05-09-2022, 07:01 PM | #45 |
Rep 3,030
Wait you get 10 year warranty on a new unit?
Why are we discussing this? |
spammysammich1579.00 |
05-09-2022, 07:50 PM | #46 | |
Rep 3,241
If you all would read the article I linked to, this will all be clear. |
05-10-2022, 12:00 AM | #47 | |
Rep 228
05-10-2022, 03:03 AM | #48 | |
#buildnotbought
10634
Rep 4,852
This is something completely different. Variable timing mechanisms change timing by pumping oil in one chamber or another, therefore moving a piston that sits inside. Driving with no or low oil pressure can only affect it so that it doesn't change the timing to the desired position. However, like I wrote before (twice), some variable timing mechanisms have locking mechanisms inside to lock the timing in a certain position, for example to get a specific timing during startup. Maybe that is not functioning, or worst case, damaged. Look at my previous link. Have you read that? So the first thing to figure out is why your car isn't starting. A compression test is the first test to do for that. If you have damaged valves or boring score, it would show. If you have compression, fuel and spark, and it doesnt start: it's timing. Also a previous question: did the oil light come on when you drove? I think a good independent garage could solve this issue way cheaper btw, but I'm not really familiar with US workshop rates. Even if the timing chain did skip some teeth, to set that straight is less than a day work in my book. But also in that scenario you first have to check if you don't have valve damage, so again: compressiontest. TBH I don't understand why the dealer didn't do the compression test in the first place. I mean he has the plugs out. From then it's just literally removing 1 fuse (fuel pump) and start the car 4 times with the meter in each plughole. How long can that take? surely shorter than 10 minutes! (or shorter than writing this post for that matter )
05-10-2022, 07:09 AM | #49 | |
Rep 3,030
To me, why rish spending 2 to 3K on a seriously questionable engine when you can drop 6 on one with some 10 FUCKING YEARS warranty on it. This is a no brainer. |
05-10-2022, 07:19 AM | #50 | |
Rep 611
F15 35d M Sport (SOLD ) | F30 328i | 2020 Tacoma TRD Pro
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread |
05-10-2022, 07:36 AM | #51 | |
Rep 224
