed my Match-up 7DSP with
You'll need the Match Up PP-DMW 1.7 RAM harness, this is a Y-cable. One side is connected to the OEM harness of the car, the other end is connected to the RAM-module, and 3 set of Molex-connectors connecting to the Match 7DSP. There is a 2-Channel MEC built-in. I you order this at ACR-Helmond, they know what to deliver. This is how I have built-in the Match Up 7DSP, it is just under the RAM-module. Screwed 1 screw into the plastic panel to secure. The other side is resting on the bottom of the car. The image is upside down, the top of the picture is the bottom of the car :-) I'm using the factory speakers. Then the fun part started. How to configure the Match Up 7DSP. ACR-Helmond was helpfull to provide the car-specific setup-file, although it was not quite good. I had to figure out how the DSP-Tool is working and with trial and error have set it up in a way I think it is good. For those who are interested in the setup-files, attached 2-zipfiles. BMW X3 2020 - RAM - UP7.6 - ms8 - oem front.zip This file is provided by ACR Helmond. 20200725-3 BMW X3 .zip This file is created after modifying the settings. If anyone has knowledge setting up the Match Up 7DSP, please feel free to help me. After the configuration the sound is much better than the original HIFI system, more crisp and more bass. Last edited by ETan; 07-25-2020 at 03:30 PM.. |
07-25-2020, 03:37 PM | #33 |
Rep 222
Awesome! Thanks very much for the info. Can I please confirm if you have coded the ASD off and if not, whether it is noticeable (ie. The artificial engine sound in amplified) in sports mode?
I don't quite understand your speaker HiFi setup. I'm not sure the option you're talking about is available in Australia. I'm going to need to pull my car apart to confirm... which unfortunately I won't get to for a couple of weeks. |
07-25-2020, 03:40 PM | #34 |
Rep 222
In regards to tuning, I think there is a thread in here (or maybe another forum) that runs through it fairly well. Maybe search for Match Up and see what comes up. It's not really specific to this car.
07-26-2020, 03:56 PM | #35 | |
Rep 310
I just placed the order. I'll share my impresions after I hook it up and fiddle with the DSP settings. |
07-27-2020, 04:51 AM | #36 | |
Rep 15
The ASD is still on. I will search the forum about tuning the DSP. |
08-10-2020, 11:10 AM | #37 |
Rep 310
I just installed the Match UP7BMW amp with DSP.
Installation is straightforward. Disconnecting the oem HiFi amp and removing it from the rack. Putting the Match amp on the same rack and connecting it to the OEM connector. I didn't have to buy the ID7 harness as my car (interestingly) doesn't have the RAM unit, but a standard analog HiFi amp powered by an audio receiver in iDrive 6 headunit. Downloaded the BMW limousine sound setup for the DSP and loaded it into the amp via Audiotec-fischer's DSP software. Generic limousine sound profile was good but it was "Center-optimized". Thus i measured distances from the driver's head to all speakers and entered them in the DSP tool to get clearer highs and a better soundstage. I've also made small tweaks to the clarity effect to slightly boost up the brightness of the smooth sounding silk Eton tweeters. The system now sounds great. I am running OEM under-seat woofers and ETON mids and tweeters on all channels, including center. Even with OEM under-sear woofers low end is very very good. Mid-bass and bass guitar, and bass drums sound surprisingly good for a 16cm woofer. This is because MatchUp amp has some tricks that allow it to push the OEM woofers just close to the limit without ever overpowering them. Even more impressive is that this feature does these tricks dinamically, so when the volume is lower it will push full power, and will protect the speakers when the levels get close to speaker's limits (either when volume is raised, or when the bass level raises within a track). All in all, Match UP7BMW is a great piece of equipment and I would recommend it to anyone that wants a clear, natural sound. Last edited by Calamari; 08-11-2020 at 07:41 AM.. |
helmet91303.50 |
08-11-2020, 08:09 AM | #39 | |
Rep 310
Did you do time-aligment? Equalizer or gain levels for individual speakers? Did you play around with processing options like RealCenter and stageXpander? |
08-11-2020, 02:47 PM | #40 |
Petrolhead
1949
Rep 3,521
After going through all the posts, basically the limiting factor in the HiFi system is the amp and not the speakers?
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
08-11-2020, 03:53 PM | #41 | |
Rep 310
Component speakers of the OEM system are muddy. OEM tweeters are very "metallic" sounding and mids are lacking in mid-bass. As soon as I replaced OEM speakers with ETON units, sound became clearer, precise, warmer, more natural, and noticably more kick-bass came out of the 4inch mid units. (All this on the factory HiFi amp) From all the data I have collected so far across numerous bmw and carAudio forums, replacing the amp and all mids and tweeters of BMW HiFi system is enough to get very good results. However, optimal tuning of the DSP profile is crucial to get the most out of this system. Last edited by Calamari; 08-11-2020 at 04:00 PM.. |
VipinLJ1949.00 |
08-12-2020, 06:16 AM | #42 |
Rep 222
Looks like I probably have the old style amp - I'll pull it apart tomorrow to confirm (11/2018 build). I'm mostly interested in the tuning now... running all bavsound speakers and subs with an amp that's not specifically tuned to the car and speakers is annoying. Assuming it's the old amp, I'll check with Bavsound to see if they have a tune for the G20 with their F30 amp. Since their amp is not modifiable, it's a bit of a risk. So I guess I'll end up going with the Match amp and manually playing around until I'm happy.
I'd be keen to get a copy of people's tunes, especially if they are running non-OEM speakers. FYI - I read that builds before 09/2019 have the old separate amp. Not sure I'd rely on that though. Last edited by AustraliaG20; 08-12-2020 at 06:21 AM.. |
08-12-2020, 07:01 AM | #43 | |
Rep 310
Anyway, just start with the limousine setup, and play around with it. P.S. My car is a 07/2019 production date, and I have the old-style analog hifi amp. Last edited by Calamari; 08-12-2020 at 10:31 AM.. |
08-12-2020, 09:35 AM | #44 | |
Rep 424
