Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      12-08-2014, 10:22 PM   #89
MWcoupe
24k GOLD
MWcoupe's Avatar
Drives: Mineral White M4
I have the adaptive suspension, steering set to sport is a little better, once change steering to comfort... You can really notice the pull to the right.
      12-08-2014, 10:34 PM   #90
Lups
Lups's Avatar
11829
Drives: I don't own a car.
Originally Posted by Wei718 View Post
Wow, more and more people are coming forward on this issue. I hope BMW will do something about it as it's bugging the crap out of me.
Tire pressures okay, nnothing found and I have a good mechanic, car still randomly (Yes, I get out of the car, and check the fucking road too when this happens) under braking my way (hard, fast, you know) decides to pull the wheel to the left. This is seriously dangerous, that's not drool from my road rage attacks on the wheel, it's coffee and I have actual burn marks bc of this.
Now, I am not too weak to hold a wheel, that can be forgotten also.
Suggestions, and yes, I know he does it only to the left, and you guys want to complain about right, but I feel many enough around here at least don't know the difference at all for me to slide this in.
Originally Posted by Joekerr View Post
You're still a little new here, so I'll let you in on a little secret. Whenever Lups types gibberish, this is an opportunity for you to imagine it to be whatever you'd like it to be.
Originally Posted by Delta0311 View Post
How would you know this? Did mommy catch you jerking off to some Big Foot porn ?
      12-08-2014, 10:48 PM   #91
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Yeah, that is very dangerous and maybe you should have them check the brakes if you haven't yet.
      12-08-2014, 10:50 PM   #92
Lups
Lups's Avatar
11829
I have, no reason has been found, and because he doesn't do that always, I really do step out of the car in the lights and check the pavement. I just really need a reason finally. No use to up the power if something is causing this.
      12-08-2014, 10:50 PM   #93
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
Love the pink shoes!!
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      12-08-2014, 10:54 PM   #94
Lups
Lups's Avatar
11829
NO laughing at my massive 7-7.5 feet and my very manly driving shoes!
      12-08-2014, 10:56 PM   #95
Tonymiabmw
Tonymiabmw's Avatar
555
Drives: Nardo F90 M5 on order
It's a tire issue I'm for sure, I have this and a warped set of CCBs rotors. Pulls to the right and Extreme steering vibration from rotors over 80mph braking. The joy of first year model cars. Been waiting a month for ceramic rotors. Gonna be another month I bet.
      12-08-2014, 11:01 PM   #96
Wah
IG@i.am.wah
Wah's Avatar
Drives: M2 CS
You need some M pedals for Peter.
      12-08-2014, 11:01 PM   #97
Wei718
Wei718's Avatar
340
Drives: 718 GT4
I remember reading your thread about it and that sucks. Hopefully the new rotors will fix the problem.
I tried swapping front and rear wheels from left to right and no changes in fact when i did the rears the pull was worse so I'm kinda wondering if it had anything to do with the rear wheels or tires. As of now my dealer refuse to do anything else and is telling me they don't feel the pull but more of a radial pull.
      12-08-2014, 11:04 PM   #98
Lups
Lups's Avatar
11829
STFU and they are coming.
      12-08-2014, 11:04 PM   #99
Tonymiabmw
Tonymiabmw's Avatar
555
Its xtreme on mine. It annoys me honestly. We will see, I'm switching wheels and tires, once the tread is gone on these. My Advisor mentioned changing the rear toe bolt. Might give that a try if swapping tires doesn't work.
      12-08-2014, 11:06 PM   #100
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Check back in with your results! Good luck!
      12-08-2014, 11:27 PM   #101
binky
Drives: 2013 BMW M3
Tried swapping the fronts, no better.
      12-08-2014, 11:53 PM   #102
tooch
Drives: F82
Hey Whats up! Is yours still pulling to the right also? Maybe I should check mine again to see if its still straight. I can't believe so many are pulling to the right.
96 E31 JB
07 E92 AW
F82 BSM
      12-24-2014, 08:34 AM   #103
Damasconian
Damasconian's Avatar
742
Drives: 2015 M4
Here is my experience. I felt the car pulling to the right after getting the car back from my European Delivery. 800+ miles in Europe and I never once felt it pulling in any direction.
I had my 1200 miles service scheduled last week and told them about the alignment issues I was facing. They checked it out and confirmed the car was indeed pulling to the right. They tried the tire switch to no success. They then did the following:
-Adjusted toe-in on front axle
-Adjusted rear axle and front axle
-Adjusted rear camber and tow
-Adjusted front toe
My SA did say BMW's are designed to slightly pull to the right, but not as much as I was experiencing. I got back in the car after all of this and.......it feels the same. Still pulls to the right. Ill have them take another look at it when I bring it back for the front vanity mirror replacement, that's a design flaw in the Coupes that I'm now hearing more and more about. When bringing your seat forward to let someone in the back, don't slam the seat, bring it up gently! Will keep everyone posted.
2015 M4 6-MT
      12-24-2014, 09:11 AM   #104
minn19
minn19's Avatar
14066
Drives: 24 Z06, 23 CT4VBW, 22 PFinder
-Adjusted front toe
I forgot to report back after my 1200 service. Almost the same deal as yours. The alignment was quite a bit off and it is muuuuuuch better now.
      12-24-2014, 11:23 AM   #105
tkhan456
Drives: F82 (MW/Black/Black 19")
I had this problem too. What the hell is going on at BMW. Luckily I was not charged for the fix. They said alignment is covered up to 1200 miles. It took them 5 times and it's still not perfect but I can live with it I think. Mines an F82 though
      12-24-2014, 04:03 PM   #106
Spencer25
2015 M4 Coupe, Black Sapphire
Drives: 2013 F13 M6; 2015 F25 M4 Demo
I am having this SAME problem!!!! My car pulls to the right and it's exhausting/annoying on freeway road trips. I wish I would have paid more attention to this when I first got the car, but after I installed H&R sport springs the car pulled so badly. I took it to irvine BMW who did an alignment and thy confirmed it is pulling to the right but there is nothing they can do because they align the car to spec and that doesn't account for the springs.
How can I fix this issue?!?
      12-24-2014, 05:10 PM   #107
idocm4
idocm4's Avatar
190
Drives: MG F82
Man I must have gotten lucky so far. My M4 tracks straight and true.
      12-24-2014, 05:16 PM   #108
Vigilant
Vigilant's Avatar
Drives: Cautiously fast
Lucky as well...M3 tracks straight. Bizarre that BMW says that this is "expected".
2022 BSM G80 Comp X-drive
      12-24-2014, 09:48 PM   #109
Marckymarc305
Marckymarc305's Avatar
80
Drives: BMW M4
I had it done three time this week and BMW can't fix it. Headquarters needs to fix this problem ASAP
      12-26-2014, 10:04 PM   #110
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Ok so I noticed that after 900 miles it does slightly pull the the right too. And when coming to a stop and u let go of the wheel it ends up off to the right coasting to stop.
Is it really true Bmw is made this way? Never noticed this on my other bmws but then again I didn't read a thread about it before. I actually didn't even notice the pulling until I saw this thread and started to pay attention to it
Is it even Worth mentioning at break in service?
f80post
