| 12-11-2024, 11:10 PM | #23 |
![]() 717
Rep 1,096
I like to clay bar the outside of the windshield, and ISO alcohol on the inside for the plastic vapors. The glass cleaner product doesn't really matter, I have good luck with the cheap concentrate stuff from home Depot. It's all about the clean towel. Also wax on the outside of the windshield is nice, the rain just rolls up. That and a little of the gummy fledge rubber conditioner on the wipers is great for the rain.
jwmFcreek154.00 |
| 12-11-2024, 11:59 PM | #24 | |
![]() 177
Rep 153
jwmFcreek154.00 |
| 12-12-2024, 12:19 PM | #25 |
Rep 2,213
jwmFcreek154.00 |
| 12-13-2024, 12:38 PM | #26 |
Rep 72
Using news paper worked great till they took the lead out of news print ink. The lead in the ink would actually polish the glass and provided great results. So if you have any pre 60’s news paper lying around give it a try.
Another cheap fix was deionized water and a bit of vinagar. Works great on outside windows. |
jwmFcreek154.00 |
| 12-13-2024, 02:29 PM | #28 |
Rep 2,417
Posts Drives: F85 X5M, F80 M3 ZCP Join Date: Dec 2019
Some people even go so far as to have all their glass ceramic coated. No streaks whatsoever.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
jwmFcreek154.00 |
| 12-18-2024, 08:56 PM | #29 |
Rep 29
I do this day in and day out for the past seven years. This is what I’ve found to work the best.
For exterior glass simple wipe on/wipe off after washing the car and clay bar if needed. Start with saturating a waffle weave towel with glass cleaner for your “cleaning” towel. I typically do the perimeter of the window first then work the middle, switch over to a plush MF buff off with one side, flip over and do another light buff. For interior glass it can be a bit tricky especially if it’s a humid climate or if there’s noticeable oil build up on the glass. If it’s humid, I typically wipe it with the “cleaning” towel and let it sit for a few minutes before buffing with my second MF. If there’s oil build up (typically on the windshield) I have a bit of a procedure. I use a little bit of dawn dish soap in a bucket of warm water with scrub pad (I’ll link it below) but only use the scrub pad on glass that is not tinted! If it is tinted you can use a clean mf towel or applicator. Get the bucket of dawn nice and sudsy, wipe the window down then use a squeegee to dry the glass, you’ll need a second towel for clean up. I go around the entire car first doing this process then use the waffle weave and glass cleaner starting with the first window I used the dawn on. I’ll link what I use below, hope this helps! My favorite glass cleaner so far https://a.co/d/8nb3gfe I cut these into thirds https://a.co/d/68pfewj “Cleaning” towel https://www.detailedimage.com/wax.ph...92/16-x-16-S1/ Buffing towel https://www.detailedimage.com/wax.ph...54/16-x-16-S1/ |
| 12-19-2024, 09:09 AM | #30 | |
![]() 160
Rep 252
| 12-19-2024, 10:55 AM | #31 |
![]() 717
Rep 1,096
I would recommend just trying the iso alcohol on a paper towel on the inside of the windshield instead of the whole mess with soapy bucket and towels everywhere.
Also I don't have one but they sell those little stick mop things to help clean the inside of a windshield. My mother has a Honda Civic where the dashboard is about 8 ft long and you need that to reach the glass. When I washed cars professionally back in high school, cleaning the inside of the windshield was always the thing we dreaded the most, I would have loved to have one of those things then. |
jwmFcreek154.00 |
| 12-19-2024, 04:54 PM | #32 | |
Rep 2,453
We used Dawn liquid dish soap in a tray with some water. Put the eye glasses lenses down submerged in the very soapy water -- submerged enough the nose pads were submerged -- resting not on the tray bottom but on a clean towel laid down and covered by the soapy wat4er -- then after a bit remove rinse under hot running water. Dry with a *clean* towel. There was a sonic cleaner too. But most glasses -- way back when -- were fitted with glass lenses and soapy water, clean rinse water, toweling off worked very well. I left the business just as plastic lenses started to make significant inroads. Anyhow, to clean auto glass -- inside and out -- I rely upon Windex then a wipe down with a clean soft cloth towel. I repeat until no more streaks. I start out with a stack of clean towels. After all the cleaning is over with the towels go into the wash with some laundry soap and bleach. Then the dryer. No dryer sheets. Back on the auto glass: It helps to have the car facing a low sun -- but not a hot sun -- to better see any streaking or missed areas, etc. Cleaning the inside glass especially the windshield and rear window are my least favorite tasks in keeping my cars nice. |
jwmFcreek154.00 |
| 12-21-2024, 02:38 PM | #34 |
![]() 154
Rep 113
Posts Drives: Xm Join Date: Aug 2024
Great tips on window cleaning … changed directions of cleaning outside the car to inside . Very great comments .
