THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Offset Range M235i
      09-12-2014, 09:13 PM   #1
CANBeamer
Drives: M235i
Offset Range M235i
Hi all,
Sorry I tried looking this up, but couldn't quite find a range of wheel offsets that would fit on the M235i.
I understand the OEM's are 47mm in the front, and 52 mm in the rear.
Thanks
      09-12-2014, 09:56 PM   #2
BLK235iNJ
BLK235iNJ's Avatar
183
Drives: m235i,13MustangGT,84C10,99A8
im running 19 x 8.5 et40
      09-25-2014, 10:49 PM   #3
five3three
Drives: m2c
Originally Posted by CANBeamer View Post
Hi all,
Thanks
Fronts are not 47mm. They are 45. Here are specs:
02 Light alloy rim 7,5JX18 ET:45
02 Light alloy rim 8JX18 ET:52
      10-03-2014, 09:50 AM   #4
philisme
Belgium
54
Drives: BMW 1M Coupe + M2 + 330e
2016 BMW 330e  [0.00]
2012 BMW 1M coupe  [10.00]
2017 BMW M2  [0.00]
on four corners ?
      10-03-2014, 03:06 PM   #5
VMRWheels
VMRWheels's Avatar
2040
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
So far the most "aggressive" I've seen is 8.5 ET35 | 9.5 ET45.
8.5 ET45 (Front) - looks to require a 5mm spacer for suspensions clearance
      10-03-2014, 04:12 PM   #6
haloeight
Drives: m235i xd perf. ed'n
Can you clarify what you mean by aggressive for 8.5 ET35?
I ask because you had quoted me the 8.5 ET35 setup for my vehicle and am not sure if it's going to be pushing a limit or if I need a spacer from the above...
      10-03-2014, 04:26 PM   #7
VMRWheels
VMRWheels's Avatar
2040
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Below are a few examples of 8.5 ET35 | 9.5 ET45..
I personally don't believe it's too aggressive, however, if there isn't any negative camber or if you decided you want to go with a meatier tire setup.. you may see some wheel poke. From what I can see 8.5 ET35 w/225s and 9.5 ET45 w/245s seem to be a safe bet.
If you want to run 235s (F), 8.5 ET40 would a good choice or 8.5 ET35+some negative camber.
If you want 255/265 (R), 9.5 ET50 would be choice or 9.5 ET45+some negative camber. ^^ These should get you to just about flush w/no wheel poke
http://www.2addicts.com/forums/showthread.php?t=1040428
http://www.2addicts.com/forums/showt...&highlight=vmr
http://photos-e.ak.instagram.com/hph...65761383_n.jpg
http://photos-c.ak.instagram.com/hph...15477206_n.jpg
http://photos-b.ak.instagram.com/hph...76118037_n.jpg
      10-03-2014, 07:37 PM   #8
haloeight
I was looking at 8.5 ET35 + 225s for a winter setup with you.
Don't know if it's just me but your instagram pics can't be viewed.
      10-03-2014, 11:14 PM   #9
vteckiller2000
Drives: 2014 M235i
Aspec on ebay has a set of CSL reps that are 18x8 +38F and 18x9 +40R that I have my eye on. Just not sure about using one inch stagger when I really want a square 245 setup that will rub.
      10-04-2014, 02:41 PM   #10
BLK235iNJ
BLK235iNJ's Avatar
183
Originally Posted by philisme View Post
on four corners ?
Yes all 4
      11-08-2014, 11:40 AM   #11
darkfaker
Drives: M235I
does m235i fit 20Inch wheels?
      11-11-2014, 12:49 PM   #12
VMRWheels
VMRWheels's Avatar
2040
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
It could with the right offset/width/tire size combination
      11-11-2014, 02:05 PM   #13
darkfaker
Drives: M235I
can xdrive go staggered set?
      11-11-2014, 02:13 PM   #14
VMRWheels
VMRWheels's Avatar
2040
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Yes, as long as you keep the rolling diameter (F & R) as close to stock as possible.
http://www.1010tires.com/Tools/Tire-Size-Calculator
http://www.miata.net/garage/tirecalc.html
      11-11-2014, 02:25 PM   #15
darkfaker
Drives: M235I
thansk a alot. what is difference between square set and staggered set?
      11-12-2014, 12:59 PM   #16
VMRWheels
VMRWheels's Avatar
2040
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
There are various forms of "staggered", generally speaking square vs staggered will be referred as:
Square
- Same width all around ( F and R )
- Ability to rotate tires in traditional manner
- Front wheel/tire setup may sit more "flush" in comparison to the rear
Staggered
- With BMWs, most examples will include smaller width FRONT and larger width REAR
- Ability to run larger rear tire. Provides aggressive/wide/flush look (subjective)
^ Each will also have their own pros/cons in terms of handling/performance
      03-06-2023, 02:31 PM   #17
Falco_666
Falco_666's Avatar
18
Drives: ///M2 Competition
Can someone confirm it this would fit on my M235i?
8J ET30 on all 4 corners, 19" wheels.
Stock tire dimensions (225/35R19 and 245/30R19) lowered on ST XA coilovers.
Thank you in advance.
      03-20-2023, 09:47 AM   #18
SmellyGreek
SmellyGreek's Avatar
Drives: Estoril Blue F22 M235i
That offset appears to be way too low to fit without heavily modifying the suspension....and even then.
      04-09-2023, 12:44 AM   #19
daneagles
Drives: M235i
Apex has a really good fitment guide for our car:
https://support.apexraceparts.com/hc...-Fitment-Guide
2addicts
