02-07-2016, 04:24 PM | #221 | ||
#buildnotbought
10980
Rep 4,912
But if you take a roots or twinscrew (both volumetric), it will make a lot of torque from very low rpm's. Maybe even lower than turbos. But there is of course no lag (no lag possible) If the TS wants zero lag and a lot of torque on low rpms, it's either large displacement or a volumetric supercharger. (or a tesla roadster as someone cleverly opted)
02-07-2016, 05:38 PM | #222 |
Rep 232
After two caymans you probably should try the 991.1 c2s it's geared better than the taller Cayman and has more torque.
Another $$$ option is to have bgb regear the Cayman manual box for closer ratios. Won't cure the lack of torque but will have lesser rpm drop at least. |
02-07-2016, 08:48 PM | #223 | ||
Rep 3,481
02-08-2016, 07:46 AM | #224 |
Rep 4,302
Posts Drives: M135i Join Date: Jul 2009
Ultima GTRs aren't too expensive but they are light, torquey and VERY fast.
02-08-2016, 08:18 AM | #225 |
Rep 2,665
I think everything except newer/warranty but at $10k you should have money left over for repairs.
http://nashville.craigslist.org/cto/5424923964.html More -http://monstermiata.webs.com/classifieds.htm
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
02-08-2016, 08:27 AM | #226 |
Rep 394
Posts Drives: 2015 MW M4 Join Date: Dec 2014
02-08-2016, 10:22 AM | #227 | ||
#buildnotbought
10980
Rep 4,912
Actually you're correcting yourself with your statement here. Quote:
I call that relatively low rpm. Lots of turbos still have trouble with these low rpms. They usually solve that with variable geometry turbo's, a relative new and complicated technique. If you think a volumetric supercharger cant do that, you're incorrectly informed. It's pretty much in the definition of volumetric supercharger that it can do that. In practice they perform better at low to midrange rpm than in the higher rpms, although that also varies with the size of supercharger you're designing with.
02-08-2016, 01:06 PM | #229 |
Rep 8,643
You want a light, nimble car, with low end torque but no turbos...
GL buddy... cuz you will need it. It sounds to me like you want a Miata with an LS swap. only other option is a supercharged lotus or Alfa 4c. |
02-08-2016, 02:50 PM | #232 |
Rep 3,856
BMW 128i M-Sport
02-08-2016, 03:18 PM | #233 |
Rep 2,210
Posts Drives: '17 jackrabbit on crystal meth Join Date: Dec 2013
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
02-08-2016, 04:05 PM | #234 | |
Rep 3,408
One last idea before we give up. Take that engine out of your Cayman and drop this bad boy in its place. Problem solved. |
02-08-2016, 06:42 PM | #236 |
Rep 1,049
Yes or a GT4. The Cayman S is already so close to the best apart from seriously focused track cars like the Atom, Catamaran and others.
If you need nimble, you should also add mid-engine to your list of requirements. I think my ideal might be a supercharged NSX. |
02-08-2016, 09:50 PM | #237 |
Rep 2,476
Posts Drives: Satan's Chariot 2.0 Join Date: Sep 2013
No TQ, but a Miata is what you need to buy. You'll thank me later.
