Rough idle and intake valve carbon build-up. How is this possible?
08-22-2011, 06:55 PM | #23 |
3441
Rep 79,211
It helps to run it all out on the highway, especially a car that is driven like a grandma, but inevitably their will still be carbon build up.
08-22-2011, 07:44 PM | #24 |
Rep 3,730
Take you IC pipe off to see another way gunk gets in there
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
08-22-2011, 08:07 PM | #25 |
Rep 566
My car is in the shop right now to get the valves cleaned. I took pics of the valves, and they were pretty nasty. I'll post them up later.
Also, for the OP, check out this thread if you want a TON of information about our crankcase ventilation system. http://www.e90post.com/forums/showthread.php?t=518306 |
08-22-2011, 08:10 PM | #26 | |
Rep 566
Also, I'm thinking that another benefit of dual injection is that for big turbo applications, it would be easier to beef up the fuel system, but that's for another thread. |
08-22-2011, 08:16 PM | #27 |
310
Rep 15,745
I have done 4 of these as of latley...anything north of 50k i highly recommend doing it. LostMarines were super gunked up and he uses a lot of meth...we gained 12hp alone just from the cleaning on the dyno
08-22-2011, 08:59 PM | #29 | |
Rep 6,773
08-22-2011, 09:15 PM | #30 |
Rep 40
Granny shifting
08-22-2011, 10:37 PM | #32 | |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
If your rough idle is caused by clogged or dirty injector tips, then a proper fuel injector cleaner should do the trick...but if its from valve stem build-up, then really your only option is to open up the intake manifold and clean those valves by hand. |
08-22-2011, 11:48 PM | #33 |
Rep 1,262
Had this problem, BMW covered it out of my warranty. Read here..
http://www.e90post.com/forums/showthread.php?t=549660 |
08-26-2011, 09:21 AM | #34 | |
Rep 709
Drives: '07 335i (E93)
Alpine White/Coral Red/Gray Poplar Convertible Sport/Prem/Step/Comfort/Nav/Sirius
MHD Stage 1 Flash, M-Factory Helical LSD By the way people: USE YOUR F&*#ING TURN SIGNALS! Pass the word. |
08-26-2011, 09:24 AM | #35 |
3441
Rep 79,211
08-26-2011, 09:36 AM | #36 |
Rep 709
Fair enough, I was just weighing the odds of one issue over the other
08-31-2011, 05:05 PM | #37 |
Rep 86
The new Toyota/Subaru Boxer engine will have port and direct injection as well.
PS My dealer said they are getting the tool for this walnut sheel intake blasting as well. It seems a good method...i will start saving now! |
08-31-2011, 05:36 PM | #38 |
Rep 3,736
Hmmm, rough idle, I bet all you need is new spark plugs, remind the dealer that you are due for new plugs under warranty at 45K.. that should fix it
08-31-2011, 08:50 PM | #39 |
Rep 233
09-01-2011, 08:04 AM | #40 |
Does not play well with others
80
Rep 1,787
Had this problem and had the walnut shell along with hand cleaning by a dealership.....$$$$(but it did help tremendously)
This cleaning can be covered under warranty since it is a known issue which affects the car and is not a result of any type of misuse or neglect on the part of the owner. Just have to convince the dealership to submit the claim to BMW where it is handled on a case by case basis.
09-01-2011, 08:48 AM | #41 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
Yea, I don't want to wait until there are symptoms of a problem. Just DIY it myself.
09-02-2011, 10:24 AM | #43 |
3441
Rep 79,211
It's called blow by. Oil gets gunked in their and the charge pipe over time. Its part of the "emissions" system. Instead of dumping the oil particulate into the atmosphere they recirculate it back into the intake tract. That's the reason some of us run oil catch cans to reduce the amount of oil put back into their.
09-02-2011, 10:31 AM | #44 | |
Rep 1,160
Rumor has it that routing the PCV line to atmosphere solves the problem in a major way. Gotta wonder if an inline plug's an inexpensive solution. Catch can? ANYONE have pics of valves after 10K+ mi w/catch can? Opinions on Redline's metal catch can vs. plastic? |
