06-03-2022, 05:08 PM | #1 |
Rep 34
M4 Comp (F82) seats in M2 (F87)
Ok guys, I am happy to say I fitted M4 comp rear seats in my M2 OG today, and I can tell you exactly how I did it. I'm not suggesting this is the perfect method, just what I did. If you have any more questions hit me up on instagram @dunstablem2 as I don't often come on this forum.
Feel free to try fitting the bench without removing the brass coloured U-bracket off the side bolsters. People have said it's possible, but this makes it a lot easier. Be careful when you have the rear rests in but not the bench, if you put the rests into the 'down' position onto the bare metal (where the bench would be), then kneel on them it will force the rests onto pretty sharp metal which could damage or even cut the leather. Be prepared to push the bench in extremely hard to get it to clip. You're pretty much getting the bench to slightly bow/bend to find that extra last cm or so of reach to the clip. For this reason I don't think the middle clip is possible to get on, as the middle plastic rigid tray means you can't get the flex you need. |
06-04-2022, 12:37 AM | #3 |
a coffee drinker
96
Rep 162
06-04-2022, 12:55 AM | #4 |
Rep 1,675
06-04-2022, 02:35 AM | #5 |
Rep 34
Absolutely! Other than needing the original seats securing brackets swapped, the rear seat backs (as opposed to the bench part) are a completely straight swap with OEM, no modification needed and fit and work exactly as OEM. That includes unlatching and folding down.
03-04-2023, 05:16 PM | #8 |
Rep 1,550
What’s the reason to do this?
jefe2000775.00 Creations_cult6.00 |
04-04-2024, 09:25 PM | #9 |
Rep 9
Kevin_The_Clean13343.00 |
