2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing How light is your car?
      07-09-2021, 07:35 AM   #1
Jamesjedi
Jamesjedi's Avatar
Drives: NA
Anyone building a lightweight car? At roughly 3400 pounds, there is some weight to loose.
A 911 is lite to begin with. Here is 438 pounds of additional weight loss.
http://forums.pelicanparts.com/porsc...d-story-3.html
      07-09-2021, 10:59 AM   #2
aerobod
Car Geek
aerobod's Avatar
3727
Drives: Caterham R500, M2-G87, Macan S
It depends on what you are trying to achieve with weight loss, but if it is for hard track use, it is better starting with a light car to begin with and add power, as opposed to starting with a powerful car and trying to lose weight. I would class a light car as being something below 1000kg / 2200 lbs, not many cars that are currently produced can meet that criteria.
If it is just for a lighter car for road use, I'm not sure if it is worth lightening a car for the marginal benefits vs the major downsides in terms of cost, noise, reliability, resale value and loss of integrated systems due to the best weight saving coming from stripping everything from the interior other than the drivers seat and controls.
      07-09-2021, 11:44 AM   #3
msendit
msendit's Avatar
424
Drives: M240i
3570 full tank and 150-lb driver. This would be ~3300 empty.
I've done some of the basic weight reduction things, but there's an easy, say, 150 more in battery, ac, doorcards.
      07-09-2021, 06:04 PM   #4
dradernh
dradernh's Avatar
4487
Drives: 2017 M240i
3,603# with 170# driver and 1/2 tank of fuel.
I don't think these cars will ever be lightweight, nor will they ever be middleweight. They're on the low end of light-heavyweight.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro;
GTechniq Crystal Serum Ultra Ceramic; Suntek PPF
      07-10-2021, 08:32 AM   #5
Jamesjedi
Jamesjedi's Avatar
Drives: NA
Hope to weigh mine. Track edition. Should be lighter than most.
Weigh is definitely removable. It can get expensive to do. Lightweight batteries etc.
Track cars would be lighter. Usually done with ac, seats, and other big heavy not necessary parts.
Curious to see if anyone has stripped theirs out and how much weight was lost?
      07-10-2021, 02:51 PM   #6
Maynard
Drives: 228iX & M2C
Rear seat delete is supposedly good for nearly 50#, and there are lithium batteries that are under 10kg (think that is probably saving another 20# or more). Track buckets will also save some, but you put it back with the cage.
      07-12-2021, 01:36 AM   #7
ngl
ngl's Avatar
120
Drives: BMW 228i
~1480 kg with full tank.
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger | LithiumNext Battery
      07-13-2021, 06:21 PM   #8
PeanuKeeyes
PeanuKeeyes's Avatar
368
Drives: E34 | MX5
3,260 lbs with about 3/4 tank. Tad over 3,430 with the driver.
E34 525iT 5 spd | 228i ZTR 6 spd [SOLD] | MX-5 NA 6 spd
      07-14-2021, 01:33 AM   #9
230iZTR
230iZTR's Avatar
322
Drives: Signal Orange wrapped 230i THP
I'm sitting at 3352 lbs with ~3/4 tank without driver.
17x9 APEX Arc8-R, 255/40/17 RE71RS, Vorshlag Plates, Swift Spec-R Springs, m-Performance Bumpstops, Dinan ShockWare, Paragon 2-piece rotors, Carbon lip, custom 3" alumalite splitter, GTS wing, FTP Intake and Charge pipe, BootMod3 Stage 1 OTS
      07-15-2021, 02:50 PM   #10
Jamesjedi
Jamesjedi's Avatar
Drives: NA
Old 911’s are light to begin with. Not a stiff chassis by today’s standards.
This is an example of the effort involved in getting a race car very light. It is expensive to do.
http://forums.pelicanparts.com/porsc...1971-911s.html
There is always weight to lose somewhere.
      07-15-2021, 02:53 PM   #11
Jamesjedi
Jamesjedi's Avatar
Drives: NA
I would love to do it to my car, it is too nice a car to strip and devalue. That does not mean that I will not do it in the future.
      07-16-2021, 08:55 AM   #12
dradernh
dradernh's Avatar
4487
Drives: 2017 M240i
Do it part-time if you can. I could (and did) remove an even 200# from my V70R, and then I put it back. It took 30 min. each way.
That car may have been an extreme case, though.
      07-16-2021, 10:28 AM   #13
msendit
msendit's Avatar
424
Drives: M240i
Y'all are a bad influence It's 3530 now, finally got rid of the massive OEM battery.
The replacement (40Ah AG) battery is actually not that light at 14 lbs, but with how often these cars disconnect the alternator, I didn't wanna push it too far.
dradernh4486.50
      07-16-2021, 02:27 PM   #14
Jamesjedi
Jamesjedi's Avatar
Drives: NA
At a certain point the 911 guy said it cost about $100 per pound.
The battery is a great example. The OEM is super heavy.
Hope to weigh it nest week. It is the "M performance" track edition from 2015. Parts bin special really. I really like it. OEM engine oiling - I hope to address w/M2 bits.
I had to look up the VR 70; station wagon! love it!
      07-16-2021, 02:48 PM   #15
dradernh
dradernh's Avatar
4487
Drives: 2017 M240i
Me, too! I took it to Lime Rock Park, New Hampshire Motor Speedway, and Monticello Motor Club. It was an understeering AWD car, but if you worked within its limitations it got around MMC and LRP pretty well. NHMS, not so much - that's a pure handling track. The only mods were a mild tune from IPD and Castrol SRF brake fluid. The buyer got a very good deal when I sold it for $24K with 24K miles on it.
      07-29-2021, 08:33 PM   #16
msendit
msendit's Avatar
424
Drives: M240i
OP, don't keep us waiting here. How light is the Track Edition? Did you take it out already and shame a GT3? So many questions...
      08-07-2021, 12:42 PM   #17
Jamesjedi
Jamesjedi's Avatar
Drives: NA
My car is 88 pounds less than standard M235.
If I pass a GT3 they are not driving their car fast.
I'm not Fangio, I'm having fun
I have been fiddling with P cars since 2002. I had an air cooled Carrera, 944 and a project race car - 1977 911 S that I never finished. That project and the others were sold to pay for bills and kids sports.
M235 is a bargain. That said I do want a Cayman. They are too expensive, but their depreciation is less.
The Caymans have similar issues to the M235I. Oil starvation, difficulty in finding one with an LSD. Not to mention bore scoring. The 2.7 L does not suffer from for scoring. Neither do the 2009+ years. At a certain point, you're not gonna be any happier. There's always going to be a better or faster car.
Today I am chewing over purchasing a set of PSS10 Bilstein coil overs. What I will have done to my car, I would have wanted done to a Cayman (assuming it is a 2.7). That is; a baffle, camber plates, wheels, tires and Bilstein.
      04-30-2024, 06:14 AM   #18
hydra
Flaccid Member
hydra's Avatar
68
Drives: E82 135i 6MT F22 228i 6MT
Necro bump I know, but I'm at 1390kg with 1/4 tank of gas
BSM 2010 Euro 135i 6MT with many mods...
http://www.1addicts.com/forums/showthread.php?t=1264997
VO 2014 228i 6MT with too much M goodness to list, quite possibly the most heavily modified 228i anywhere!
2addicts
