12-28-2016, 08:46 AM | #1 |
BsaintMedia.com
389
Rep 433
Posts Drives: Collection of German Join Date: Jan 2007
My LS6 E36 M3 Burnout/Drift
Nothing crazy just a little year end burnout and shot from my larger video of me doing a little U-Turn.
IG @Bsaintmedia
YouTube << Subscribe | |
12-28-2016, 10:45 AM | #6 | |
BsaintMedia.com
389
Rep 433
and yes of course it does, actually sits lower and further back and weighs less than the s52, and I'm not the one upset lol it also runs on the tears of purists thanks man.
IG @Bsaintmedia
12-28-2016, 01:08 PM | #7 |
1Addict
3237
Rep 7,897
Awesome. Do you have a build thread for that car any where?
12-28-2016, 01:35 PM | #8 |
BsaintMedia.com
389
Rep 433
Thanks man!
I started one back in 2011 on bimmerforums, but after it taking 3 more years I kind didn't update it at all specially considering it was nothing ground breaking at the time and the swaps have been done and documented fairly extensively. Also most of the links are dead thanks to imageshack being bought out and sold. However I'd be happy to answer any specific question if you have any. Typical ones are what kit, whats done to the motor, what trans etc. Kit was Vorshlag Alpha kit, Solid front subframe mount, vorshalg longtube headers, no cats, vorshlag drive shaft into stock M3 diff 3.23 lsd rear. Motor is fairly stock, cam only eps 234/246. I will be boosting it soon. Trans is a t56 from an 02 GTO paired with LS7 clutch and flywheel. Also just made 422whp and car weighs 2,800 lbs
IG @Bsaintmedia
YouTube << Subscribe | Last edited by Bsaint; 12-28-2016 at 01:43 PM.. |
12-29-2016, 09:20 AM | #12 |
BsaintMedia.com
389
Rep 433
hahaha well I guess it's not silly if you've never tried, but every car is different. Mine will do one in first or second just from flooring it and holding the brake, but for these I rev to about 2-3k drop clutch in first gear then quickly stand on the brake. While holding the brake I feather the throttle between 3-4k and let them spin. Then when I feel like I've had enough just let off the brake and ride out the throttle make sure not to over rev. You could shift into second or third if you want to really smoke them. Obviously an auto car or a car with traction control is different you are going to want to turn off everything and just hold the brake and gas slowly feathering the brake so the rear can spin.
That it is! haha thanks man appreciate it! it's pretty quick, but never enough. Run against a GTR
IG @Bsaintmedia
12-29-2016, 02:39 PM | #13 | |
Rep 188
You hold the brake with your left foot and the gas pedal with the right? Also what happens with the rear brakes? |
12-29-2016, 03:07 PM | #14 |
Rep 240
I've done my share of swaps with 240s and such, and the tricky part was always the wiring. Did you sent engine and donor harness to be done, or just buy a plug and play harness ready to go? Once I switched to those, man everything got easier.
12-29-2016, 03:30 PM | #15 | ||
BsaintMedia.com
389
Rep 433
and as you know your front brakes do about 80% of the braking that's typically why they are bigger. Your front should hold it enough to either lock up the front wheels and still apply bits of pressure to the rear which yes is not exactly good for your rear brakes, but its kind of how it is. The only way to apply just front brakes and leave the rear off is to install a line lock, typically drag racers use this who need to burnout more. But for the occasional burnout it's not needed. Quote:
I sold the s52 and trans/wiring harness from the original setup, because everything is controlled through the GM ecu and tuned through it using HPtuners it was a matter of wiring the BMW into the GM computer. Thankfully I did not tackle this as I do not have the patients for it lol. If I was to do it again I would probably just look into a holley dominator efi, specially for boost applications. I'll probably switch to one down the road though.
IG @Bsaintmedia
12-29-2016, 03:42 PM | #16 |
Rep 1,395
Posts Drives: Porsche 993, 2014 MB GLK Join Date: Jan 2015
They slip against the torque, the front brakes hold as they don't get power. It takes a bit of practice as you're trying to just brake enough to keep from moving forward while the rear spins like a demon.
