04-22-2018, 12:49 PM | #1 |
Rep 241
DIY: Manual Transmission Fluid Change
I saw there was a little demand for a DIY for changing the manual transmission fluid in our F22s. It's a pretty easy task in and of itself if you have the right tools. Do this at your own risk, I am not liable for any damages if something occurs because of this DIY.
You will need the following: 8MM socket 10MM socket 8MM Alllen socket Torque wrench that is calibrated to 45nm A fluid transfer pump (you can pick one up at your local auto store for ~$10) ~2 Liters of fluid. I used the OEM BMW fluid (MTF-LT-5), PN 83222239654. I ordered it online, you can probably get it from the dealer (15% off with a BMWCCA membership so join!) 1: Get the car on jackstands or a lift 2:Remove the plastic shield (held on by 8mm trim bolts and a 10mm plastic nut) 3: Circled in red is is the fill plug, circled in blue is the drain plug. 4:I blew out each hole with a little brake cleaner and then used an 8MM (edit: some claim 9mm for their car) allen to loosen the fill plug first. The reason for doing this is that you do not want to be SOL if you can't take the fill plug out after you have drained the existing fluid. 5:Loosen the drain plug, and fluid will come out. It is normal for it to smell funny. 6: Once it is fully drained, clean the plug and Torque it to 45NM 7: Remove the fill plug and using a fluid transfer pump, pump in approximately 1.2 liters liters of fluid or until it starts leaking out (about 1.2 liters) 8: If you slightly overfilled it, let the remaining oil drip out. clean and torque the fill plug to 45nm 9: Reinstall shield, take the car off ramps and drive away! I noticed my car shifted a little better. BMW claims their MT fluid is lifetime...It has been shown that this is kind of BS. I change mine every 30k miles. I hope this helps you guys out! Last edited by EEBreh; 07-22-2021 at 12:55 PM.. |
04-25-2018, 11:27 AM | #4 |
Rep 525
04-25-2018, 12:37 PM | #5 |
Rep 131
Thanks for the reply! I'll do it around 25k-30k then - I autocross, track and mountain drive my car so I guess I drive "moderaterly hard"
04-28-2018, 07:37 AM | #6 |
NewFinishColumbia/detailer
604
Rep 2,096
I drive my car moderately hard as well and changed the fluid out at 71,321 miles. I also did a sample and sent it to Blackstone Labs. Here are the results.
I replaced the stock fluid with RedLine D4 ATF.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
05-02-2018, 09:54 AM | #7 |
1L
156
Rep 336
Great info! Any other oil recommendation other than Redline?
2015 Glacier Silver M235i/6MT
MP Front Splitter//MP CF Short Shifter//MP CF E-brake//MP LSD//Cold Weather package//Driver Assistance package//Oyster Dakota leather//Aluminum Hexagon trim//ECS Tuning Wheel Spacers//AutoPlus Rear Diffuser//HUD//Rexing DashCam//AutoID M Mirror Caps |
05-02-2018, 09:59 AM | #8 |
Rep 525
05-02-2018, 12:47 PM | #9 |
Rep 241
Im sticking with the BMW brand while it is under warranty because if the transmission blows up, i don't want them to take an oil sample and reject the warranty work. Ive used redline and swepco before In my porsche, both are excellent brands.
05-02-2018, 02:56 PM | #10 |
1L
156
Rep 336
Thx CXP213 and EEBreh! I'll try the Redline. I've used Royal Purple in my past BMWs before and that was pretty good.
12-17-2018, 04:01 PM | #11 | |
Rep 245
Here is the torque data (2AZ) and according to the Transmission designations for the GS6-45BZ it's a type K, which is 40nm torque. |
12-17-2018, 04:03 PM | #12 |
Rep 245
I have 17k and I'm doing it because it's noticeably less smooth than when I first got the car brand new. I never did my fluids at break in though so that might be why. I followed the BMW maintenance until now that I learned better.
12-17-2018, 04:58 PM | #13 | |
Arsevader
37
Rep 128
12-18-2018, 02:41 AM | #14 |
Car Geek
3718
Rep 3,626
For the type “H” transmission in the M240i, it shows 35Nm if the fill/drain plug has an M18 thread, 25Nm if it has an M12 thread: https://www.newtis.info/tisv2/a/en/f...earbox/5s1E0XS
Funwithdesign36.50 |
12-23-2018, 11:18 AM | #15 | |
Rep 1,271
I've used Redline lubes since the 1980's. Great products. However, Redline sez it doesn't have fluid suitable for our ZF 6MTs. I'll still with the spec'd fluid. |
12-28-2018, 12:18 AM | #16 | |
Rep 245
Real OEM and Newtis shows GS6-45BZ for the M235i and M240i. BMW of South Atlanta also has it listed as GS6-45BZ for F22. |
01-06-2019, 09:01 PM | #18 |
Rep 245
That link is just transmission designations which is a universal page they link to keep the info all in one place. I haven't checked every model but if you check the manual transmission designations page on the M235i, 4 series, 8 series they all bring up the same page so it looks like every single car links to that document.
01-06-2019, 10:45 PM | #19 |
Car Geek
3718
Rep 3,626
A search for the appropriate part by VIN and for model designation 2G13 (maps to 2G1C in the 4th to 7th character of the VIN) leads to GS6-45BZ-SHCK (part# 23-00-8-609-450) as the installed transmission for my 2017 M240i.
01-20-2019, 07:42 PM | #20 |
Rep 912
Drives: '17 F22,15 E84 M Sport,02 R53
I don't see any pics? Am I missing something?
11-02-2019, 09:13 PM | #22 |
Rep 12
Drives: BMW M235i, Honda S2000
Nice, will be doing this and the differential fluid soon. Going with amsoil DCT which meets the BMW spec for LT5 and the pentosin specs.
