04-15-2024, 11:20 AM | #1 |
Rep 224
Spilt superglue on trim
Anyone know the best way to remove superglue accidentally spilt on the black door trim as attached photo. Someone suggested pure acetone but my guess is that will either melt the paint or remove the paint entirely. Thanks
Martin
04-16-2024, 01:58 AM | #3 |
AH3 Owner
206
Rep 312
Drives: BMW 335i ActiveHybrid 3
If it hasn't caused the plastic to melt, you can try this. https://www.3m.com/3M/en_US/p/d/b40070703/
04-16-2024, 05:43 AM | #4 |
Rep 224
I kind of like the gloss black effect, I’ll try the 3m removal method. I dare not try acetone as I think it will strip the paint, although others have said it won’t
Martin
04-22-2024, 01:05 PM | #6 |
Rep 224
Acetone did the trick on the trim,sprayed plenty of water immediately after using it, no damage. I’ve one other issue, super glue on a plastic window deflector already fitted to the car. I put some super glue on an old deflector I had, then used acetone to try and remove it, it ended up cracking the deflector,even though it removed the glue. Tried all the old Wives tales, white vinegar, surgical spirit, soapy water etc but it won’t budge.Any products to recommend? For the UK? I don’t want to risk scratching it or dulling the tint. I’ll try nail polish remover without acetone next, but don’t want to waste money on various products that don’t work. The 3m spray as in the previous post is unavailable here, Any ideas?
Martin
