07-25-2014, 06:06 AM | #45 | |
Rep 19
07-25-2014, 08:53 AM | #46 |
Rep 501
Not really aggressive compared to a lot of the stuff in this thread but here's mine.
F: 245/40/18x9 ET42 R: 275/35/18x10 ET25 Tires are BFGoodrich Rival which, like many others of the "Extreme Summer" category, run wide compared to other categories. Stock suspension. Zero rubbing even at Autocross. My issue right now is that I cannot fit camber washers up front because the tire will rub on the strut. So I would need camber plates, or spacers+washers to increase negative camber in front. |
07-25-2014, 12:37 PM | #47 |
309
Rep 3,635
Drives: R56 Cooper S
07-25-2014, 01:22 PM | #48 |
Rep 5,329
NIIIICCCCEEEEE
EAS since you guys actually use this car properly, what was needed to be able to run such sizes without fender fouling???
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
07-25-2014, 11:26 PM | #49 |
Rep 151
The car with the Volk TE37 is like perfect to me, I as well would like to know exactly what has been done, what coilover setup, and full alignment and camber specs
07-31-2014, 04:34 PM | #50 | ||
Wagon life
39
Rep 991
hehe still love ya buddy! Quote:
Further to this, the real key is here the 265/35/18 tire. The 35 aspect ratio is short enough that it fits. 245/40/18 is technically "correct" but it does *not* fit properly because it's too tall. Run a 245/255/265 in 35 aspect ratio, and you're fine. Sorry to butt in on EAS's thread, but that car with both those setups looks great! Keep up the good work! Last edited by nekky; 07-31-2014 at 04:40 PM.. |
07-31-2014, 05:06 PM | #51 |
Retrograde
18
Rep 390
Proof that 18's are perfect for these cars. Best mix of aesthetics and practicality.
08-01-2014, 03:18 AM | #52 | |
Rep 5,329
from what i see, without significant fender work, stretched tyres, these aggressive offset rims don't work when the car is used as it supposed to be . like i say, post me up a detailed pic of all four of your fender liners please?? For all we know for track work EAS swap to a more conventional offset, hold your horses until they post... you only have to read numerous posts from APEX fitment threads to know what will and won't work and what NEEDs work to work correctly. to be honest nekky if you think a 10.5" with a 275 is ideal then that in itself says its all, a 265-275 is a 9.5" ideal width for the tyre to be properly seated. What I'm saying is their are imo serious compromises when stuffing such rims on the z4m platform and i just want people to understand those compromises WHEN using the car as the ///M division saw fit, cursing like a granny I'm guessing you can stuff more in their with extreme camber and stretched tyres. Im definitely not bashing people who choose such sizes just trying let people know their are compromises to such setups.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 08-02-2014 at 05:20 AM.. |
08-01-2014, 03:56 AM | #53 |
Rep 509
Ok, now I just have to ask...
With all these wide tires in front on these cars above, is there any difference between a Z4M and a 3.0si? I know the rear is different, but could I manage these front setups on my 3.0si? The reason why I ask is that on my Coupe it rubs with 235/35-19 on 8,5" ET34 if I dont have a lot of negative camber....
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
08-01-2014, 06:47 AM | #54 |
Rep 5,329
front i believe should be the same fitments....
08-01-2014, 07:11 AM | #55 |
Rep 509
So in theory I will be able to have 8,5" ET20 in the front with 225/35 without issues?
If so I will be a happy camper look into getting hold of a set of Apex ARC-8 with Profile 3 both in front and rear. I guess I need to borrow some 15mm spacers and try with my current wheels at first....
08-01-2014, 07:26 AM | #56 |
#dubspec
6344
Rep 5,201
I'm running 19x 8.5 et22 up front with current setup.
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
08-02-2014, 05:17 AM | #57 |
Rep 5,329
how are you finding it in terms of rub etc?? or is this more of a cruise show setup?? remove the spacer for attack mode?
08-02-2014, 07:29 AM | #58 |
Rep 5,329
found this pic from my last Track event
After a few swapping back and forth 18s will stay on this car from now on...
08-02-2014, 12:10 PM | #59 | |
Retrograde
18
Rep 390
08-03-2014, 12:04 AM | #60 |
Rep 12,568
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Steve19670.00 |
08-03-2014, 09:10 AM | #61 |
Rep 5,329
3002, probably one of my favourite setups on the z4 i have seen.... looks perfect to me and with those thick sidewalls you could REALLY up damper rates etc...
08-03-2014, 05:43 PM | #62 |
Rep 12,568
I actually have increased rates. Went from 450f/550r to 550f/650r + H&R front sway bar set at full stiff.
08-07-2014, 09:27 AM | #63 |
Rep 1,530
Drives: 2008 Z4 3.0si, 2013 E92 M3 ZCP
Here's one I saw on FB.
08-07-2014, 01:30 PM | #65 | |
Rep 5,329
doesn't take much for that to happen on the z4 to be honest... mine isn't however... im guessing you've experienced the same on your GFs Red z4m, your offsets were way WAY to aggressive.... ET13 on the z4 front is bordering insanity, it was never going to work, its not just alittle over the line either... did you guys do no research??
08-07-2014, 01:43 PM | #66 |
Rep 19
Lol trust me mate I do plenty of research. I do this for a living.
I'm just seeing if people have tried flipping the mounting around. Fitting it on the inside. I barely touches. It's just a scrub on full lock. Just seeing if you guys have looked into a way around it before I start playing around with it Thanks for the nice condescending reply though. |
