European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      12-21-2018, 09:41 AM   #221
JoshFND
Drives: M4 shopping
Have seen some amazing set ups here.
Think I'm close but want to get some feedback if possible.
For a M4, and I have had all previous cars with aggressive[IMG][/IMG] fitment, coils and slightly stiffer spring rates.
(rear and front of my old car... coils, rear lower and upper Adj arms, camber plate and stock body panels minus a light fender roll..
20x 9.5 and 20x10.5 daily driven..)
For the M4..
option 1
19x9.5 + 35
19x10.5 + 22
Option 2
20x9 + 20
20x11 + 25
I don't mind a slight stretch on tires to accommodate the lower offset and fitment...
Will any of these options work??
      12-21-2018, 10:38 AM   #222
LOW4LYF
LOW4LYF's Avatar
2163
Drives: E92 M3 & F85 X5M
20x11 et25 with 285/30 PSS works without any issues.
JoshFND228.50
      12-22-2018, 04:02 AM   #223
AK.
AK.'s Avatar
137
Drives: E90 M3/E92 M3
2010 E90 335i  [10.00]
Looking to run 18x10 18x11 with 275/305 tire setup without rubbing.
What is the ideal offset to run for front and rear?
Any benefits running 18x9.5 over 18x10 for the front?
What is the lowest offset I can run on 18x10 18x11 without rubbing on 275/305 setup?
Planning on being lowered on CO's as well.
      01-03-2019, 04:23 PM   #224
Padfan9
Sergeant
Padfan9's Avatar
Drives: 2022 M8 Competition Coupe
Any chance you could post the same info for the competition and CS wheels, sizing, tires, color options?
'22 F92 M8 Competition Coupe - Frozen Brilliant White | 8 Speed DCT | Sakhir Orange/Black Full Leather | M Perf CF Exterior Package | M Perf. CF Exhaust | BBS FI-R 21" Wheels |
      01-19-2019, 08:05 PM   #225
spy963
Drives: 2017 F80 M3
Tire size please ?
20x9.5 ET 22
20x10 ET40 or 20x11 ET35
I have KW HAS on the M3. I don't want to rub and I don't like stretched tires.
What do you suggest ?
Thanks !!
      01-22-2019, 10:50 AM   #226
LOW4LYF
LOW4LYF's Avatar
2163
Originally Posted by spy963 View Post
Tire size please ?
20x9.5 ET 22
Thanks !!
20x10 & 20x11 265/30 & 285/30
20x 9.5 & 20x11 265/30 & 295/30
Just to have same stretch front & rear
Edit: in both cases you gonna have some stretch....
      01-23-2019, 09:43 AM   #227
M3SemiSlow
Drives: 10' OME X, M3, glc43
Originally Posted by dongerkim View Post
This will 100% not work. Im running 19x10.5 +32 295/30/19 and I barely fit (sometimes rub on steep hills)
Set-up looks good..
Do you by any chance have some more shots of your car with the rims? Are those E88.
Thanks
      01-25-2019, 06:25 PM   #228
jbijster
Netherlands
Drives: BMW M3 F80 competition Mineral
Thx for the info
Thx for the info. I used your info for buying wintertires.
Regards
John
      01-25-2019, 07:13 PM   #229
jacobe92
jacobe92's Avatar
Drives: 2016 Hell Rot F80 M3
Offsets
I have this in my staggered set up. 18x10 et 22 and 18x11 et 43. I chose et 43 to be able to accommodate a 315/30/18 tire if need be.
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
      02-24-2019, 10:11 AM   #230
arrivederci
Drives: F80 M3
Question for the brain trust here. I have a set of VMRs that came off my wife's old F31 that I want to re-use as a winter setup on an F80.
18x8.5 ET35
18x9.5 ET45
Looks like the offsets are all wrong for the F80 but I can correct that with spacers? Or am I trying too hard to make these work? I think I can safely run 255/40 (not 255/45) R18 all around.
Thanks in advance.
      02-24-2019, 10:49 AM   #231
CRRobert
Drives: 18 Avus Blue ZCP M3
For the front, 12mm spacers would have the outside as same as stock. Would have to check for the rear, it is 14 mm if you had 8.5et35 in the rear like I do. I did some comparisons using the 1010tires calculator.
Tire size is taller than stock, but might be fine on stock suspension.
      02-24-2019, 11:39 PM   #232
arrivederci
Drives: F80 M3
Oops. Meant 255/40 R18. Will update post above.
Having 2nd thoughts - can't find unstudded Hakka's in that size for 18s. Can get 255/35 19s tho. Might have to pony up for new 19s in correct offset w/o spacers.
      02-25-2019, 05:30 PM   #233
CRRobert
I am running 255/35/19 PA4 on my 340 and trying too figure if change for next winter. Would really like Hakka 9 w/o studs, hopefully before next winter. I have 19x9 et 35 with 10mm spacers that work fine on my M3 I would put on.
      02-27-2019, 07:26 PM   #234
ny2nj
Thinking of running 20x10.5 et22 w/ 275/30 tires...Any advice? Would this work?
      03-07-2019, 01:02 PM   #235
LOW4LYF
LOW4LYF's Avatar
2163
Yes... I had 11" ET25 with 285/30 PSS
      03-09-2019, 02:03 PM   #236
Stormshadowm3
Drives: 2018 F80/M3
Originally Posted by LOW4LYF View Post
Running 20x12 with 305/30
what suspension are you running with this setup?
      03-09-2019, 07:19 PM   #237
arrivederci
Drives: F80 M3
Went with Apex EC-7, 19x9.5 ET22 for the winter setup. The Hakka R3 big blocky treads squirm and slip like mad on dry roads. Fun, although I hope I don't burn through them before the next snow!
      03-09-2019, 07:25 PM   #238
CRRobert
Hey, can you get a shot of how flush the rears are? Tempted to get these rims for next winter.
      03-10-2019, 10:03 AM   #239
NTMR_M3
NTMR_M3's Avatar
311
Drives: 2018 Imola Red M3 ZCP
Having an issue with my fronts rubbing on my Coilovers (KW V3)
Wheels are 20x10 +16 w/ 265/30/20 PS4S
The inner barrel was rubbing on the spanner nut, and tire rubbing the spring. Threw 5mm spacers on and it is still rubbing I haven't got an alignment done yet (but my previous wheels were pretty close to the same spec (only in 19s) and I had no issues.
Any ideas? Wheel co. doesn't think they should be rubbing either. Is my tire too wide?
      03-10-2019, 01:17 PM   #240
arrivederci
Drives: F80 M3
Does that help?
      03-10-2019, 05:41 PM   #241
CRRobert
thanks
      03-11-2019, 02:26 PM   #242
LOW4LYF
LOW4LYF's Avatar
2163
KW HAS
f80post
