ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      04-19-2017, 03:23 PM   #111
angelr
Drives: 07 aw/ir m coupe, 2013 S4
Originally Posted by PLCZ4M View Post
I know this treat has been death for a while but I am looking for wheels for M coupe. The M is still on standard suspension & factory alignment. I know this treat talks a lot about aggressive fitment.
One quick question for all the expert with fitment specially if its aggressive, would this set fit the M Coupe properly or aggressive? Or would it be better to use Spacers? Or different tire size better?
Wheel info:
(F):18x9.5 et 22
(R):18x10.5 et 22
Tire Info:
(F): 235/45/18
(R): 265/35/18
Would like some feedback before purchasing, wouldn't want to be too aggressive.
Thank You for your help.
You should be good with a little front camber. I'd look at a 40 series up front though. With those widths and offsets you will not need spacers.
      06-07-2019, 08:41 PM   #112
g2096
Drives: IS300
Aloha all, I'm hoping can help me out with a fitment question.
I have a 2008 z4 3.0si and need to know if a 18x9.5 +30 with
a 215 or 225/40 would fit up front? I'm currently on BCRacing
coilovers. Mahalo in advance!!!
      03-12-2021, 05:33 PM   #113
WideEVO
WideEVO's Avatar
Drives: 2003 BMW Z4 Coupe
Work Meister
19x10.5 +10 (225/40)
19x12.5 +5 (275/35)
Always evolving
      03-12-2021, 09:10 PM   #114
Willy Sea
Drives: BMW M Coupe S54, E36 M3 Evo,
Looks very painful to us
Murf99314114.00
XMetal1136.00
      03-13-2021, 09:26 AM   #115
wdb
dances with roads
wdb's Avatar
4732
Drives: '07 E86, '02 996, '95 Seven
I'm struggling to remember Thumper's lesson. Car enthusiasm is a big tent, right?
      03-14-2021, 06:34 PM   #116
zurus
Puerto Rico
49
Drives: IB M coupe
I don't really consider people who put together mediocre "builds" as enthusiasts.
      07-16-2021, 08:25 PM   #117
e46IX
Drives: Z4MC, E92 M3, F80 M3
Volk TE37SL
Fronts: 19x9.5 et22 on 245/35/19 PSS
Rears: 19x10.5 et21 on 275/30/19 PSS
Lowered on Eibach Pro-Kit and running -2.1 camber up front, about -2.5 in the back. Was able to get that camber by pulling the strut mount pins and with stock arms in the back. No rubbing, nothing. Drives great.
TRiCC264.50
      07-25-2022, 08:27 PM   #118
Caosa
Drives: Z4MC TiAg
Hey guys,
Got a great chance to grab some Vorsteiner wheels. I just want to know what it'll take to make them fit.
I've got the M sitting on BCR Coilovers; everything else stock.
19x9.5 et22
19x10.5 et 34
Having trouble finding out if there would be any issues. I'm assuming the front's wont work without some negative camber involved.
Any thoughts?
      07-27-2022, 08:06 PM   #119
3002 tii
3002 tii's Avatar
2286
Drives: Z4 M, X5, GX460
Originally Posted by Caosa View Post
Hey guys,
19x9.5 et22
19x10.5 et 34
Any thoughts?
Yes depending on tire but most likely will need -3.5 degrees
Follow for latest mods
      08-02-2022, 01:23 AM   #120
ANILE8
ANILE8's Avatar
Drives: Z4 M Coupé - Carbon Black
Originally Posted by e46IX View Post
Volk TE37SL
This is actually a bad tire size selection because your fronts are more than a 1/4" taller than the rears. Next time go for 235/35/19 up front with this setup for a more natural look.
Nitron NTR R3 | StopTech Trophy Sport STR-60 380x32mm / StopTech Trophy Sport STR-40 355x32mm | Bridgestone RE-71RS | ADV.1 | CDV Delete | TMS Rear Camber Arms | RE Diablo's | 4.10 Gears | Euro Headers | RTD REVO1 Short Shifter
      01-08-2023, 01:49 PM   #121
07ImolaRot
07ImolaRot's Avatar
Drives: 07 Z4M, 05 M3, 13 M3
the problem is the overall diameter with 235 is smaller than OE tire size and leaves a bigger wheel gap. not to mention worse ride quality and easier to bend wheels.
      02-09-2023, 05:47 AM   #122
gnx
Όλα ρόδες
gnx's Avatar
760
M359 rims
Just mounted these today. No wheel well rubbing at full lock, -2,3 camber front IIRC.
The back looks more aggressive than what i expected. Tires 245/35 with 275/30 in the back.
wdb4732.00
      02-10-2023, 08:21 PM   #123
07ImolaRot
07ImolaRot's Avatar
are you on stock suspension? Yeah 19x10 +25 in the rear sits much further out compared to stock wheels. I have that exact wheel/tire setup on my e46
2007 Imola Red Z4M
2005 Phoenix Yellow M3 6MT
2013 Interlagos Blue M3 6MT ZCP CF roof
      02-11-2023, 12:12 AM   #124
gnx
Όλα ρόδες
gnx's Avatar
760
Actually, no. The car sits on a Bilstein PSS10 kit but my ride height is at stock level. I really wanted to be as close to stock as possible so i used the strut tower reinforcement plates up front and these
https://www.ecstuning.com/b-genuine-...h/33531094754/
in the back from the e46 Xi touring models.
zpost
