Go Back   BMW E39 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs)
      06-08-2024, 10:17 PM   #1
Huck50
Drives: 2020 BMW M4 F82 (ZCP)
Do I pre-rinse before using foam cannon?
Just wondering if I should pre-rinse the car before using my new foam cannon?
Thanks,H50
      06-08-2024, 10:34 PM   #2
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
Technically if you look at comparison videos I believe not rinsing is best for most cleaning. That said if you have mud I would pre-rinse. But normal regular wash I foam then rinse only.
Huck5023.00
      06-08-2024, 11:32 PM   #3
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
if you're using a prewash, go straight to a prewash. if just car shampoo then a pre rinse might be helpful in getting a little bit of loose dust, pollen, etc off
      06-09-2024, 12:13 AM   #4
BruinMan
BruinMan's Avatar
93
Drives: BMW X5 M50i Unicorn
Best way and the way I do it: Prewash with a foam cannon. Let it sit for a couple of minutes. Rinse and foam cannon again. With the soap on the car, I use a microfiber mitt that is on long handle. Rinse again. Ego leaf blower.
I use Adam’s Mega foam in my foam cannon. My car also has Graphene Ceramic Coating™ Advanced from Adam’s. I am also checking out Jay Leno’s shampoo and soon be switching to Armour Shampoo+ High-Foaming pH Neutral Shampoo.
2021 BMW X5 M50i Tanzanite Blue II Metallic
Huck5023.00
CTPJ311.00
Bruuuce365.50
      06-09-2024, 02:19 AM   #5
whofelt
Drives: M340x Drive
I rinse, foam, rinse , foam and hand wash then rinse off.
Huck5023.00
cooolone2682.00
T0RM3NT4565.50
USMC_Sam200.00
      06-09-2024, 06:31 AM   #6
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
I always rinse before performing a contact wash. In New England there's always tons of road grime that ends up on your car. Pre rinsing gets off the loose stuff which lessens the chance of you rubbing it into the paint with a contact wash. It also softens up the stuck-on crud for easier removal. Just my $.02..... Have fun!
Huck5023.00
tcphoto4164.50
Seedster2372.50
      06-09-2024, 06:38 AM   #7
Portimao Blue M440ix
Portimao Blue M440ix's Avatar
Drives: Bmw m440i g22 Bmw 335i e92
Thats my method as well. By the time the microfiber touches the car its pretty well clean.
Huck5023.00
T0RM3NT4565.50
      06-09-2024, 07:03 AM   #8
Huck50
Thanks everyone.I was thinking that maybe the foam won't 'stick' and would run off faster if I rinse first, as opposed to the foam doing it's job and 'sticking' on a dry car?.Thanks,H50
      06-09-2024, 07:32 AM   #9
disintegrator66
After running my Kranzle power washer for 5+ years I'd say this is not a concern. Thick foam will dwell longer than thin watery foam. A You just need to get your set up and shampoo product correct for this to happen.
Huck5023.00
      06-09-2024, 08:41 AM   #10
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
Foam, rinse, foam, 2 bucket wash with grit guards. I still see grit at the bottom of the rinse bucket at the end of the wash (especially with our daily drivers), but the wash bucket (with shampoo) stays pretty clean.
Huck5023.00
T0RM3NT4565.50
Bruuuce365.50
      06-09-2024, 01:19 PM   #11
MADBMWX5MC
MADBMWX5MC's Avatar
Drives: 2023 BMW X5MC
Foam, rinse, foam and rinse. Most of the time that takes care of the issues. Then I blow dry. Since I have ceramic coating the job is easy. Rarely I have to make contact with the paint -- with a wash mit or other
2023 BMW X5MC Tanzanite Blue II Metallic
2021 Jeep Grand Cherokee SRT Black
2006 Ford Mustang GT Convertible (show car)
      06-09-2024, 08:31 PM   #12
GreenRangerDX
GreenRangerDX's Avatar
Drives: BMW F31 2014
I am happy to see I am not the only double foamer
cooolone2682.00
pokerface442.50
MADBMWX5MC1564.00
      06-09-2024, 08:58 PM   #13
TheMidnightNarwhal
I don't know if that's the reason but yes that's what I've seen from comparaison videos on Youtube, foaming dry car then rinsing will clena more than rinsing car, then foaming, then rinsing.