Started using Adam’s window cleaner and window towel and truly had the best of luck with the Adam’s so far . |
| 12-21-2024, 03:16 PM | #35 |
Rep 188
Don't you guys have concerns damaging the antenna lines on the rear window when you use isopropanol?
For the rear and front window I am using this tool below after: 1. Piece of an old terrycloth towel, stolen from mom or wife, moisturized with i-Propanol (except of the rear window); 2. Another such piece half-soaked with a water/one shot kitchen cleaner/one drop dishwasher mixture (not over-dosed!); 3. A third piece, dry and applicated at once after task 2. is done. 3a. If practicable, use instead of 3. a small, soft(!) rubber wiper without any pressure and hold with the other hand a cloth below the wiper to collect the superfluous (word game) liquid. A friendly professional window cleaner guy gave me this advice. He mostly refuses to use commerial glass cleaners.
The fact is I don't drive just to get from A to B. I enjoy feeling the car's reactions, becoming part of it.
Enzo Ferrari |
| 12-23-2024, 06:10 AM | #36 |
![]() 154
Rep 113
Have to say I absolutely loved everyone’s thoughts and comments on the glass it helped me thank you . Was kicking my butt
I tried everything … my shop lights would show glare through the window until I used this Adam’s glass cleaner … a waffle micro towel to clean and like many here said another towel to finish and Adam’s green glass towel with two different surfaces woukd finish the glass perfect . Not a Adam’s spokesman could careless what product works … but for me this did it and swear the BMW glass in the XM is far more touchy then the GM glass no question . But found a answer |
slilley245.00 |
| 12-23-2024, 08:05 AM | #37 |
Rep 277
I use Bilt Hamber Traceless with a good microfiber towel. I’ve tried ALOT of different window cleaners and this one is by far, and I mean by a wide margin, the best window cleaner you can buy. It leaves zero streaking or hazing. Yeah it’s expensive but I’ll take it for super clean windows. Also, I even use on the dashboard screen and it removes all finger prints and smudges. It’s super annoying when you clean the screen and there are still smudges but Traceless does a great job at removing everything.
jwmFcreek154.00 |
| 12-29-2024, 09:47 PM | #38 |
Licensed Professional Slacker
2833
Rep 1,420
Posts Drives: 2026 M4, 2025 i4 M50 Join Date: Mar 2019
My go-to glass cleaner is 1 part white vinegar, 1 part Isopropyl Alcohol (usually 70%) and 4 parts distilled water mixed into a spray bottle. Works very well. 👍 I have used spray glass cleaner before and I've found Stoner Invisible Glass is much better than Sprayway.
The Dunning-Kruger effect - Stupid people are too stupid to realize how stupid they are. |
jwmFcreek154.00 |
| 01-06-2025, 08:16 AM | #42 |
![]() 340
Rep 182
Posts Drives: 2025 M4 Competition Join Date: Jun 2024
Greetings,
A couple of ideas: 1. Use Griot's Rinseless Car Wash and rub back and forth and up and down...dry with microfiber or cotton towel using same motions. 2. Try using a squeegee on the glass. Dry squeegee after each swipe. 3. Use a mixtures of Dawn (a few drops) and water in a spray bottle. Use a sponge on the inside of the window with the Dawn mixture. Semper Fi |
jwmFcreek154.00 |
| 01-06-2025, 08:56 AM | #43 |
Rep 2,417
ooh rah........Devil Dog
| 01-06-2025, 08:34 PM | #44 |
![]() 340
Rep 182
| Bookmarks |
| Thread Tools | |
