09-14-2013, 12:53 AM | #1 |
Rep 603
How to reset oil service / brake pad service indicator
1. Without pressing the brake/clutch, press the start/stop button
2. Wait for the service reminder to disappear 3. Press and hold the odometer reset button. You will notice your trip meter reset and then go back to the value it once was. Keep holding for a couple more seconds At this point, service values that can be reset will come up. Use the odometer reset button to scroll through the menu. 4. At the value you want to reset, press and hold the odometer reset button. "Reset possible" will change to "Reset?" 5. Press and hold odometer reset button again until value is reset 6. Press the start/stop button to start car or turn off car |
09-27-2013, 06:06 PM | #2 |
Jacko
Rep 8
Drives: 2012 335i Sport line
F30
Does this work on the 2012 F30 models?
12-22-2014, 08:35 AM | #4 | |
Rep 152
For some reason after the last oil change i couldn't reset the mileage through the cluster Every time i try to reset i get an error message "reset unsuccessful" Now its showing "-2000 kMs" I have a retrofitted NBT so i dont want to go for BMW service as they will say the car needs reprogramming. The guy who retrofitted my NBT said i can use some tools such as ISTA or ISPI NEXT to reset the oil interval Any feedback will be appreciated Cheers |
04-08-2015, 11:19 AM | #5 | |
Rep 22
04-16-2015, 11:05 PM | #7 |
Rep 1
I have a retrofitted NBT so i dont want to go for BMW service as they will say the car needs reprogramming. The guy who retrofitted my NBT said i can use some tools such as ISTA or ISPI NEXT to reset the oil interval..???
Get fast success in certkiller 70-411 and questions by using our 642-874 latest exam We also offer up-to-date www.usna.edu and answers for your prep
07-20-2017, 08:11 PM | #8 | |
Rep 2,010
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
03-27-2018, 07:39 AM | #10 |
Rep 345
Anyone know how to reset the vehicle inspection reminder? It's not on the list that appears in this reset thread.
Never mind, figured it out in iDrive. |
09-10-2018, 01:05 PM | #13 |
Rep 5,089
09-10-2018, 02:25 PM | #14 |
Rep 16,088
It has one trip point, at about 3mm. When mine went off it started counting down from 1,000 miles, literally, with an update every 100 miles.
09-10-2018, 05:36 PM | #15 |
Rep 5,089
So if pads are replaced at 5mm without tripping sensor, then very likely sensor will not need replacement then. My guess is the electrical contact can be cleaned up and the sensor can be reused.
09-10-2018, 09:35 PM | #16 |
Rep 16,088
You can reuse the sensor if it hasn't been tripped. I did on my front pads. It didn't trip because the front sensor is on the driver's side, while the pads that were just about toast were on the passenger side.
12-01-2018, 01:14 PM | #17 |
Rep 2
Just Finally put my rear brakes on the 2015 435iX. The instructions at the top worked perfectly.
I drove another 4500 miles after the rear sensor activated. I didn't realize the car would tell me if it was the front or rear, so I eyeballed them and thought the fronts were more worn, and bought and replaced those only to see the front sensor was not tripped. At 4500 miles after sensor trip the rear pads had still not worn down to metal, but they were getting close. I've got the single piston rear calipers, and 4 piston front. There are apparently 3 different rear brakes. First time I ever did this type of front brakes, it was quite easy - knocking out the pins with a punch is easier than getting the floating caliper pins back in, I like it. |
02-05-2020, 03:34 AM | #20 |
Rep 52
SOLVED (brake service)
With "ISTA D" and ENET cable (Y) yessssssssssssssssssssssssssss I've tried everything before (Instrument cluster menu, OBD ELM327 with Carly, E-SYS, BMW tools, etc.) with no success. |
09-28-2020, 03:41 PM | #21 |
Rep 126
When I try this, I get the following menu:
Identification System test Start roller Test end Unlock How do I get to the menu to reset my brake fluid & pads? Thanks. |
09-28-2020, 03:50 PM | #22 |
Rep 126
Did some more digging. I was holding the button down too long. Brakes reset
I also unlocked that menu (unlock code is the sum of the last 5 digits of VIN) and found some potentially interesting menu options. |
