03-20-2024, 06:15 PM | #1 |
Rep 87
Posts Drives: 2012 328XI, 2023 M4, 2024 M3 Join Date: Mar 2013
PPF bad Install question
I just had full front end PPF done and at the top of the hood they cut it to wrap around the corner. The one on the passengers side is pretty big and very noticeable. Is this normal procedure or should I have them re do it?
Here is a picture of the passenger and Drivers side.
2012 E92 N51
Last edited by Ifly680G; 03-20-2024 at 09:15 PM.. Reason: Clarity reason for posting |
03-20-2024, 09:44 PM | #2 |
Rep 3,406
I'm sure people will jump in and say that's absolutely unacceptable...but the reality is I see stuff like this on most PPF jobs, and on significantly higher-end cars.
Good thing is that most shops will give stuff like another go if you take it in. Or if you're not that anal, leave it. But then I'd wonder why you got PPF in the first place. |
Burrcold5322.50 Bornagain73164.00 |
03-20-2024, 09:50 PM | #3 |
Rep 3,962
It's not a bad installation (or any worse than a standard pre-cut, close to the edges kind of job)...but you likely paid less for it. If you want edges wrapped, you need to ask the shop, and the price will be reflective of that choice.
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
whofelt198.00 |
03-21-2024, 03:53 AM | #4 |
Rep 16
That's how PPF is supposed to be applied: it should be cut around sharp corners instead of attempting to wrap it in. Otherwise, it will bunch up and eventually lift back up. Think of it like using gift wrap on the corners of a box — there's extra material that needs to be folded over. The same principle applies to PPF, but keep in mind that it's much thicker material that's harder to manipulate.
dizz81311.00 Bornagain73164.00 |
03-21-2024, 06:58 AM | #5 | |
Rep 3,962
Westside Guy5726.50 |
03-21-2024, 07:36 AM | #6 |
Rep 12,565
Posts Drives: Z4 M, X5, GX460 Join Date: Apr 2008
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
I’ve seen all versions… cut corners, trimmed to corner and folded over. That would annoy me but only because I’m super ocd when it comes to cars. That said if it was only that section I could live with it since it’s not easily in plain sight as opposed to lower part of the hood. Can’t hurt to ask them to redo but I’d make a note to never go back. Just having to drop my car off again for their mistake is a pain.
03-21-2024, 10:24 AM | #7 | |
Rep 16
What I'm saying is that the corner circled in green meets industry standards and illustrates the correct method, where the PPF isn't completely wrapped underneath the panel like they would do with a straight edge where they leave half an inch of overhang to be tucked in later. I get my PPF done at a top-of-the-line shop where they custom cut the PPF for each panel & all my corners look like the one circled in green. |
03-21-2024, 11:09 AM | #8 | |
Rep 3,962
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 Last edited by Burrcold; 03-21-2024 at 11:18 AM.. |
03-21-2024, 11:51 AM | #9 | |
Rep 87
03-21-2024, 01:40 PM | #10 |
Rep 3,277
Posts Drives: E46 M3 Coupe/G80 M3CX Join Date: Jul 2021
PPF isn't perfect to the mm. If that corner is your biggest issue, then your installer did a very good job.
azonis202121.00 chris7197334.00 |
03-21-2024, 06:48 PM | #11 |
Rep 1,082
You made look at my PPF and all my corners are like in the green circle....from the high end install shop (who did my 2023). But, on my non-high end (2021 JGC SRT), its like the red circle...bottomline...does bug me a bit...no-pun intended...
2023 BMW X5MC Tanzanite Blue II Metallic
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
03-23-2024, 06:26 PM | #12 |
Rep 11
I went out and looked at the hood of my Audi A5 Sportback, and the only place that I see these corners are near the A-pillars. The cuts are similar but probably 70% smaller and closer to the corner.
03-23-2024, 11:35 PM | #13 |
In The Rain
8174
Rep 6,259
Posts Drives: '24 GT4RS, '24 Macan GTS Join Date: Mar 2015
That is not a bad install, it is the plotter and how close it is. Some times you get lucky and it is very close, some times it isn't. Wrapping PPF all the way to the edge is not an indication of a good installer.
Too many people who are told, tucking everything in, is some miraculous thing when it comes to PPF and all that brings you later is headaches because PPF on the edges lifts. Installers won't tell you this, and when those tucked edges lifts, they trim it they end up being the same anyway. It is not a big deal. Good installers, you can ask them to do things a certain way and most will tell you the risks of doing things a certain way. If you have a preference, let your installer know and see what they say. Trust is the most important when it comes to PPF installers and of course the installer's experience in the field.
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
03-23-2024, 11:54 PM | #14 |
Rep 1,459
Posts Drives: 2023 G81 M3 Touring Join Date: May 2012
My corners don’t look like that, and you’d definitely notice as it’s a satin PPF on a Black Sapphire Metallic car.
03-24-2024, 06:25 AM | #15 | |
Rep 3,962
