BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
European Auto Source (EAS)
      02-13-2009, 11:47 AM   #1
SS32
SS32's Avatar
156
Drives: 2008 M3
Arrow DIY: Front Bumper Removal
Does anyone know if there is a DIY out there on removing the front bumper? Or if anyone has done it, could you shed some light on the basic steps?
      02-14-2009, 08:37 PM   #2
Gelsenpower
Gelsenpower's Avatar
Germany
9
Drives: M3 E93 DCT AW
sorry for german language, but I think it still will help...
      02-14-2009, 09:05 PM   #3
mdernst
mdernst's Avatar
Drives: Tesla Model S
2013 BMW M5  [0.00]
Removing and Installing Front Bumper Trim
The same document as above but in English.
Mike
File Type: pdf 51 11 156 Removing and installing front bumper trim.pdf (125.2 KB, 17450 views)
roastbeef11586.00
M3MPH1S592.00
gotjnco21.00
      02-15-2009, 01:10 PM   #4
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
here ... it is for 335 but it is pretty much the same
http://www.e90post.com/forums/showthread.php?t=80133
      09-29-2009, 04:36 PM   #5
mrtm2008
mrtm2008's Avatar
42
Drives: 08 E90 M3 Sedan
Post
Much the same, but you will also need a 10mm ro remove 2 plastic nuts on the driver's side wheel well. You DO NOT need to do the part of waiting to straighten out the wheels to put the wheel well liners to the side. As long as you take out ALL the screws on the bottom of the liner, you will be able to get to the top 2 screw in the bumper, but you will need a long extention to your socket to get it unscrewed.
I'm doing it as I'm typing this on my E90 M3!
08 E90 M3, JrzB/BB, 360 Forged 8 Mesh, H&R Springs, RPI Scoops, Eisenmann Sport Exh, VRS Lip, CF Decklid, CF Diffuser, OSS LED AE, Rear Headrest V1, '09 iDrive Controller, Euro Rear Fog, OEM BlackLine TL, MRTM Design E90 Pedals & Door Lock Studs
      10-21-2009, 03:24 PM   #6
Boost3dm3
Boost3dm3's Avatar
Drives: E92 M3
what about the headlight washers any special notes since some of us may have them?
Become a BMW CCA member; please use member #405205 as a reference . Click here to join online
      10-21-2009, 05:44 PM   #7
JCtx
Drives: No BMW yet
Nope. Did mine a few weeks ago. They're fixed; you just have to slightly lift the bumper there to clear the nozzles. In fact, the washers worked perfect for me since I was by myself; I just pushed in the bumper slightly inclined to one side, waited until the nozzle 'popped' (holding the bumper in place), then did the other .
Just a comment. I did remove the bumper only 'loosening' the inner fenders, but decided to remove them to put it back on. Not worth the aggravation of trying to line up the fender screws. Besides, I was only missing 2 fasteners on each side to fully remove them (and the wheel, of course, but I always take the opportunity to clean everything in there, including the wheels). Good luck.
      10-21-2009, 05:52 PM   #8
Boost3dm3
Boost3dm3's Avatar
Drives: E92 M3
will do
      11-08-2009, 11:32 AM   #9
cchan
Drives: '12 F30 328i/'11 C2S/'04 GT3
Originally Posted by elp_jc View Post
By the way, found a straight rubber strip at the bottom (and middle) of the pan below the radiator, and couldn't find out where it was originally installed, but figured it'd fall again, so didn't investigate any further. If you see it (use a flashlight from the driver's side) somewhere, please take a pic so I know where it belongs (photo below). Thanks, and good luck.
There are two rubber strips along the front and back edges of the vent rectangle of the center undertray. Here's a pic of a new undertray (had to replace mine). The front edge of the undertray is closer to the camera. Hope this helps.
Golden Gate BMWCCA - Car Control Clinics
'13 C4S/'12 328i/'04 GT3
Past: '09 M3 DCT/'03 M3 SMG/'95 M3... missing an E30 I suppose...
      11-08-2009, 04:20 PM   #10
bavarian19
bavarian19's Avatar
Drives: Car
nice!
      11-08-2009, 06:57 PM   #11
JCtx
Drives: No BMW yet
Originally Posted by cchan View Post
There are two rubber strips along the front and back edges of the vent rectangle of the center undertray. Hope this helps.
Absolutely . Many thanks man. Doesn't look critical, but will try to reinstall it from the bottom. Wonder how it got loose . Didn't see any evidence of bumper being removed before, or that part being replaced. Oh well. Thanks again.
      11-08-2009, 08:24 PM   #12
Leozap
Drives: AW E90 M3
LOL I took off my front bumper this morning and found the same rubber lying there doing nothing so I put it back just like the pic above from cchan.
11 335is, KW1, M3 bits and what not
08 M3 Sedan 6mt, loaded, modded to the bone
Old: 04 M3 SMG
      11-08-2009, 11:33 PM   #13
cchan
I just put my new undertray on this afternoon. The rubber strips seem to seal the airflow that passes through the lower radiator, and down through the vent. If you look behind the radiator, there is a curved piece of plastic which diverts the airflow down under the car. I think the back rubber strip should seal behind the curved plastic, to prevent any of the air from getting above the undertray (otherwise if airflow gets up in there, the undertray could start scooping more air and bending down which will be bad - ask me how I know). The front rubber strip doesn't seem to be as critical though.
