03-09-2015, 04:45 PM | #111 |
Blocked from G80/G82 for having an opinion
3498
Rep 3,729
That is actually good thinking. I've already tried this in the past for my M5 and it says cannot be stored. But if anyone with an F80/2 can confirm that would be cool if they allowed that. I've always wanted a separate switch to flip thru the two modes vs. going thru the iDrive menu.
03-09-2015, 04:47 PM | #112 |
Rep 435
Drives: 2017 BMW M4CP SO
It's one of the settings that can't be assigned to 1-8 keys
03-09-2015, 06:01 PM | #113 | |
Rep 2,561
I do randomly dip into M2 mode on the street, but find ///M view a bit too garish. Coupled with removal of all references to radio stations and other controls, I may just reset my M2 "track" settings to use regular HUD mode in the future. But not just yet. a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
03-09-2015, 06:13 PM | #114 |
Rep 435
1-8 buttons aren't reserved for radio and nav. You can assign some iDrive views to it, like sport displays, efficient dynamics, etc. HUD configuration is not one of them however.
03-09-2015, 06:48 PM | #115 | |
Rep 11,760
Drives: 2018 M4 Comp Indv
There are other things you can't store in quick access 1-8, but that you can still get to. For example you can set one of the quick access button to go to your climate settings; this way when you shut off the car you can hit the QA button which will tell your iDrive to go to climate settings, and then pick 'comfort ventilation' ... but you can't store 'comfort ventilation' directly to QA button. In other words, for some functions you can get close enough for it to not matter. in the case of the HUD all you could do was get close to setting in your M1/2 buttons but then you'd have re-config'd your M1/2 button just to turn it on. Very annoying to have abundant but useless flexibility. |
05-09-2016, 08:24 PM | #116 | |
Rep 331
You must have a special M4, mine doesn't turn Orange at night like my 650i did.
05-10-2016, 12:30 AM | #117 |
3498
Rep 3,729
05-30-2016, 09:17 AM | #118 |
Rep 245
It sounds like some polarized lenses work and others don't from reading through this thread.
Polarization is usually oriented in one direction. As far as I remember, for sunglasses, the direction of polarization filters out light that is mostly horizontal. Some polarized glasses may have the polarization direction oriented slightly differently and therefore don't filter out the light from the HUD. You can check out the direction of polarization by using two pairs of polarized sunglasses. Hold one pair over the other (the lenses parallel) and slowly turn it. When it is completely black when you look through the lenses, the polarization directions are perpendicular.
2018 M4 MGM/SO
