BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      06-11-2012, 03:52 PM   #45
DavidZ
DavidZ's Avatar
Drives: '11.5 E90 M3 6MT
I've found differing info on this, but mostly for different chassis. Does the E9X front PDC detect curbs?
-David
      06-11-2012, 04:02 PM   #46
tlp
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
It will and can detect a curb initially during approach but it will fall off the horizon as soon as you get closer. The front sensors in the OEM location on the e9X are too high to effectively detect curbs all of the time. If you're working with an undrilled bumper without holes I would consider placing the front sensor towards the bottom of the bumper like other BMW models.
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
      08-01-2012, 10:02 AM   #47
tico1028
Drives: F83 M4 - MG
So, can this be done on an M3 that never had PDC to begin with (no rear)? I really want to look into doing this, but I have no idea who down in South Florida can do it for me if I get the parts.
      08-01-2012, 10:33 AM   #48
tlp
It's a little more involved but a full PDC retrofit can definitely be done.
      08-01-2012, 05:07 PM   #49
tico1028
Drives: F83 M4 - MG
I figure it would require more coding? I was thinking about ordering the part, then trying to find a coder. Do you think BMW would actually do the work? I know they charge like crazy for labor though.
      08-01-2012, 05:17 PM   #50
tlp
Actually, from a coding only perspective while following the best practice methodologically it's the exact same amount of work. In other words, no more additional coding work to do a full PDC vs a front PDC only retrofit. I don't think that BMWNA has an approved retrofit path for the dealer to agree to to it. A savy dealer can easily do the work you also may be able to find a shop in your area to assist in the install and coding.
      08-26-2012, 01:45 PM   #51
ramez75
ramez75's Avatar
Drives: 2015 640i xDrive GC (F06)
tlp,
How did you run the wiring of the Front PDC under the hood. The wiring from the ECU box to the front bumper. I cant close the ECU box because I have the wire that i ran through the firewall. Do you have pics of how the wiring is run under your hood..
Thanks
15 F06 640i xDrive Gran Coupe/Grey
      08-27-2012, 12:57 PM   #52
tlp
Originally Posted by ramez75 View Post
tlp,
Thanks
I don't have any pic's but I believe that piggy backed the headlight wiring harness for a stretch on the passenger side. It's fairly intuitive and straightforward. Just may sure that you don't waste too much harness length during the routing as run of wire is the exact length to the rear PDC module.
      08-27-2012, 01:22 PM   #53
ramez75
ramez75's Avatar
Thanks top for the prompt response. What I did is I ran the front pdc through the firewall as you had in one of ur posts and connected one end to the pdc unit in the trunk. The thing that threw me off and the instructions weren't clear to me atleast on how to route the wiring harness with sensor part out of the Ecu box so I can close the box.
I hope I m making sense
      09-04-2012, 02:37 AM   #54
ramez75
ramez75's Avatar
tlp how did you close the lid on the ECU box without smashing the front PDC wiring. I have the wiring from the front bumper running on the passenger side into the ECU box through the firewall. So now I want to close the the ECU box putting the lid on but I dont know how not to smash the wiring. Do I squeeze it by the rubber gourment or how?
Thanks
      09-04-2012, 10:41 PM   #55
tlp
Thanks
I created a little U shaped hole at the top just under the cover to allow the wire to pass.
      09-09-2012, 11:41 AM   #56
ramez75
ramez75's Avatar
tlp,
Did you have issues putting back the front bumper after you installed the 2 middle sensors. There is no way my bumper will go back in place with the 2 middle sensors, there is no clearance. It just doesnt fit. My car is the 335ix 2009 but i was wondering how did you fit urs.
Its a show stopper.
Let me know what is ur thoughts
      09-09-2012, 12:43 PM   #57
tlp
tlp,
Its a show stopper.
Your front bumper carrier is the culprit. You will need to modify it or replace it with one that is compatible with front PDC. The M3 does not have this issue and I have no data for your application.
      10-04-2012, 08:01 PM   #58
tico1028
Drives: F83 M4 - MG
I've been busy and had to let this go for a while, but now I'm back into it. I found a shop that can install the retrofit, but I'm looking for the parts to order. I am thinking about just doing a rear PDC retrofit. I have the following part numbers to order:
Ultrasonic sensors (4): 66208046453 (Jerez black, $139 new each)
PDC Mounts (4): 51110432249 ($11 each)
Now, I know I need cables and the ECU, and I'm sure I need something else. Would you by chance know the part numbers for the Rear PDC ECU and the kit?
Thanks.
      10-04-2012, 11:41 PM   #59
tlp
Thanks.
All of the required parts for this project are listed in thread #1 assuming that you already have rear PDC and will doing a front retrofit. You will need go on Realoem.com to source the right part number for the PCD module based on your build date. The rest of parts are generic. The wiring kit already comes with the PDC mounts. You will not need to source them separately.
      12-03-2012, 05:42 PM   #60
Dnc026
Drives: Ess Supercharged E92 M3
Thanks for the DIY on this!
      09-08-2013, 04:33 PM   #61
Sam33
Drives: 335i Coupe xDrive 2009
Sam,
I have not seen or experienced that issue. I have also coded a few cars for this mod and they did not mention any errors or issues as well. I would go back and retrace all of your wiring to make sure that it is correct. Also, make sure that you didn't inadvertently disconnect anything when you were routing the wires. My install previously had rear PDC and I just added the front. A full PDC retrofit can be time consuming. Good Luck.
Thanks, yes it was fiber cable issue. Retracing solved the problem.
      09-08-2013, 04:41 PM   #62
Sam33
tlp,
Its a show stopper.
Ramez,
I had to cut front rebar edge to fit the two middle sensors but unlike M3 these sensors will go off in crazy way because they sit on top 335 rebar. I tried to install 2011 335 rebar, same issues. I have to try install M3 rebar but it is costly so I am waiting till I get extra cash for this project.
      06-05-2014, 06:51 AM   #63
ramez75
ramez75's Avatar
Well I am in the process of replacing my front bumper and front bumper support. The Autobody shop will not modify the front bumper support (by cutting it). The current one I have is damaged and need to be replaced. The autobody shop will only install the stock one which if they did then I cant install my 2 middle front PDC sensors.
Sam33 or anyone do you know the part number of any front bumper support that will allow me to install the middle front PDC sensors. I have a 2009 335i xDrive Coupe
I need to have something ordered by end weekend otherwise the autobody shop will order the stock.
Any help on this will be greatly appreciated.
Thanks
RB
Originally Posted by Sam33 View Post
Ramez,
      11-13-2014, 07:17 AM   #64
minialvitano
Drives: bmw m3
Hello, I would want to realize this assembly on my E92 but I do not find the retrofit kit for my car
      12-15-2014, 07:43 AM   #65
mierzwin
Drives: E90 330i
I did retrofit on my e82 with all the coding etc. done by myself and must say this guide was very helpful. On RHD cars pdc cable is routed via firewall under abs pump, not ecu as this way cable will be to short and sensors will be the other way round
      02-05-2015, 06:54 PM   #66
BeastMode335i
Maximus Decimus Meridius
BeastMode335i's Avatar
Drives: F30 335i
Are those circular/crosshaired markings behind the bumper there from the factory (to make perfectly aligned installation for PDC sensors, or did OP put them there so he knew where to drill? I imagine it'd be very easy to make these not evenly installed without there being some sort of template.
Thanks!
Tags
do it yourself, euro, front & rear pdc, park distance control, retrofit coding
m3post