That said of course it's marginal at the end of the day but I still switched to doing this when I will do a full wash rather than my rinseless wash, why not right. Then I just continue with a 2 bucket wash since I like to have a soap bucket. I do use the foaming stage though for intricate areas with a soft brush that aren't to close to paint.
Huck5023.00
      06-09-2024, 09:19 PM   #14
cooolone2
cooolone2's Avatar
682
Drives: 20' M240iX B58, 01' 330XI E46
Rinse with high volume low pressure.
Rinse with pressure washer.
Foam, allow to dwell 5-10mins
Rinse
Foam, allow to dwell 10+mins
Wash - microfiber mit, 2 bucket, 3rd for wheels/brush
Rinse
Rinse with Deionized Water
Dry - Waffle Towel with detail spray
Detail spray with microfiber...
2020 with barely a scratch you could see... Other than what I've put on the paint. Chips front end from road debris. Otherwise very clean.
Just get the loose dirt off, use the foam to loosen it even more, mit wash to remove the rest, rinse, then rinse with water that won't leave a trace, dry with detail spray to reduce surface tension and possibility for scratching, then another shot with detail spray. Could use spray wax, or recharge if ceramic coated...
Good Luck
Huck5023.00
      06-10-2024, 01:13 AM   #15
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
unless you're using a prewash like bilt hamber to sit and dwell, letting a snow foam like adam's mega wash sit and dwell then rinsing off does nothing. you're just wasting a good snow foam at that point.
arsunic49.50
      06-10-2024, 02:23 AM   #16
whofelt
Drives: M340x Drive
not from my experience.....
washing a car is not rocket science, i get that, but rinse, foam, rinse, foam+hand wash has given me great results.
i don't believe in "pre-wash products" and i'll never spend my money on that.. just my opinion
2022 M340 Xdrive, aFe CAI, AA Catted Downpipe, 13mm wheel spacers. 56,000 miles on the odometer
cooolone2682.00
      06-10-2024, 08:51 AM   #17
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
i felt the same way until i tried bilt hamber. didn't believe in the stuff until i tried it
      06-10-2024, 12:05 PM   #18
Bruuuce
the me
366
Drives: 01ZCoupe, 08M3Coupe, 21M2C
I also have also adopted the double foam method
I foam the car, let it sit and pick up the loose dirt.
Then rinse
Then foam again
Contact wash
During the contact wash I sometimes use a clay mat as well, depends on how contaminated the surface is
Lots of advice on the tube of U. DIY detail is a source
01 Z Coupe, 5MT, SB, not much else
08 M3 Coupe, 6MT, JB, not much else
21 M2c Coupe ,DCT, SOM, not much else
cooolone2682.00
      06-10-2024, 12:12 PM   #19
MADBMWX5MC
MADBMWX5MC's Avatar
Ha! Funny right there...
      06-10-2024, 06:48 PM   #20
louielouie
Drives: '18 F80
Rinse
Rinse
Good Luck
Why wipe to dry when you use DI water? The main reason you use it is to not have to dry...
      06-10-2024, 09:23 PM   #21
Hagasan41
Hagasan41's Avatar
Drives: 2013 E92 ///M3, 1999 E36 ///M3
I’ve got some on order to try. What PIR are you using?
2013 E92 M3 |Space Grey | Fox Red | Manual
1999 E36 M3 |Hellrot Red | Black | Manual
IG: @moya_M3
      06-10-2024, 09:35 PM   #22
Hagasan41
Hagasan41's Avatar
I follow a similar process but use a leaf blower to remove most of the DI water then follow up with a drying aid, etc for the final wipe. The only time I don’t do a final wipe and let the DI water dry naturally is when I’m pressed for time. But I reserved this practice for the wife and kiddo's cars. LOL
IG: @moya_M3