      11-09-2009, 10:47 AM   #14
JCtx
Drives: No BMW yet
Did you notice that the rubber was all torn where the 3 clips were, meaning it was properly installed to begin with? Wonder what's causing it . Will reinstall it myself as well, but will be checking to see if it dislodges itself again. My underbumper has zero damage, so nothing hit that part.
There's only one big radiator (and condenser), plus the power steering and oil cooler radiators in front of it at the bottom (probably the ones you're referring to). I don't think either rubber piece is critical at all, but of course it's better for them to be in place. Even the channel that the rubber strips mount to doesn't seem to be for aerodynamic purposes, but who knows.
      11-09-2009, 11:23 AM   #15
cchan
This is making me curious too as to why the rubber strips are coming off by themselves, especially since they don't touch the bumper itself. They seemed pretty well stuck on the replacement undertray I put on.
My front bumper was replaced a few months ago due to a minor accident (someone ran an intersection). The undertray was not replaced and looked fine, but perhaps some of the plastic may have been cracked/weakened and not obvious. That, combined with the possibility that the rubber pieces may not have been in place correctly may (and I'm only making an educated guess) have caused my undertray to eventually break. This happened at a recent HPDE, hence my belief that there is significant aero/airflow going through the lower bumper and out that undertray vent at speed.
So this definitely looks like an item we should be checking on every now and then.
      11-09-2009, 05:45 PM   #16
JCtx
Drives: No BMW yet
Okay, just finished reinstalling the piece, and here's what I found (which I didn't notice when I removed the bumper and installed a radiator protective screen):
- Both radiator and oil cooler end at the bottom of the lower bumper opening.
- Engine cooler is placed ahead of the radiator by about 2".
- Right behind this radiator there's a 1/4-circle shroud that starts at the top and ends at the bottom (stick your fingers from the bottom opening and you'll feel it).
- The bottom of the cooler sits in the 'front' rubber seal we're talking about. The bottom of the shroud sits at the 'rear' rubber seal that some us found laying around. We can remove both of them and there's about a 1/2" gap between surfaces. Even with the seals in place, you can squeeze your fingers to push the strip down (make sure you push hard enough -both hands- where the clips are).
- For some reason, BMW wanted the airfrow from the oil cooler to be dumped below the car, rather than hitting the radiator.
Here are my deductions:
-The strips are just to prevent road crap (especially when raining) from getting into the tray. Without the rear guard, my tray was filthy, but I didn't bother to remove the middle part (the one in post #9) during my project. In retrospect, I should have done that. That area is not sealed, but those rubber seals cover most of the bumper opening, minimizing water/crap accumulation inside the tray. NOTE: These are the same seals that protect water from getting into the engine compartment from the front/rear of hood.
- The seal was knocked out during assembly (nice QC ). It's not going to go anywhere again (we'll see about that ).
- The very bottom of the radiator gets no airflow, but it's probably better than hotter air from the oil cooler (nice design ).
Final note to all M3 owners: slide your fingers under the bottom of the front bumper until you feel the opening we're talking about. Reach a little higher and feel that BOTH rubber seals are installed, and press down on both in case one (most likely the rear) is coming off. Push the rubber all around so it fits squarely on the upper surface, sealing the area nicely.
      04-25-2011, 07:35 PM   #17
SIIK2NR
South Korea
51
Drives: AW E92 M3
Any updates or perhaps an actual E92 bumper?
Current: 2006 Lotus Elise SC
Previous:
2008 AW E92 M3 6MT - Sold
2004 AP2 S2000 - Sold
      02-06-2012, 03:28 PM   #18
richardg
richardg's Avatar
Drives: MacanGTS, 991.2GT3, E63wagon
The OP should add this video to the original post and rename thread if possible to DIY front bumper and headlamp removal. Going to do this today for LS3!
      02-08-2012, 12:12 PM   #19
richardg
richardg's Avatar
Finally took off my front bumper to get the headlamps. I want to mention you will need a 10mm for two plastic bolts on the drivers side. Also the headlight washers shouldn't get in your way. Just slightly lift when removing. Also on a side note I found removing the headlamps to be a fucking nightmare. Reaching the bottom hex bolt is a pain and the wheel wells aren't the most malleable.
      07-15-2012, 04:37 PM   #20
windinmyhair
Drives: beamer
It wasn't the easiest thing to do, but I did it, thanks to this guide. :-)
      07-31-2012, 08:44 AM   #21
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
There is a slight gap between the bumper and headlights as well as where the top of the bumper meets the hood. Any suggestions on how to fix this without removing the whole bumper and putting it back on?
      08-08-2012, 10:40 PM   #22
snowmants
snowmants's Avatar
Drives: '06S2K,'11EVO,'11Jeep,'13GL450
2008 BMW E90 M3  [10.00]
Just a few tips from someone who just removed his bumper and headlights:
-Bumper removal is pretty easy and straight forward if you follow the PDF instructions posted above. Don't be afraid to remove more screws from the fender liner than those instructions tell you to. I found it made things easier.
-Make sure you take the front wheels off first.
-Have a "torx 30" bit that fits on your socket wrench. Craftsman makes them and I got one at sears for my 3/8" drive socket wrench.
-when removing the headlights remove the headlight bracket that each of the headlights sit on. It will allow you to remove the headlights without having to try and remove the one almost impossible to get to screw that is directly under the headlight and connects it to the headlight bracket. It took me 2 hours to get that bolt out on the first headlight I did. On the second one I noticed I could just remove the whole bracket with the headlight and it took like 10 minutes instead!
'06 Honda S2000 #555 TT5
'16 Porsche GT4
m3post
