ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      03-27-2011, 10:32 PM   #133
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Originally Posted by Samjam927 View Post
BUMP! any help would be greatly appreciated
It'll work and you can go wider. I have 245/40-18X8.5ET35 & 275/35-18X9.5ET22 with OE height and setup. No rubbing whatsoever.
      03-27-2011, 11:01 PM   #134
Samjam927
The One And Only
Samjam927's Avatar
15
Drives: 2006 TiAg ///M Roadster
2006 Z4M Roadster  [10.00]
2003 Z4  [5.00]
thanks! any way u could toss up some pics of your car?
      04-16-2011, 10:27 PM   #135
boondocksaint
Penfold, shush!
boondocksaint's Avatar
Drives: 07 Z4MC
I'm planning on an 18x9 F and 18x10 R setup. 07 Z4MC
I have the option to specify my ETs, so I'll ask the experts.
I would *like* to get 255s in the front and 285s in the rear. This is for a track setup on stock suspension (at the moment, though I doubt I'll ever drop the car more than half an inch, ever).
The question is: what ETs should I get for those wheel sizes, and what aspect ratio of the tires to get it close to stock? I'd do the math but the last time that happened, I...well, MATH IS HARD.
      04-17-2011, 07:37 AM   #136
onebluemcm
onebluemcm's Avatar
45
Drives: '07 Z4MC
18x9 et42
18x10 et30
If in doubt, go a tad higher on the offsets so you have the option of using thin spacers to get it perfect. Lots will depend on tire brand and model and the specific shape of the tire.
Expect rubbing - even with dead on perfect offsets, 255/40 and 285/35 is a tight fit on this car - trust me
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      04-17-2011, 09:50 PM   #137
boondocksaint
Penfold, shush!
Drives: 07 Z4MC
Thanks. Should I drop down to 245/275 then, to be safe? Proper fitment is my primary goal.
      04-20-2011, 10:15 PM   #138
jdl1pt
Drives: Z4M coupe 2007 IL Blue
anyone know if these will fit...owner say will fill on z4mc
VMR VB3
Bolt Pattern:
5x120mm
Center Bore:
72.6mm
19"x8.5" +40mm Front
19"x10.0" +25mm Rear
Thanks in advance!
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit|
      04-21-2011, 04:49 PM   #139
Beedub
Drives: 2007 Z4 M roadster vt2-500
VMR VB3
Bolt Pattern:
5x120mm
Center Bore:
72.6mm
Thanks in advance!
on an 8.5" rim you really want to ge that offset down to +32 to +35, that'll give that lovely flush look upfront and will not rub on stock ride heights, the rears will be flash and work perfectly......
as is the fonts will looken sunken in the arch and wont look ideal imo.
i love +32 offset with alittle camber upfront.... PERFECT!!
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      04-21-2011, 07:49 PM   #140
boondocksaint
Penfold, shush!
Drives: 07 Z4MC
Originally Posted by onebluemcm View Post
18x9 et42
18x10 et30
Bump.
      04-21-2011, 08:30 PM   #141
boondocksaint
Penfold, shush!
Drives: 07 Z4MC
Also considering some Enkeis on TireRack.
NT03
Front = 18x8.5 ET38 (18.6 lbs)
Rear = 18x10 ET25 (20.5 lbs)
What do the experts think?
      04-21-2011, 11:14 PM   #142
jdl1pt
Love this forum. Thanks!
      04-24-2011, 10:49 PM   #143
Kgolf31
Kgolf31's Avatar
461
Drives: 2007 Z4MC, 2012 128i
Hey Guys.
I'm looking for autocrossing wheels.
I want to go 225s in the front and 255s in the rear.
Can I go 18x8 ET 35 in the front and 18x9 ET 20 rear?
      04-28-2011, 10:32 AM   #144
jdl1pt
Will these fit?
Fronts: 19x8.5 et 32
Rears: 19x10 et 25
      04-30-2011, 04:56 AM   #145
Beedub
Will these fit?
Rears: 19x10 et 25
get that rear to 9.5" and your talking the perfect z4m setup in 19" sizes :-)
this will be flush all round and will be able to take small increments of lowering also :-) tyre choice is paramount also.
      05-12-2011, 02:38 PM   #146
604BrO
///M GENERAL
604BrO's Avatar
Isle of Man
51
Drives: M
hey guys can anyone tell me if these will fit.. 19" te37 rep's
19" all round
9.5 et +20
10.5 et +22
on my 2006 z4m roady
      05-12-2011, 02:55 PM   #147
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
Fronts are like 15mm too aggressive with stock suspension/camber setup.
The rears are pretty aggressive too and you will probably have to pull fenders to prevent rubbing.
These are very close offsets with Crfine's TE 37 SLs... which are seriously aggressive.
      05-12-2011, 03:16 PM   #148
ZStig
instagram 997turbotom
284
Drives: Interlagos Z4MR
really good calculator here, that takes tires into account
http://www.rimsntires.com/specs.jsp
      05-17-2011, 12:13 AM   #149
Mr. Jones
Drives: Z4 MC
Hello everybody, I'm new here, I'm from Belgium and I just bought a 2006 Z4 M Coupe. I have found some nice BBS LM's with these specs:
Front 19 x 8.5 ET38
Back 19 x 9.5 ET20
Will these fit without rubbing ? Is the wheel at the back going to stick out of the fender ? (I hope not) And what would be the perfect tires for these wheels ?
Already thanks and I hope my English isn't too bad
      05-17-2011, 10:46 AM   #150
Mirko
Mirko's Avatar
Drives: E86 Z4M, E90 328i, E84 X1
Hey guys
I have a tire shop putting together a winter tire package for me and they state that the following will work. I am doubtful after reading this thread that a 17" will fit over the brakes. What do you guys think? It is for a Z4M. Thanks
17" rims with 40 ET
225/45/17 tires and 225/5017 tires
      05-24-2011, 01:35 PM   #151
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
Originally Posted by Mirko View Post
Hey guys
17" rims with 40 ET
Some 17"s will clear the stock brakes while some will not. To be certain you should just try one of the wheels on.
As for tire sizes, if you want a squared setup the correct tire size for 17"s is 225/50/17 all around. 225/45/17 is too thin of a sidewall.
You never mentioned the width of the rim, that is important too when you mention offset. If they are 8" you are fine in the front but you will need a significant spacer at the back to keep the wheel from being tucked under the fender.
      05-24-2011, 03:25 PM   #152
BTM
Drives: A///MERICAN!!!
Hey guys
17" rims with 40 ET
Here is my Z4M on 17x8 ET40 OZ Ultraleggeras
      05-26-2011, 06:07 PM   #153
Mirko
Mirko's Avatar
Thank you BTM & Daemonblitz for your posts. I will try and stop by the guy's shop Saturday to do a test fitting and will report back.
I don't know the width of the tires, he didnt mention that but I am going to assume at least 8"
BTM ... How are those rims to clean? They look good!
      06-27-2011, 08:35 PM   #154
Bigmac834
Drives: 2008 Z4 M Coupe
If someone could help me out, I'd appreciate it. I'm pretty new to this site, as I have just been a spectator every since buying my z4m coupe. However, I have come across some ccw wheels and want to know if they would fit.
18x8.5 et38 fronts
18x10.5 et19 or 18x10 et18 rears
Thanks in advance!
zpost
