10-26-2023, 10:24 AM | #45 | |
Rep 128
I’ve decided to take the plunge and replace the only matt silver pieces on the exterior of the car for M Sports package iX where everything else is black apart from the chosen body colour for a better look. Removed the xDrive emblem for good. Sent the car in for ceramic coating before putting the new emblem on. Measurements if you are interested to know. Cheers!
Past - E60 535i, F07 535i, G05 X5 xDrive40i
Current - I20 iX xDrive40 |
10-26-2023, 11:38 AM | #46 |
Rep 898
Thanks all for this thread especially the OP and VG. While I normally remove some badges, this thread had me going over tons and tons of iX pictures and in this case I am agreeing with most that it looks better with the fender badges on it.
Going to install them before I put the ceramic coating on the car. |
01-13-2024, 06:31 PM | #48 |
Rep 4,527
Drives: 2022 iX xDrive50, DGM
Good job!
01-13-2024, 08:58 PM | #49 |
Rep 898
Thanks. Thanks to all who contributed to creating this thread; could note have done this well without your posts above. I followed their individual and collective advice and the old carpenter’s mantra, “measure twice, cut once” in a revised form.
I chose instead of masking tape (for it would not stick to my recently ceramic coated vehicle), to use 200 mile duct tape on the two door handles, running a string from 5/16” up from the bottom of each of the metal door handle frames forward to the front, adjusting the front of the string to where is was a perfect, horizontal line. Then without removing the backing of the badge, with one hand placed it temporally touching but above the string, thenmeasured upward from its top edge of the badge to the seam where the bottom of my Titanium Bronze horizontal trim @ 6 1/8”; worked well on both sides (lining up perfectly on the horizontal string) and confirmed with my baby level. Lastly the put the rearmost edge of the badge 1 3/4” forward of the door edge opening. Pulled off the backing and carefully pressed it into the paint. So STICKY as many noted. |
LVBMW1486.00 |
02-06-2024, 04:20 PM | #50 | |
Rep 16
Drives: BMW iX
02-06-2024, 05:04 PM | #51 |
Rep 128
Hope this helps
02-06-2024, 05:10 PM | #52 |
Rep 16
Drives: BMW iX
02-06-2024, 06:11 PM | #53 |
Rep 791
M side badges on Oxide Grey. Photos are taken from a little far away, but I thought they might be useful for seeing the alignment with the door handles and other body lines. Couldn’t have done this without the tips from this thread, so thank you all! Painters tape and a level (and some pre-application alcohol wipes) did the trick.
03-06-2024, 08:46 PM | #54 |
Rep 63
I know this is not the jam of many on this forum, but I decided to go with the original M colors to add my side badge.
I went with the dimensions of 1.5 inches away from the door gap and I used a straight edge to make the bottom of the emblem lineup with the bottom of the front door handles. Note it is not level I used a level, but the doorhandles are not level either. I’ll let you know how it holds up with these guys: https://www.ebay.com/itm/40438430289...mis&media=COPY |
03-27-2024, 12:04 PM | #55 |
Rep 16
Drives: BMW iX
Fender badges iX M60
Fender badges:
why so difficult with laser etc. The way I see it, is that I need some measurements; see picture !! Who will give me these ? Thx in advance !! |
03-31-2024, 05:42 PM | #56 |
Rep 16
Drives: BMW iX
Nobody ??
03-31-2024, 06:17 PM | #57 |
Rep 4,527
How about these, posted on the first page of this thread, in the first post? That not enough (from ChuckChoi )?
04-01-2024, 09:05 AM | #58 |
Rep 16
Drives: BMW iX
Hi Paladin1, yes indeed, I saw these. But I don’t know or the distance of 18 cm at the top is on both sides. Because when I read well, the badge isn’t mounted straight……. So p.e. 18 cm and other sude 17,7 ?
04-01-2024, 11:15 AM | #59 |
Rep 4,527
As per the thread, you are not going to get within tenths of a millimeter. The badges are not mirror images, so will be different on each side. Take a look at the distance from the door edge to the closest part of the badge, and the bottom of the trim edge at the top to the bottom or the top of each badge. Parallel the bottom of the badges to the bottom of the door handles - they're not parallel to the ground or the bottom of the car (post #5) - hence the laser used by some. That's 3 reference points and that's all you need. Use painter's tape to define where you want to place the badges, even tape them to the door to see how they look (post #6). That's as close as you're going to get to factory - don't overthink it. You are placing the badges visually where they look symmetrical and correct. There's no template or jig, and everyone here did it the same way. The only caveat is that once you remove the backing and press them to the door, they're there to stay, so measure several times and work slowly. Be sure you've done the surface prep - clean the area (plain alcohol is fine) and don't touch the sticky backing on the badge. You can remove the badges with a heat gun and dental floss or fishing line, but you're probably looking at new badges if you position them wrong - you get one chance.
04-07-2024, 07:04 AM | #60 | |
Rep 16
Drives: BMW iX
Paladin15599.50 |
04-24-2024, 08:26 AM | #61 |
Rep 16
Drives: BMW iX
What material are the doors made of ?
04-24-2024, 08:45 AM | #62 |
Rep 4,527
The door is aluminum. If you use a laser (which you don't actually need) you need a standard construction laser with a vacuum suction, like this (mentioned several posts up in this same thread:
https://www.amazon.com/Ryobi-ELL1002...s%2C103&sr=8-6 |
04-24-2024, 08:46 AM | #63 | |
Rep 1,993
Drives: '13 128i, '23 iX M60
Im glad mine doesn’t have the 3rd side ///Marketing logo. There is already one on the wheel and on the brake caliper.
2023 BMW iX M60 BSM
2013 BMW 128i 6MT MGM/CR. M-sport/Premium/Cold, HK, Xenons, BMW SSK and PE. ED 7-12-2013 SOLD: '07 E90 6MT BSM/Terra, '18 F31 Sunset/Oyster, '21 Polestar 2 http://www.1addicts.com/forums/showthread.php?t=897862 |
04-24-2024, 08:58 AM | #64 | |
Rep 16
Drives: BMW iX
Paladin15599.50 |
