      04-03-2024, 10:25 AM   #1
Cwelch
Cwelch's Avatar
18
Drives: BMW 535xi drive 2009
2009 535xi drive  [10.00]
Need help and thoughts on my e60 bmw
I recently just got a bmw e60 and it runs perfect besides when I accelerate hard for the first couple times it sounds like my engine misfires and I have to turn it off and then back on again to make it run like normal but when the engine is heated up their is no misfires at all and I’m so confused because I don’t know what’s wrong with it
      04-03-2024, 10:34 AM   #2
Cwelch
Cwelch's Avatar
18
Here’s what the car looks like
      04-03-2024, 11:00 AM   #3
M3SQRD
M3SQRD's Avatar
2425
Drives: E92 M3,G20 330ix,F22 240iX,F82
No misfires when warmed up so does that mean you’re driving the car hard/high rpm to cause misfires while the engine is cold and/or not fully warmed up? If the answer is “yes” then the problem is you by not allowing the engine to reach its operating temperature before you start beating on it.
Cwelch18.00
      04-03-2024, 11:05 AM   #4
Chihuahua
Chihuahua's Avatar
4127
Drives: E30 329iS, E65 Alpina B7
Any chance any of this started after you modded the car?
https://e60.5post.com/forums/showthread.php?t=2093361
Cwelch18.00
      04-03-2024, 11:43 AM   #5
Cwelch
Cwelch's Avatar
18
It only started doing this after I took it to an auto shop nearby my house to change my fuel pump. And if I need to let the engine warm up, then how long should I wait or how would I know when it’s fully at operating temperatures?
      04-03-2024, 12:01 PM   #6
M3SQRD
M3SQRD's Avatar
2425
Does the e60 have an oil temp gauge? At a minimum, keep engine rpm’s at or below 3k rpm and wait until the oil temp is at its normal operating temp (e.g., on my e92 M3, it’s when the oil temp reaches 210 F; M3 also has a variable redline that increases with increasing engine/oil temp) but I still wait at least another 5-15 min, depending on ambient temp, before I exceed 3k rpm. I do this to make sure the DCT and other components also are up to temp. Engine wear is the greatest when the engine is cold.
Cwelch18.00
      04-03-2024, 12:07 PM   #7
Cwelch
Cwelch's Avatar
18
Thank you so much I really appreciate it and I’m going to make sure my engine is warm before I get anywheres above 3k rpm and I’m new to this car because I had an Acura tl so it could drive right away but this car has so much more power and I need to make sure I take better care of it. I’m just trying to figure it all out but thank you so much
      04-03-2024, 12:12 PM   #8
Almuliman
Drives: 2013 LMB 6MT 128i
Not to be a d*** about it, but the "rule" about keeping revs low until the oil is up to temperature applies to all ICE vehicles. In other words, it applies to the Acura you had, too.
Congrats on your new ride and welcome to the club
Cwelch18.00
SYT_Shadow11504.50
celsdogg329.00
      04-03-2024, 12:34 PM   #9
Cwelch
Cwelch's Avatar
18
Thank you bro I completely get it I’m just a dumb driver I’m also young as hell so I didn’t know about all these things but I’m happy to be a new member 😁
Almuliman511.50
      04-03-2024, 12:51 PM   #10
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
2012 BMW 335i  [5.25]
2012 BMW 335is  [5.00]
2008 Infiniti QX56  [0.00]
1967 Chevrolet Corv ...  [10.00]
2001 M Roadster  [10.00]
2022 BMW 540i  [0.75]
2009 528i  [9.50]
+1 on this. No, the non-M e60 does not have a temp gauge.
Cwelch18.00
      04-03-2024, 01:22 PM   #11
Tambohamilton
Drives: E91 330d
Even if the OP doesn't let the engine warm up before beating on it, it still shouldn't misfire etc.
OP, get yourself a BMW specific code reader (protool, INPA, ista, etc). It'll save you money in the long run.
Cwelch18.00
Almuliman511.50
celsdogg329.00
      04-03-2024, 01:36 PM   #12
Cwelch
Cwelch's Avatar
18
I’ll look into one but thank you!
      04-03-2024, 01:38 PM   #13
Cwelch
Cwelch's Avatar
18
Is their also any I specific code reader that you recommend that’s cheap and easy to use?
      04-03-2024, 03:05 PM   #14
Chihuahua
Chihuahua's Avatar
4127
I used INPA when I had my E60, I'd recommend either that or Carly. Carly is more readily available and easier to get up and running with. INPA is/was BMWs factory software that they used back in the E-chassis days. I like using it, but it can be challenging to get setup correctly.
      04-03-2024, 03:11 PM   #15
Cwelch
Cwelch's Avatar
18
Thank you I appreciate it and the reason it was misfiring only when I accelerated was because my engine temp wasnt high and I just drive it and let it sit for a while and not let it get past 3k till it was warm and it was perfectly fine after!
      04-03-2024, 03:16 PM   #16
spammysammich
spammysammich's Avatar
1614
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
this forum may get you more accurate answers regarding your specific car model. This is the M3 section.
https://e60.5post.com/forums/index.php
      04-03-2024, 03:27 PM   #17
Cwelch
Cwelch's Avatar
18
I thought this was the general news and bmw discussion because I went on the 5-series forum and no one would awnser
      04-03-2024, 03:52 PM   #18
Almuliman
No worries. It's how we've all learned along the way
P.S. Not helped by BMW—and other manufacturers—not including or even offering an oil temp gauge, -128ownerwithoutANYtempgauges
Cwelch18.00
      04-04-2024, 02:50 AM   #19
Tambohamilton
Drives: E91 330d
Cheapest is INPA/ista - free software, just need laptop and a decent kdcan cable. But most difficult to install and use.
I'd recommend protool - costs some and you need android device and a decent cable. But very easy to use, good support, etc.
      04-04-2024, 06:31 AM   #20
Chihuahua
Chihuahua's Avatar
4127
Just a friendly tip: BMWs are great cars, and you can drive them hard, but if you abuse them they will abuse you back tenfold if you catch my drift. Enjoy the car, try 5series.net as well as it's a little more active than this forum.
      04-04-2024, 07:22 AM   #21
Cwelch
Cwelch's Avatar
18
Thank you bro I appreciate it!
      04-04-2024, 07:43 AM   #22
Cwelch
Cwelch's Avatar
18
I’m also learning the tenfold the hard way I’m definitely gonna drive it a lot smoother 😂
