10-25-2020, 07:28 PM | #1 |
Rep 10,346
Does it matter to you if the oil BMW recommends is not your preferred brand?
I know talking oil is akin to talking politics but I'm just curious if it matters for our more enthusiastic BMW fans.
"Drive more, worry less. "
10-25-2020, 07:42 PM | #2 |
Rep 71
For what it's worth i work at a mercedes dealer and use the Mobile one that gets put in all of our cars in my M and everything runs great and my Blackstone oil analysis looks great so IMHO it doesn't matter just get a quality oil. Also im running 5w40
tracer bullet2390.50 5.M0NSTER3353.50 |
10-25-2020, 08:25 PM | #3 |
#buildnotbought
10655
Rep 4,855
Also in your s54?
Ever done a rodbearing swap on that engine?
10-26-2020, 01:59 AM | #4 |
Rep 71
No im not running it my s54 just because it needs 10w 60. Have not done rod bearings yet but It is a 2005 with 30k and had the vamps redone so its probably not going to get rod bearings for a while. My 335i did get the mobile 1. Also running it in a Bentley flying spur no issues
10-26-2020, 03:29 AM | #6 |
#buildnotbought
10655
Rep 4,855
Yes ok that was not clear to me.
The clearing on the rodbearings in the s54 is also bigger than on most bmw engines, so going with a thinner oil (especially in warmer areas) can be a serious risk
10-26-2020, 04:37 AM | #7 | |
I only ride park
490
Rep 385
Personally have no issue buying the recommended oil/brand but, my knowledge of the business world tells me that, the brand recommendation will be part of a mutually beneficial deal between those two companies and not that that oil is leagues ahead of the competition. |
10-26-2020, 07:39 AM | #8 | |
Rep 392
When was the time anyone saw someone come of a message forums and complain "I used the right spec oil, changed it at correct intervals, and the oil ruined my engine" I'll wager this has never actually happened. Buy good oil with the right specs, change it regularly, and the rest of the car will fall apart around a well lubricated engine. |
10-26-2020, 08:09 AM | #9 | |
Rep 10,346
10-26-2020, 10:15 AM | #10 |
Rep 3,909
Oil performance really is a long, deep rabbit hole. Unless you really want to get technical on it, or your engine is operating significantly outside its design parameters (heavily tuned/modified), just find an oil which is certified for your engine (eg LL-01 or LL-04 ,etc) and carry on. That's not to say that non-certified oils couldn't be better; it's just an easy way to be sure that the oil you choose will be good enough to keep your engine running properly for a long time. Don't cheap out, but also don't over-think it.
10-26-2020, 12:50 PM | #11 |
Rep 3,255
As long as the oil it quality, it doesn't matter to me. It's not like BMW recommends the best based on lab results. They are recommending Castrol over Shell because Castrol paid more
10-26-2020, 02:25 PM | #13 |
Rep 10,346
Yes you're correct but times are changing.
10-26-2020, 03:20 PM | #14 |
Rep 6,716
Now BMW has Motul branding on some of their race vehicles... so there’s another option.
A lot about oil in general can be found on BITOG forum. |
10-26-2020, 03:44 PM | #15 |
Rep 653
10-26-2020, 04:26 PM | #16 |
Rep 6,920
Posts Drives: 2018 M2 AW DCT Join Date: Aug 2012
Castrol isn’t an approved oil for my M2. It isn’t LL-01 approved.
10-26-2020, 04:27 PM | #17 | |
Rep 10,346
Just curious if things have changed.
10-27-2020, 09:15 AM | #18 |
Rep 392
10-27-2020, 09:29 AM | #19 |
Rep 533
Nope, I'll still use my preferred brand. Spend enough time over on BITOG and you'll know what you want/don't want and the mystery behind BMW oil approvals is better understood.
10-27-2020, 09:34 AM | #21 |
Rep 6,283
