F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > High milage 330D?
GetBMWParts
      03-16-2024, 02:25 PM   #1
tonksie93
Drives: BMW F30 330d M Sport
High milage 330D?
I have a high milage 330D (170k miles) which has had a few mods. EGR delete, DPF delete, meth injection and a custom remap. Also done a swirl flap delete as i was cleaning out the inlet manifold. Never had it dyno’d but i assume it’s around the 310bhp mark.
Change the oil every 10k miles and use Millers 5w30. Along with air filter and fuel filter of course.
Getting to the point where i want to do some preventative maintenance. I am going to do a gearbox service but is there anything engine wise which should be done?
Thanks
      03-18-2024, 02:28 AM   #2
barf
Drives: F30 330D
I would change oil more often, 8k miles max. The bottom end is not as reliable as it was on M57.
Engine chain should be replaced at that mileage. I would do crank bearings aswell if you are planning to keep it for longer. I had a similiar setup with similiar mileage and crank bearings were already worn a bit, conrods were fine.
      03-22-2024, 07:23 PM   #3
vito140
Drives: BMW F30
Hi, i agree on changing the crank and rod bearings, oil pump and a full chain service.
f30post