02-09-2016, 01:43 AM | #238 |
Rep 3,481
02-09-2016, 06:09 AM | #239 | |
#buildnotbought
10980
Rep 4,912
You are not correctly informed. Here is the performance map of the twinscrew I use (lysholm ax1600): http://www.lysholm.us/pdf/diagram_lys1600ax.pdf You can clearly see that the peak efficiency is at 1.8 pressure ratio, that is around 11 psi, and that the widest flow range is about between 1.6 and 2.0 ratio, so between 8.5psi and 15psi. That is it's ideal operating range for this twinscrew. Nowhere near the 5-7psi you think of. It will work on that low range if selected carefully when the cfm requirements of the engine fall within it's range (or you'll loose boost/gain heat in ranges), but it's not designed for it. Maybe if you want to go in those low boost ranges the little eaton m45 is an option. That's used in a lot of miata sc conversions (mostly sources from small mercedes engines I think), doing it on the cheap so to say. But that is a very small and low yeald supercharger (although I still suspect that it'll still perform at 8psi, but with low cfm/for small engines) But these are all facts/data which is easily available on the interwebs.... Eaton V series sits between about 5 and 12psi and eaton R series sits even between 7 and 17psi. So you can pretty much find a roots or twinscrew supercharger for most applications. Only if you want to go above 17psi (in fact that eaton R will go up to 21...), you have to go turbo, but that is even for gas turbo engines pretty high. For comparison: the n54 runs stock on 8.8psi. Boost pressures above 17psi are normally only seen in turbodiesels or very very high performance builds where the stock turbo probably also has run out of air (well....gains too much heat) (335i's with 600hp+ and such) That concludes this weeks' turbo and supercharger lesson
02-09-2016, 08:59 AM | #240 | |
Rep 3,481
That's the point I made originally, yes, your supercharger may be operating under "full boost", but that "full boost" for a super charger is usually less than that of a turbo, although a turbo will drop off more above around 5.5K due to going past it's volumetric efficiency usually, which can be solved with a larger turbo, but that creates more lag issues. You spent all that energy to basically say the same thing I did? |
02-09-2016, 09:24 AM | #241 | ||
#buildnotbought
10980
Rep 4,912
If you'd make 15psi on that engine, you'd have a 335i with approx. 520HP. I'd say that that's already pretty extreme for a 3 liter turbo and by no means a 'starting point' If you make 20psi, you'd be pushing 700HP theoretically. By that time, the stock turbo would have probably melted in a solid lump of steel. So the 'starting point' is like 8-10psi on most petrol cars (mind you, 8.8psi is full boost on a stock n54!, and that is a good high performance engine considering all the awards it got). If you look at how boost is set on various tunes, for example that n54 used in so many bmw's, 8.8psi is stock, 12psi is a stong tune on a stock engine and 15psi is only possible with mods (intercooler, downpipe etc), but still on stock internals. Go to 20 psi, you need high performance turbos, maybe different internals, the lot (although the n54 has proven to be a very good engine with a strong crank). I also doubt that that's possible on pumpgas. The only cars that run 15-20psi stock are turbodiesels. Thats one of the reasons why a dieselblock is much stronger built. But I dont think the TS is considering a diesel car. Quote:
First you say that a turbo can make full torque at 1500rpm, and that it has therefore no lag. That is not true and after my post you correct that yourself by saying the thing about shifting down... Also you say that 'Supercharged engines gradually build up torque and are happiest in the high RPM ranges', which is also not true. That only goes for centrifugal superchargers (non volumetric). Volumetric superchargers (roots, twinscrew, G-lader) make boost pretty much instantly down low. Then you say that '"full boost" for a roots twin screw type is somewhere like 5-7psi', which is also not true. and then you say "You spent all that energy to basically say the same thing I did?" WTF? cant you read? I'm constantly correcting all the incorrect information you give. I think your opinion was formed by all the cheap superchargerkits (or should I say entrylevel kits, cheap is very relative) that are on the market; small centrifugal sc, no cooling, no plenum, sometimes even no injectors etc that give a certain NA engine maybe 25-40% extra HP. Those have only extra torque on high revs (centrifugal sc, small cfm bandwith) and operate generally at 5psi or so etc. Or cheap miata conversions where an eaton m45 is harvested from a crashed mercedes and bolted to the NA block. The better SC kits operate at 8psi or little above, before you have to lower the compresion ratio. Once you do that, kits and installs go up to 15psi or more if desired. If you go for top whp on a high performance build, turbo is more efficient (because a turbo only creates pumplosses, no parasidic crank loss), and therefore a turbo will consume a little bit less fuel when cruising (comparable to for example having the ac on or off), but from a drivability pov a twinscrew is a nice alternative, as there is per definition zero lag. Especially aftermarket turbokits or upgraded turbo's create extra lag compared to stock turbo installs (a manufacturer spends lots of money to minimize the lag, but that also always has influence on the efficiency of the turbo)
