09-24-2023, 03:59 PM | #23 |
Rep 536
Which ever way you go remember disconnecting the negative under the hood is NOT the same as disconnecting the negative on the battery. The post under the hood is just connected to the frame so you can still short out the positive under the hood if your wrench hits the frame. Just sayin...
09-24-2023, 05:19 PM | #24 |
Rep 825
Also note that the IBS is only located on the rear battery negative terminal (ETA: Li-Ion front has one), so you are GTG connecting the charger directly to the front (AGM) battery terminals.
Two is One and One is None
09-24-2023, 05:36 PM | #25 |
Rep 9
Posts Drives: BMW 750i Join Date: Aug 2023
This is what I'm planning on doing I just didn't know if disconnecting the terminals under the hood should be done with battery connected or disconnected? I'm thinking it doesn't matter but I don't want to risk messing something up doing it the wrong way
09-24-2023, 06:09 PM | #26 |
Rep 883
Convenient and discrete lower grille-mounted CTEK ‘comfort indicator’. (the low level LEDs are only visible at night). Hooks up directly to the forward access point.
I concur that all charging of the car battery should be via the provided under hood connections… https://www.amazon.com/CTEK-56-380-C...dp/B002OHXX60/ Last edited by visionaut; 09-24-2023 at 06:41 PM.. Reason: Added link: CTEK Comfort Indicator Panel |
09-24-2023, 09:41 PM | #27 | |
Rep 1,002
Posts Drives: 2007 Z4 M Coupe 2012 e93 M3 Join Date: Sep 2008
Here is my connector tucked underneath the hood. |
Craw2theJ4.00 |
09-25-2023, 12:36 AM | #28 | |
Rep 9
09-25-2023, 03:05 AM | #30 |
Rep 3,910
How do you know there are no issues? The issue it'll cause is to reduce battery life in the long term. Just because nothing breaks immediately or explodes or catches fire, doesn't mean it is working properly.
09-25-2023, 03:55 AM | #31 |
Rep 19,561
In earlier cars the rule of thumb is to disconnect the earth on battery and charge, on later ones with under bonnet connections just hook to the points and when the green light comes on the CTEK then you're done.
If your car is outside the garage then feed the power cable from behind the bonnet to shut it and lock car while charging for security. |
///M Power-Belgium63391.00 |
09-25-2023, 06:12 AM | #32 |
Rep 837
I disconnected the battery completely, negative terminal first.
Then I attached the eyelets to the same terminals under the hood that the manual states for jump starting. After all was said and done, I reconnected the battery, positive terminal first. |
09-25-2023, 07:23 AM | #33 |
Rep 1,795
Posts Drives: E86 3.0si Join Date: Oct 2011
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
Having the charging connection at the base of the windshield is (for me) a very convenient spot, it's also a spot that you won't forget it's hooked up.
09-27-2023, 11:10 PM | #34 |
Rep 378
My Chrysler and other car manufacturers include a simple unswitched (hot/always-on) 12v cigarette lighter outlet in their vehicles' cockpit for this exact purpose (making it an extraordinarily convenient plug'n'play option). However, I DO understand how other manufacturers (like BMW) leave it out knowing it's likely their owners won't fully appreciate the switched/unswitched outlet difference, leave an accessory on it 24/7, and deplete their battery.
Otherwise, this jerry-rigging of wires underneath your hood is seems like it'd be one huge PITA that I'd personally never stand for (and I guess I don't have to since I've ordered a BMW EV that is FOOLPROOF when it comes to charging it up). Editorializing aside, I'm merely saying it's a shame that half the cars don't include this straightforward, frustration-alleviating antidote. |
09-27-2023, 11:52 PM | #35 | |
Rep 825
