03-14-2011, 01:28 PM | #1 |
Rep 691
Massive E36 Build w/ TONS of pictures (HP Autowerks, Clutchmasters, Red Line Oils
(I know it isn't e82 specific but a lot of the stuff is similar to your cars. Plus HP AUTOWERKS was a HUGE help! Thank you!)
I’ve come to the conclusion that I will probably always have an e36 in my life in some form or another, whether it be a DD, a project car or a weekend toy. I’m on my second e36, third in the family, the first being the auto 328is, and the second, a ’99 5 speed m3 and the third is my brother’s alpine/Modena m3/4. When I bought it the clutch was going and it had always bothered me but it’s my DD so I didn’t really have the luxury of having it out of commission. The clutch wasn’t horrible but I definitely could not launch the car. Before I had bought the M3, I was in the process of acquiring parts for an auto to manual swap conversion on my 328. The parts I had acquired included an e46 m3 transmission. I finally bit the bullet and installed the transmission that had been taking up space in my shed for the past two years along with a whole other list of goodies. THE CAR FEELS LIKE NEW! I think this is the closest anyone will ever get to replicate the feeling of first driving a brand new e36 m3 off the lot. I have to give a HUGE shout out to Peter, Aaron, Hector and Harold at HP Autowerks for helping me with the project. They allowed me the use of the lift, tools and knowledge. This shop is top notch! They are extremely well known in the E9X realm and have built many project cars, one of which is in the shop right now, a STG2 HPF M3. Check them out at www.hpautowerks.com I also have to thank the guys at Red Line Oil for their help. Their products are great and I feel like my new parts are protected. The last thing you want to do on a build like this is cheap out on your car’s fluids and grease. Another shout out goes to Travis at Clutchmasters for getting me a clutch on such short notice; I was originally going to use a OEM e46 M3 clutch but I decided I did not want a self adjusting unit. The FX100 is great and very streetable as I expected. Lastly, thank you to everyone on the forums. I’ve learned a lot of information in the time I have been here and some of your DIY’s helped me on this very build. Hopefully this build will inspire more people that just because e36 m3’s are cheap, they don’t have to thrown to the dogs, outfitted with racelands and slammed. They are great cars, just put the time into them and they will return it ten times in driving enjoyment. To each their own. List of parts in the build: E46 M3 6 Speed Transmission Clutchmasters FX100 Clutch Kit New E46 M3 Dual Mass Flywheel Rogue Engineering Euro E36 6 Speed Short Shift Kit Euro E36 M3 Tranmission Mount Euro E36 M3 Driveshaft Euro E36 M3 Subframe Euro E36 M3 Large Case Diff (210MM) E46 M3 3.62 Ring and Pinion BMW Motorsport Shim Kit New Subframe Bushings New Diff Bushings and Diff Hanger S54 Oil Pan S54 Oil Pump w/tack welded OPN S54 Oil Filter Housing Euro E36 M3 Oil Cooler Black Anodized -10AN Fittings Earls Pro Lite Braided Hose VDO Gauges (Water, Oil Pressure, Oil Temp) Leatherz Gauge Panel ARD Oil Distribution Block Oil Pressure Sender, Oil Temp Sender, Water Temp Sender -3AN Hose to Remote Mount Pressure Sender Power Steering Oil Cooler Mishimoto Aluminum Radiator Stewart High Performance Water Pump Evosport Underdrive Pulley Kit ZHP Shift Knob AC Schnitzer Pedals and Handbrake (courtesy of Jon) New Belts New Pulleys Rebuilt Half Shafts Using Red Line CVV2 Grease New Parking Brake Shoes New Rotors (Brembo Front, Zimmerman Rear) New Pads (Stoptech 304s) Stainless Steel Brake Lines Stainless Steel Clutch Line E36 325I Slave Cylinder w/ CDV delete AKG Delrin Clutch and Brake Pedal Bushings AKG Motor Mount Reinforcement Kit Bimmerworld RTAB Pocket Reinforcements Vorshlag RTA limiters Rear Main Seal Rogue Engineering Transmission Mounts w/ UUC Enforcer Cups New Motor Mounts Transmission Seals (input shaft, output shaft, selector rod seal) Red Line 10W40 Synthetic Motor Oil Red Line 75W90 Differential Oil Red Line CV-2 Grease Red Line Assembly Lube Red Line D4 ATF Red Line Water Wetter Red Line Complete Fuel System Cleaner And TONS more that you’ll see in the pics. Pretty