11-09-2020, 11:04 PM | #89 | |
Rep 690
The Viofo will not go into parking mode; the Viofo is not automatically recording when I start the car; the NEO charged to 100% but does not say it has any usable charge for some reason...and doesn't give Viofo power when I turn car off and never goes into parking mode. I have no idea what is wrong or if I am doing something wrong. The cam records when I put it on manually and works fine but I have to turn Viofo off and on a couple times manually to get it to record. I have no parking mode working and thats why I bought the NEO. Something is not working and I have no idea what the problem is. It is very frustrating I thought this would of been an easy installation thats why I went this way instead of black view 900X with LTE Module and hot spot,,, Let me know if you have any ideas what I should do? thank you |
11-10-2020, 12:36 AM | #90 | |
Petrolhead
1949
Rep 3,521
My knowledge is very limited but I'll try help as much as I can. Let's start from the basics first. Do you have pictures of how you've wired the spliced cable to your neo?
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
11-11-2020, 01:02 PM | #91 | |
Rep 690
the top picture is the cable coming from the Viofo A129 Pro and the bottom picture is the cable coming from the Cellink NEO View post on imgur.com View post on imgur.com |
11-12-2020, 09:16 PM | #92 | |
Petrolhead
1949
Rep 3,521
I'll check mine tomorrow and see how they are labelled and get back to you
Current:
BMW11279.00 |
11-12-2020, 10:52 PM | #93 | |
Rep 690
11-13-2020, 03:12 PM | #94 | |
Rep 230
11-13-2020, 05:08 PM | #95 |
Rep 1,480
Drives: 2020 M340Xi (G20)
2020g20 ,
Am pretty certain it's a small transformer stepping 12v down to 5v -- it's printed on the face label
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
11-18-2020, 05:07 PM | #99 |
Rep 30
Had the dash cam working and then it stopped. I have yellow constant wire into fuse 38 and red accessory wire into 71 using piggyback fuse holders. I have Blackvue 900x with hardwire kit. The inline fuse on hardwire kit reads 12v for the yellow wire when tested with multimeter but the inline fuse for the red wire only reads 1 volt. However when I put the blade fuse back into slot 71 which powers the red wire and test the fuse I get 12v. Any ideas folks.
12-12-2020, 02:53 AM | #100 |
Rep 30
Used Joedeejay diagram of always on and ignition on fuses. I picked 38 for always on and 54 for ignition on. Both these are unused in my car. I turned parking mode off so that it would not record in my garage at night. It worked great for a month. Camera would switch off after about 15 minutes when the ignition on fuse went dead. But now the dash cam has started staying on all the time. If I take out the piggyback fuse from 54 it then switches off. So it appears that 54 is remaining live now for some reason. 38 has no effect since parking mode is switched off. Any thoughts or advice on this one.
12-13-2020, 08:32 AM | #101 |
Rep 30
Poor response folks. Update. Fuse 54 has now returned to going off within 5 to 10 minutes of switching off ignition. But two days ago it stayed live for 5 hours after ignition was switched off.
12-17-2020, 04:37 AM | #102 |
Rep 184
I've hard wired in to fuse 59 the Aukey front and rear dash however it has really effected DAB reception. Even if I unplug the rear and just have the front powered on. Has anyone else had this?
03-16-2021, 02:50 PM | #103 | |
Jewel Runner
332
Rep 911
Fuse 46 works perfect, times out after a couple minutes. Thanks!
06-02-2021, 03:44 PM | #104 |
Rep 71
Some good info here, thanks all.. although everyone seems to be using different fuses for switched.
One question, why are people routing down the passenger side (left side Im U.K.) when the fuses used are on the right is there any logical reason nobodys running down the right hand side to fuse box?! |
07-26-2021, 08:46 AM | #105 |
Rep 346
Drives: G20 330ix M Sport
I installed a Vantrue N4 3 camera set up in my G20 this past Saturday. Used F38 with a fuse tap that has a 5A to be able to have power for parking mode. Run the ground wire to the bolt for the air bag. Car sat for 2 days and the low voltage message came up on start up this morning. I ended up unplugging the both the main camera and the the fuse tap from F38. This is the hardware kit that came with the camera set up. I didn't move the switch on the transfer control box. I left it on what ever the setting was out of the box. I am thinking that might be the reason. But not sure. What would be the better option to have it switch to? 12v/24v or 11.6/23.2v?
"It is funny...people who drive anything expensive often get labeled by folks who drive less expensive cars. I have found, without exception, that douchebags cover all demographics and incomes."
07-26-2021, 12:41 PM | #106 |
Petrolhead
1949
Rep 3,521
I've been running the setup I mentioned a few pages back for a while now (basically since the day I posted that). Car has spent days in my garage without being started or even opened (for upto three weeks in a row). No low battery issues or anything else. Been working perfectly. And it records every time the garage door is opened too. So yes.
Current:
07-26-2021, 02:22 PM | #107 | |
Rep 346
07-26-2021, 11:03 PM | #108 | |
Petrolhead
1949
Rep 3,521
Your module only has 12v and 11.6v. I'd do 12v. Mine had a couple more. I think I've set mine to 12.4v. Can't remember for sure.
Current:
07-27-2021, 05:11 AM | #109 | |
Rep 346
VipinLJ1949.00 |
09-21-2021, 12:32 AM | #110 |
Rep 223
Is there any reason I'd ever use a slot (is that what they're called?) that's occupied by an existing fuse already when there appear to be so many empty unused slots in the car? It seems to me like using an empty one should always be better, since you won't modify the existing circuit (no chance that the add-a-fuse isn't working properly and somehow blows the existing fuse, or that you accidentally connect the two fuses in series rather than in parallel).
Trying to figure out how I should wire a battery pack for a dashcam into the fusebox. Seems like I'd probably want an empty ACC slot (not looking to drain the car's battery while the car is off). I simply plug in the add-a-fuse leaving the bottom fuse empty (since the port was unused before) and then plug like a 15A fuse into the top so I can get 9A from it, and then plug that into the the external battery pack (i.e. B-124X). Just checking with the more experienced folks around here. Am I missing anything here? |
