01-11-2018, 11:08 AM | #23 | |
Rep 10,655
The question to me is whether there is any jack that will roll right under to the front center lift point. If going on ramps or planks, a lot of jacks work and you don’t need a super expensive long reach. My $59 HF aluminum jack works if you do that. Last edited by pbonsalb; 01-11-2018 at 11:29 AM.. |
01-11-2018, 11:29 AM | #24 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
The Sunex looks really low and like a great solution. I can't speak to the quality of that product since I have never laid hands on it. I can say that the Compac is the highest quality jack I have ever seen / used. To say it's a waste of money is hard to determine IMO. I am not against cheap tools. I have two Harbor Freight tool chests that work well, sturdy, and cheap. I would feel like I was wasting my money to buy a Snap-on chest for my home use. However, I am willing to pay for a quality jack because I think it provides better performance, longevity and safety. It would suck to have a jack fail under any scenario. I have had the cheap jacks that don't last. I'm willing to pay more for that. You may not.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
01-11-2018, 11:35 AM | #25 |
Rep 10,655
Even with an expensive jack, I would use a second jack or blocks or jack stands before going under the car. I have a lift so I don’t use jacks as much anymore and if I am at the track changing wheels, I don’t need to go under the car. For me, the $59 HF aluminum jacks have been the best. Have 2 of them. Been using them for years. Also have a big 3 ton Michelin jack that was $79 and have used it for 10 years. I wouldn’t mind one of the sunex or arcan jacks due to the reasonable price long reach and low profile but have not bought one because I don’t really need it.
01-11-2018, 11:42 AM | #26 | |
Rep 6,734
'23 X7
01-11-2018, 12:02 PM | #28 |
Rep 2,971
I think there are other considerations when choosing price point on jack IE: Ease of installation, use, service intervals, documented failures, weight, etc. would hope nobody is dull enough to go under a car unsupported no matter how expensive the jack.
Another "contender?" I'll throw in mix is Arcan XLT2. Only thing lacking is a rubber saddle IMO. But that's always up to owner. Oddly enough it's a small but important (to me at least) feature for jack to have. Bring on the hockey puck comments! :P |
01-11-2018, 12:39 PM | #29 |
Rep 10,655
Do you need a rubber saddle since the factory jack points are plastic and require an insert block, or in the case of the center one, is already rubber buffered? If using other places to jack from, like a suspension point, a rubber jack cover might be less likely to slip but I try not to jack in a way that slippage is likely. I have 2 jacks with rubber pads and 1 without and have found no difference in using them but I have no concerns about marring the underside of my car-it would be minimal and no one sees under there.
01-11-2018, 03:26 PM | #30 |
Rep 2,665
Drives: Goggomobil
This is the one I have - Omega MagicLift. I said white because of the handle bar. It's a 2 ton lift. It's a must to have a lift like this. I use it only once or twice a year.
F86 X6///
01-11-2018, 08:32 PM | #32 | |
Retired Curmudgeon
2988
Rep 4,054
From the Essco Jackstand page on ReverseLogic's website (not yelling at you all, it's in all caps on the web page):
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
01-11-2018, 08:58 PM | #33 |
Rep 10,655
It’s a warning for liability reasons. But a car is more stable on 4 stands than 1, 2 or 3. I am much more careful than when I was younger. It’s up to you what you do. Chances are you’ll be fine just using a hack and nothing else. But I don’t take the chances I used to.
01-15-2018, 06:06 PM | #34 | |||||
Rep 2,971
01-15-2018, 06:18 PM | #35 |
Rep 729
I’ve read and heard this many times before I believe the potential problem is that once you have the car on two stands (i.e., front or back) and lift the opposite end of the car to place the second paid of jackstands, the first pair could tip or the car could slide off of them. It does seem counterintuitive on first impression but I think it makes sense.
admranger2987.50 |
01-26-2018, 06:31 PM | #38 |
Rep 2,971
UPS dropped off the rather large (100lb) box today. Surprisingly showed up relatively unscathed. Northern tool took order, and delivered promptly. Well packaged, and detailed instructions. Haven't used it yet on car, but pumps are smooth, as well as release. It's as low pro as you will find, but am still having doubts of reaching center point w/o having to raise car.
Some pics for those interested. (Found a bolt/washer randomly in box) - Not sure if it was part of packaging, but shows no such parts in manual. Any ideas? |
shimmy232351.50 |
01-26-2018, 07:05 PM | #39 |
Rep 10,655
Try it and let us know how many more inches you would need to avoid having to drive onto planks. As I recall the AC, at 37 inches frame length, is longer but it ramps up to 6 inches tall at the handle end and I can’t tell at what point that ramp up becomes an issue since the height increases gradually. The AC is also over $600.
01-29-2018, 12:41 PM | #40 |
Rep 10,655
I had my 08 E90 M3 on my lift to change the oil few days ago and measured from the center jack point to where the front bumper cover turns up and it’s about 36 inches. None of these jacks are going to reach it while the tall end of the jack is in front of the bumper cover.
My car is lowered so I have less clearance than a stock car and would need to drive on planks in order to roll a jack under the car. I can use 2 jacks like the $59 HF 1.5 ton aluminum jacks, one on each front side jacking point, without needing to drive on planks. That is what I usually do if not using the lift. Maybe one of these low profile jacks is low enough even at its tall end to roll under a stock height car, but I don’t know. I guess the low point is not the only place to be concerned about height if the goal is to get under from the front. The Last edited by pbonsalb; 01-31-2018 at 07:09 AM.. Reason: M |
01-31-2018, 06:11 AM | #41 | |
Rep 2,971
Possible on a stock height car as you say, thats a guess. Its safe to say there needs to some height clearance / IE via ramps or 2 jacks to get under the front center point when lowered. Another reason I opted out of the AC route. Don't think the rear will be as much of an issue. |
01-31-2018, 07:13 AM | #42 |
Rep 10,655
Be careful on the rear. On my 99M3, the subframe wraps around under the diff so I can lift from under it. On my 08M3, it does not and you don’t want to jack from diff itself because that puts the weight on the three diff bushings and bolts.
02-01-2018, 04:15 PM | #44 |
Rep 12,736
you can safely jack from underneath the differential. i can understand how some would prefer not to. i was told it was safe by someone i trust, and i have done it several times without ill effect.
Instagram; @roastbeefmike