much anything that could be replaced and seemed logical to replace, was replaced. All rubber got replace except for LCAB and rear shock mounts that will be changed when I install Moton Street Sports along with new control arms and tie rods. To the pics: Look at all that rubber! VDO Chrome Vision Gauges to match OEM Z3 M Cluster Aluminum Radiator and Oil cooler (the oil cooler was too large to be used and was substituted for a OEM e36 oil cooler. Before anything has been touched Flushing the powersteering system and preparing for new lines and cooler. Old pullies and tensioners The belly of the beast. Red Line Assembly Lube to prime the S54 dual pick up oil pump Mounted the pump up. Oil pump pick up tubes and misc parts Oil pan cover and engine mount reinforcements. Stewart High Performance Water Pump Everything mounted. Tacked up, that nut isn't backing off. The pan up and in. Oil drain line and dipstick. The rear main pick up tube. The water pump installed Old oil filter housing out. S54 oil fitler housing mounted (-10AN VAC adapter) with ARD distribution block, remote oil pressure line and oil pressure sender. Old, dirty rear end Front subframe out E36 M3 autotransmission cooler that I will use for a custom power steering coooler. Mounted up, but its final position will be much different. This spot had clearance issues with the oil cooler. MMMMM, yum. Look at all that Red Line Oil goodness. Front subframe out Prepping All done, just needs to get hit with paint Old driveshaft and trans Everthing out of the car from the engine block back Rogue Engineering Euro E36 6spd Short Shift Kit RTAB Before Vorshlag RTAB Limiters Installed Rear Pockets Cleaned Up Repainted Large Case Diff cover with new speed sensor, gskt and bracket Dismantling the rear end Subframe Out New Rear Main Seal Packing the halfshafts with Red Line CV-2 Clutchmasters FX100 E46 M3 Clutch Kit. Sucks I won't see. New E46 M3 DM Flywheel E46 M3 Transmission New Input Shaft Seal New Fork Lever, 850CSI metal pivot ball, etc New Brakes Rear Euro Subframe and Rear End Mounted Tansmission Mounted with SSK and New Rogue Trans Mounts. Ended up flipping the shift rod to connect from the left side (opposite the pic). Evosport Underdrive Alternator Pulley All new pulleys, tensioners and belts. What $250 worth of metal motorsport specific shims looks like. Not very impressive I know. I couldn't believe they costed that much. Spec'd out There has to be a combo somewhwere in here to get the right backlash. Old shims for the 3.23 ratio Gear marker paint. It had a fantastic contact patch The output shaft bearings Found the perfect combo Diff ASSEMBLED! Power steering cooler was moved to a side exit. Nice clearance and not contacting the radiator or condenser. Halfshafts just waiting for the final piece. And there it is! Woop, there it is, looking so clean. New dipstick placement New Clutch pedal installed with Delrin Clutch Pedal Bushings Delrin Brake Pedal Bushing All wrapped up Build was completed as of January 1st, 2011. How it sits as of 3/7/2011. |
03-14-2011, 02:30 PM | #4 |
Rep 8,801
"it's no running anymore?"
you gave her a second life and it lasted 2 months. fun while it lasted. i'm sure a 3rd life is in order. put another quarter in the machine.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
03-14-2011, 02:44 PM | #5 |
Professional Moose Racer
316
Rep 7,509
1. Need pics re-hosted
2. IbtM
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
03-14-2011, 02:45 PM | #6 |
boku no namae ha...
336
Rep 11,025
Posts Drives: 2006 BS 330i Join Date: Feb 2006
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
hahaha nice ending i guesss
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
03-14-2011, 02:59 PM | #8 |
What
141
Rep 9,325
damn such a bad ending after all that work
E92 328xi Space Gray
Aero Lip | M3 Side Skirts | CF Performance Spoiler | ACS Roof | Gloss Black Grilles | LUX H8 Angels | BMW Performance Exhaust My E92 Photos |
03-14-2011, 08:27 PM | #9 |
Rep 3,214
Posts Drives: f25 X3 AW Join Date: Aug 2010
Garage List 2004 e46 M3 AW RETIRED [0.00]
2003 e46 M3 CB RETIRED [0.00] 2013 f25 X3 AW [0.00] 2007 e92 328i SG RE ... [0.00] 2007 e90 335i AW RE ... [0.00] |
my 8==D got limp. sucks to see the car go like that.
